Hunt group. Timeout.
Pavel Teplov
Level 4
Level 4
Partner asked me.
What is the timeout set for the hunt group?
Can I to change it?
8.6.3
Russian Locale
Pavel
sanjsinh
Please explain what is meant by Hunt Group timeout. Do you mean the ring answer timeout before the alert to next member in the group? If yes, that timeout is 10 sec. It is not configurable.
sanjsinh
The timeout must be alterable 10 seconds for a BLAST group is not long enough. At the least we need an alterable timeouts for groups and a seperate timeout per profile.
The fact that you cant direct a group to another group is also a huge oversight and a big problem.
