Issue with MeetMe Conferencing
I just went through the MeetMe VOD that's posted on the site and was able to configure it successfully. I have tested it internally using the ephone-dn 1500, as in the VOD, and it works just fine.
The problem that I have though is when an outside call comes in, hits the AA, the tries to dial the extension 1500, it says the number is invalid.
What am I missing here? Do I have to adjust dial-plan or something like that?
Thanks.
Brian
www.jaydien.com
Re: Issue with MeetMe Conferencing
A user needs to exist in CUE so the AA can include it in the dial-out pool. Do the following:
1) Telnet to the UC500
2) Log into CUE (notice enable password is blank):
UC500#service-module integrated-Service-Engine 0/0 session
Trying 10.1.10.2, 2002 ... Open
User Access Verification
Username: cisco
Password:
UC500-CUE>
UC500-CUE> ena
Password:
UC500-CUE#
3) Go into configuration mode "config t"
4) Create the user "meetme" and associate extension 1500:
UC500-CUE(config)# username meetme create
UC500-CUE(config)# username meetme phonenumber 1500
UC500-CUE(config)#exit
UC500-CUE#wr mem
UC500-CUE# exit
UC500-CUE> exit
[Connection to 10.1.10.2 closed by foreign host]
UC500#
Let me know how it goes,
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
Ah that makes perfect sense now. I should have realized that.
I created that user like you said through the CLI and that worked. But just so I'm clear, I could have done that throught the CUE web interface also right?
Thanks for your help.
Brian--
Correct.
Thanks Brian,
Marcos
2867
