IP Phone 7945 - Voicemail to Voicemail transfer
I cannot find documentation for forwarding a voicemail message from one I{ phone to another IP Phone's voicemail.  How to?
Re: IP Phone 7945 - Voicemail to Voicemail transfer
What call control are you using? UC 500? If so, VoiceView Express gives you this option. Watch a brief VOD on:
https://supportforums.cisco.com/docs/DOC-9709
Marcos
Marcos I think he means just transferring the message; when listening to the message press 5 to forward then either spell the end users name or press ## to change to number; enter the number, press pound, add an introduction, press pound, then delete or keep the origianl message.
All of this is dictated by the voicemail system.
Hope this helps.
Correct Bob. That's another way to do it.
Marcos
I will give this a try. This will send directly to the disired extension's VM?
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_user_guide_list.html
Look for end user quick start guides here.  Select the proper version.  It will have all of the information for your users in their language.
9606
