Showing results forĀ
Search instead forĀ
Did you mean:Ā
How do I get the UC520 to add 1 and area code to locally dialed numbers?
mcastrigno
I want to add 1 plus to the area code to my locally dialed numbers.
How can I the UC520 to realize it is a local call from the user prospective but add 1 plus the area code so the SIP trunk provider can process the call.
Thanks.
2 Accepted Solutions
Edit the following rules  using the CLI (make additions where appropriate):
voice translation-rule 1112
rule 1 /^91/ /+1/
rule 2 /^9011/ /+/
rule 4 /^9/ /+1/
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate calling 1111
translate called 1112
Make sure that your SIP dial peers (1000 range) have the profile applied, for example
dial-peer voice 1001 voip
corlist outgoing call-local
description ** Outgoing call to SIP trunk (Generic SIP Trunk Provider) **
translation-profile outgoing PSTN_Outgoing
The above feature is called a "voice translation rule" and uses an SED-like syntax for digit manipulation. More info on:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Hope this helps,
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
This is not currently possible via CCA. But the CLI I posted should be safe. Give that a try. If you run into any issues, please contact us. We'll be happy to help.
Marcos
5 Replies 5
rule 1 /^91/ /+1/
rule 2 /^9011/ /+/
rule 4 /^9/ /+1/
Hope this helps,
Marcos Hernandez
Cisco Systems, Inc.
Thanks marchern
I am trying to use CCA as much as possible and only use the CLI when absolutely necessary. The two don't play that nice together but the less I use the cli the less likely i am to upset CCA.
Is this functionality you describe available in CCA?
Thanks.
Marcos
I guess the obvoius question here is what about the inbound direction?
Is there a "default" expectation of how the numbers are to be set? Right now I think the sip trunk provider sends 1(area code) number with no "+" in front
I cannot yet recieve calls. I am simply trying to set up a  single line SIP Trunk  to DID right to one phone.
Right now under:
Configure->Telephony->Voice->Dial Plan
I have a Direct inward dial translation sending the one number to the extention i want to ring but no luck yet
see the attached screen shot
thanks
If you do a "debug ccsip messages" in CLI, you should get some info from the SIP provider regarding the call, and from there investigate further on your setup. DonĀ“t forget "term mon" to get messages on screen if your not using console,
Eivind
