Community Member
Internal Ring?
Is it possible to have the phones ring with a different ring tone for Internal calls?
I have tried googling but have come up with nothing.
Everyone's tags (2)
Community Member
Internal Ring?
If you have multiple line buttons you can have different extensions for external and internal calls. Then you can setup the ring parameters for the button to ring differently.
You may check out my post here:
https://supportforums.cisco.com/message/3939460#3939460
-Trent Good ** Please rate useful posts! **
Community Member
Internal Ring?
I see.
But no other easy way?
Hall of Fame Super Gold
Re: Internal Ring?
It is a different tone.
Listen carefully. Two short tones, or one longer tone.
238
