Community Member
How to check which software pack I am running on UC560?
I need to figure out if my UC560 needs a software pack upgrade. The show version on the device console shows following. What software pack does it map to?
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 04-Sep-12 20:45 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)XA3, RELEASE SOFTWARE (fc1)
dcVAST-UC560 uptime is 6 weeks, 3 days, 14 hours, 56 minutes
System restarted at 17:32:32 CST Thu Feb 20 2014
System image file is "flash:/uc500-advipservicesk9-mz.151-4.M5"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco UC560-T1E1-K9 (MPC8378) processor (revision 0x100) with 497664K/26624K bytes of memory.
Processor board ID <Removed>
MPC8378 CPU Rev: Part Number 0x80C4, Revision ID 0x21
64 User Licenses
4 Gigabit Ethernet interfaces
24 Serial interfaces
2 terminal lines
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Community Member
Refer to this: https:/
Refer to this:
You are one software pack behind up to date.
