Hookflash support for SPA500 Series IP Phones
I have a customer who has a UC560 with 508G model phones desiring to do hookflash so that when they are on the phone, they can receive the next call from the PSTN...having the option to answer it or let it go to voice mail.  With the first call connected, upon attempting the second call, I can hear the call-waiting beep on the handset, but the call is not displayed on the phone. I press the Flash softkey, but nothing happens
I have checked the 'telephony-service' section to verify that 'fxo hook-flash' is present in the configuration.  I did not see the 'Flash' softkey ever appear when making the second call, so I modified the ephone softkey template and added it, which is now appears, but not working.
I guess the biggest question is...is the hookflash option supported for the 508?  Is there something else I need to be looking for?
Many thanks in advance for your assistance!
Brian
Re: Hookflash support for SPA500 Series IP Phones
Hi Brian;
I think answer is no, but escalating to engineering to check.
Alberto
Thanks, Alberto....I appreciate that.
I have an update on this issue.  I connected a 7961 and configured it with the same extension.  I place the first call, then make the second one.  I hear the call waiting beep, but do not see the call displayed on the phone.  When I press the Flash softkey, I get dial tone.  If I press it again, it reverts back to the first call.  Here is the configuration of the voice port:
voice-port 0/1/3
trunk-group FXO-340-3552 1
timing hookflash-out 250
connection plar opx 804
description Configured by CCA 4 FXO-0/1/3-OP
caller-id enable
Here is the portion of the telephony service configuration showing the hookflash statement:
telephony-service
video
fxo hook-flash
max-ephones 114
max-dn 600
ip source-address x.x.x.x port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7921 CP7921G-1.4.1
load 7925 CP7925G-1.3.4SR1
load 7937 apps37sccp.1-3-4-0
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-6
load 501G spa50x-30x-7-4-6
load 502G spa50x-30x-7-4-6
load 504G spa50x-30x-7-4-6
load 508G spa50x-30x-7-4-6
load 509G spa50x-30x-7-4-6
time-zone 12
voicemail 899
max-conferences 8 gain -6
call-forward pattern .T
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name xxxxxx
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 1... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Feb 14 2011 09:46:44
Just let me know if you need anything else.  Thanks again for your assistance!
Hello beavisthrare1,
I am having the same problem with the same setup and a Cisco SPA508G.
the next incoming call is not displayed on the phone and they can hear the call-waiting beep on the handset.
VIP Gold
This thread is very old,
This thread is very old, moreover, it seems your issue is related to Call Waiting supplementary service, not the hook-flash. Your chance someone will respond you in this thread are rather low. Try to create new thread for your issue, describe your environment in details.
396
