Community Member
IP Overhead Paging
What are the options for using IP Overhead Paging?
I'm looking at PagePro IPTM, SIP Based Paging Server, Model VIP-201.
Running 8.0.4 and CCA 2.2.5
I know the CCA can't configure a SIP device, but could I set up via CLI?
Re: IP Overhead Paging
Honestly, the best solution would be to hand off paging on an FXS port to the Valcom paging unit.  I'm not sure if the VIP-201 will support that, but I know for a fact that Valcom has an IP solution that you can plug an FXS into, and then use IP based speakers.  I think you can use a VIP-801 to interface with an FXO port, but you need to confirm this with Valcom.  They are usually very helpful if you call their Presales line.
Community Member
That won't work as the 2 bldgs are only joined via fiber.
If you use the VIP-201, you could put it in the server room where the UC500 resides and hand off analog there, then use IP speakers where you need them
I would imagine all you would need on the UC500 is a SIP dial-peer, something like:
dial-peer voice 1 voip
destination-pattern xxxx
session protocol sipv2
session target ipv4:
codec g711ulaw
xxxx being the number you want to dial for paging
session target ipv4: - this would need to be the IP of the PagePro...
I'm not sure how the Page Pro's configuration is but I bet there is a document regarding Integration with Cisco.
