11-07-2012 01:21 AM - edited 03-21-2019 06:32 AM
Hi All!
I have not sure the step by step in procedure to upgrade UC540 due a bug CSCtt94391 and I didn´t find related documents with step by step
a) I Just download the pack 8.6.2 included many .tar files and not any .bin image. Only near a IOS Image file is one called uc500-advipservicesk9-mz.151-4.M4b but is strange extension file for me.
b) Is neccessary always CCA tool installed for upgrade??? in this case... Is neccesary the compatibility CCA 3.2.1 with 15.1(4) or is possible with the software instaled in before pack 3.0
c) Is possible to upgrade only IOS software without impact via CLI with a bin file and force with "boot system flash" command with any procedure ?
Please if you know any detailed procedure for upgrading i will aprecieate it !!!
I would like to upgrade as soon as possible this platform an it is not clear for me the correct procedure.
Kind Regards!
Víctor
Solved! Go to Solution.
11-07-2012 08:03 AM
That is up to you. Some people do like CCA, some don't.
11-07-2012 03:13 AM
Please donwnload and use the latest, that is 8.6.1, IOS 15.1(4)M5.
Copy new image in router.
Delete old image.
Reload.
Nothing else is necessary.
11-07-2012 03:24 AM
Hi Paolo, thanks for your quickly answer
I download in the complete 8.6.0 pack the "" uc500-advipservicesk9-mz.151-4.M4b "" file. Is neccesarty to change to .bin extension or router will recognise that extension?
Then I could copy the file .M4b into the flash card and delete old + relaod is that correct?
There are any release referred ?, Service could be impacted heavily
Could I download only .bin image in cisco.com web?
Regards!
Víctor
11-07-2012 06:11 AM
Look in "documents" section for link to the UC500 downloads. Use 8.6.1, not 8.6.0.
11-07-2012 07:30 AM
I would like last confirmation...via CLI coping the .M4b into flash or via CCA 3.2.1 and choose maintenance and upgrade ios as document refers??
11-07-2012 08:03 AM
11-12-2012 08:04 AM
All was done VIa CCA and installed only IOS Software frommy laptop connected in UCS and download pack, it si possible via WAN with CCA installed
This guide help me
Regards!
11-12-2012 11:23 AM
Thank you for the nice rating and good luck!
