Community Member
Inbound Caller-id on PRI - UC560
I'm having a problem with the inbound name caller-id on the PRI. It shows the name on the Q931 debug but not on the phones.
The provider is ATT and they said that the CO Switch is Lucent 5ESS. but when i use this type of switch the name is not shown on the debugs.
So i configured using primary-ni and shows the name on the debug, but on the phones only the number.
Has anyone have this problem and know how to fix it??
I'm using this version:
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.0(1)XA2, RELEASE SOFTWARE (fc2)
UC560-8.0.2
Please help!
Thanks in advance.
This is the config and debug Q931 not showing the Calling Name using CO Switch primary-5ESS:
controller T1 0/2/0
pri-group timeslots 1-24
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-5ess
isdn incoming-voice voice
isdn supp-service name calling
trunk-group ALL_T1E1
no cdp enable
STPUC560#
002260: Apr 21 21:35:17.860: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0038
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100
        Calling Party Number i = 0x2183, '7869743221'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, '1031'
                Plan:Unknown, Type:Unknown
002261: Apr 21 21:35:17.860: ISDN Se0/2/0:23 Q931: Received SETUP  callref = 0x8038 callID = 0x0052 switch = primary-5ess interface = User
002262: Apr 21 21:35:17.876: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8038
002263: Apr 21 21:35:17.880: ISDN Se0/2/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x8038
        Progress Ind i = 0x8188 - In-band info or appropriate now available
002264: Apr 21 21:35:18.228: ISDN Se0/2/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x0038
        Facility i = 0x9F8B0100A117020101020100800F43524553504F204A45535553204120
002265: Apr 21 21:35:18.228: ISDN Se0/2/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 7, call id 0x52, call ref 0x8038, event 0x62
002266: Apr 21 21:35:18.228: ISDN Se0/2/0:23 Q931: TX -> STATUS pd = 8  callref = 0x8038
        Cause i = 0x80E262 - Message not compatible with call state or not implemented
        Call State i = 0x07
002267: Apr 21 21:35:24.004: ISDN Se0/2/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x0038
        Cause i = 0x8290 - Normal call clearing
002268: Apr 21 21:35:24.004: ISDN Se0/2/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x8038
002269: Apr 21 21:35:24.032: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0038
STPUC560#
This is the config and debug Q931 showing the Calling Name using CO Switch primary-ni:
controller T1 0/2/0
no ip address
encapsulation hdlc
isdn switch-type primary-ni
no cdp enable
STPUC560(config-if)#
002238: Apr 21 21:19:08.940: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8  callref = 0x0037
                Standard = CCITT
                Protocol Profile =  Networking Extensions
                0xA10F02010106072A8648CE1500040A0100
                Component = Invoke component
                        Invoke Id = 1
                        Operation = InformationFollowing (calling_name)
                                Name information in subsequent FACILITY message
        Calling Party Number i = 0x2183, '305774556'
002239: Apr 21 21:19:08.940: ISDN Se0/2/0:23 Q931: Received SETUP  callref = 0x8037 callID = 0x0051 switch = primary-ni interface = User
002240: Apr 21 21:19:08.960: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8037
002241: Apr 21 21:19:08.960: ISDN Se0/2/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x8037
002242: Apr 21 21:19:09.316: ISDN Se0/2/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x0037
        Facility i = 0x9F8B0100A117020101020100800F43524553504F204A45535553202020
                0xA117020101020100800F43524553504F204A45535553202020
                        Invoke Id = 1
                        Operation = CallingName
                                Name Presentation Allowed Extended
                                Name = JOHN SMITH
STPUC560#
1418
