Community Member
how to send 10 digits ?
my E1 provider wants to see 10 digits from my be 3000, but saw only 4 which is my internal line number.
what should i do to send 10 digits???
sorry for my stupid question.
i'm new in phone tec)))
Hi Evgeny,
It should not be 4 digits that are sent out of E1 Interface. It should atleast be office-code+subscriber number, which is typically more than 4 digit. For example in NANP, it is 7 digits. So I have some questions for you:
1) Which country is this deployment in?
2) Is it a local or a long distance call?
3) What number does the user dial?0
Generally, you can change number of digits that gets sent out on the E1 interface on PSTN Connection - S0/SU0-..,  Advanced Setting - Outbound call routing
You need to set it to Manual mode, click Edit and edit patterns in the new window that opens up.
Community Member
1) Russia
2) Local call
3) I create that template for outbound call routing
my isp said that 1002 went from  E1 flow.
I can call different outside users (mobile phone or landline phone without any problems))
According to the template above, called number should be 11 digits starting with 8. If that is not the case, please enable detailed traces, make a call and send that.
Community Member
yep. it was a mistake but after changing to 10 result was the same. (SP see 4 digits number)
later i send you my diag file=))
