Community Member
how set operator extension with cca 1.9 on uc520
Hi all,
the auto attendat aasimple.aef (system) has 3 prompts 1- dial by number, 2- dial by name, 0 for operator
how to define the operator extension number
thanks
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: how set operator extension with cca 1.9 on uc520
Use aa_sbcs_v02.aef.  You have more options available to you in CCA.  This screen shot shows you what it would look like.
To get here, in CCA 1.9.1, go to Configure -> Telephony -> Auto Attendant
Community Member
thanks
3670
