10-24-2010 11:40 AM - edited 03-21-2019 03:10 AM
What are the options for using IP Overhead Paging?
I'm looking at PagePro IPTM, SIP Based Paging Server, Model VIP-201.
Running 8.0.4 and CCA 2.2.5
I know the CCA can't configure a SIP device, but could I set up via CLI?
10-25-2010 04:52 AM
Honestly, the best solution would be to hand off paging on an FXS port to the Valcom paging unit. I'm not sure if the VIP-201 will support that, but I know for a fact that Valcom has an IP solution that you can plug an FXS into, and then use IP based speakers. I think you can use a VIP-801 to interface with an FXO port, but you need to confirm this with Valcom. They are usually very helpful if you call their Presales line.
10-25-2010 05:43 AM
That won't work as the 2 bldgs are only joined via fiber.
10-25-2010 06:12 AM
If you use the VIP-201, you could put it in the server room where the UC500 resides and hand off analog there, then use IP speakers where you need them
10-25-2010 10:40 AM
I would imagine all you would need on the UC500 is a SIP dial-peer, something like:
dial-peer voice 1 voip
destination-pattern xxxx
session protocol sipv2
session target ipv4:172.22.15.3
codec g711ulaw
xxxx being the number you want to dial for paging
session target ipv4:172.22.15.3 - this would need to be the IP of the PagePro...
I'm not sure how the Page Pro's configuration is but I bet there is a document regarding Integration with Cisco.
