How do you configure fax services on a UC560 through an FXO port
I have a UC 560 and wil like to know, how I can configure one of my FXO ports for fax services. This port is connected to a GSM gateway that has an equal amount of Sim Cards each having an assigned number.
Please assist.
1 REPLY
Re: How do you configure fax services on a UC560 through an FXO
To clarify, the GSM box is connected to the FXO port of the UC500? What type of GSM box is this by the way?
What is the call flow that fax calls will take? Are you just trying to get faxes to work from the FXO port to an FXS port that the fax machine is connected to?
If you could, attach your configurations with all the passwords removed and we can take a look at it.
Anthony
280
