How do you troubleshoot Jitter & Latency?
Does anyone recommend a type of packet sniffer to determine jitter and or latency?
If a client complains about "silent" spaces and/or noise what is the best way to determine the cause?
Is there a "Cisco recommended" software or freeware?
Thank you.
Re: How do you troubleshoot Jitter & Latency?
http://www.cisco.com/en/US/docs/ios/ios_xe/voice_cube_-_ent/configuration/guide/vb_11099_xe.html
Use Wireshark with SIP filtering and look for the BYE message to see endpoint to endpoint stats.
Ya know, the phones also have history of connections and I have seen this there too...
Hi Paul,
There is a command which for some reason I am unable to remember of the top of my head, that allows you to see this on the IOS per ephone I believe...
This is one method, to which was used frequently when I did an ISR 2800 deployment with 30 remote CIPC staff coming in on the system, but I suspect your question though is pertaining more to a SIP trunk and the users experience of that right?
Wireshark is good for this although you really have to wade through a truck load chatter and at times can be confusing.
As soon as I can remember or even find the command I will post it for you to check that one out as well.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
2354
