Community Member
Issues with Dropped Calls on UC520
I'm having issues with dropped calls on our UC520.  We're running software pack 8.6.1.  Sometimes the system works fine.  Sometimes it will drop calls mid call (sometimes after 15 seconds, sometimes after a few minutes).  I used Voice Debug Log - Voip(Sip) to capture a dropped call.  Could someone please look at it to see if you can find the cause of the dropped call.
Thanks.
--------------------------show logging--------------------------
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 1297 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 4582 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (1000000 bytes):
005708: Jan 10 20:31:17.184: %SYS-5-CONFIG_I: Configured from console by Reid on vty0 (192.168.10.30)
005709: Jan 10 15:31:20.724: //-1/xxxxxxxxxxxx/RXRULE/regxrule_queue_getfirst: NULL queue
005710: Jan 10 15:31:22.240: //-1/xxxxxxxxxxxx/RXRULE/regxrule_queue_getfirst: NULL queue
005711: Jan 10 15:31:23.672: //-1/xxxxxxxxxxxx/RXRULE/regxrule_queue_getfirst: NULL queue
005712: Jan 10 20:31:25.028: %SYS-5-CONFIG_I: Configured from console by Reid on vty0 (192.168.10.30)
005713: Jan 10 15:31:29.292: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:6147777777@69.111.111.11:56192 SIP/2.0
Via: SIP/2.0/UDP 67.205.74.164:5060;branch=z9hG4bK4d1506ca;rport
From: "6148888888" <sip:6148888888@67.205.74.164>;tag=as04151a62
To: <sip:6147777777@69.111.111.11:56192>
Contact: <sip:6148888888@67.205.74.164>
Call-ID: 705d89895386fab10f0244b85e64a684@67.205.74.164
CSeq: 102 INVITE
User-Agent: VoIPMS/SERAST
Max-Forwards: 70
Remote-Party-ID: "6148888888" <sip:6148888888@67.205.74.164>;privacy=off;screen=no
Date: Thu, 10 Jan 2013 20:32:07 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Type: application/sdp
Content-Length: 242
v=0
o=root 15546 15546 IN IP4 67.205.74.164
s=session
c=IN IP4 67.205.74.164
t=0 0
m=audio 15224 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
005714: Jan 10 15:31:29.296: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=6147777777, Called Number=6147777777, Peer Info Type=DIALPEER_INFO_SPEECH
005715: Jan 10 15:31:29.296: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6147777777
005716: Jan 10 15:31:29.296: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=6147777777, Expanded String=6147777777, Calling Number=6147777777T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
005717: Jan 10 15:31:29.296: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20002 Is Matched
005718: Jan 10 15:31:29.296: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
005719: Jan 10 15:31:29.296: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=6147777777, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
005720: Jan 10 15:31:29.296: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20002
005721: Jan 10 15:31:29.296: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6148888888, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
005722: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=6148888888
005723: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
005724: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=6148888888T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
005725: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005726: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005727: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=6148888888
005728: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005729: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005730: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005731: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005732: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
005733: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
005734: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
005735: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005736: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005737: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005738: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005739: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005740: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005741: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005742: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005743: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005744: Jan 10 15:31:29.300: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005745: Jan 10 15:31:29.304: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005746: Jan 10 15:31:29.304: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005747: Jan 10 15:31:29.304: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
005748: Jan 10 15:31:29.304: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
005749: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6148888888, Called Number=6147777777, Voice-Interface=0x0,
005750: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_VIA_URI; URI=sip:67.205.74.164:5060
005751: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:
005752: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
005753: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
   Result=-1
005754: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:exit@5985
005755: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_REQUEST_URI; URI=sip:6147777777@69.111.111.11:56192
005756: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:
005757: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
005758: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
   Result=-1
005759: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:exit@5985
005760: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_TO_URI; URI=sip:6147777777@69.111.111.11:56192
005761: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:
005762: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
005763: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
   Result=-1
005764: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:exit@5985
005765: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_FROM_URI; URI=sip:6148888888@67.205.74.164
005766: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:
005767: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
005768: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
   Result=-1
005769: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:exit@5985
005770: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=6147777777
005771: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:
005772: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchCore:
005773: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=6 Is Matched
005774: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1000 Is Matched
005775: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=3004 Is Matched
005776: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchPeertype:exit@5985
005777: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=3004
005778: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
005779: Jan 10 15:31:29.304: //-1/8C30A0B3947D/DPM/dpAssociateIncomingPeerSPI:exit@6564
005780: Jan 10 15:31:29.308: //-1/xxxxxxxxxxxx/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Set Is Failed
005781: Jan 10 15:31:29.308: //-1/8C30A0B3947D/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=6148888888
   ----- ccCallInfo IE subfields -----
   cisco-ani=6148888888
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=6147777777
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
005782: Jan 10 15:31:29.308: //-1/8C30A0B3947D/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x873D58C8, Call Info(
   Calling Number=6148888888,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6147777777(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3004, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=41206
005783: Jan 10 15:31:29.308: //-1/8C30A0B3947D/CCAPI/ccCheckClipClir:
   In: Calling Number=6148888888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
005784: Jan 10 15:31:29.308: //-1/8C30A0B3947D/CCAPI/ccCheckClipClir:
   Out: Calling Number=6148888888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
005785: Jan 10 15:31:29.308: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005786: Jan 10 15:31:29.308: :cc_get_feature_vsa malloc success
005787: Jan 10 15:31:29.308: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005788: Jan 10 15:31:29.312:  cc_get_feature_vsa count is 3
005789: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005790: Jan 10 15:31:29.312: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329772928,feature_id:15981
005791: Jan 10 15:31:29.312: //41206/8C30A0B3947D/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=6148888888(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=6147777777(TON=Unknown, NPI=Unknown))
005792: Jan 10 15:31:29.312: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD427FC; count=1
005793: Jan 10 15:31:29.312: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E1EA7C
005794: Jan 10 15:31:29.312: //41206/8C30A0B3947D/CCAPI/cc_process_call_setup_ind:
   Event=0x884CB2E8
005795: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6147777777, Peer Info Type=DIALPEER_INFO_SPEECH
005796: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005797: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005798: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
005799: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005800: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=6147777777, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
005801: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
005802: Jan 10 15:31:29.312: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 6147777777
005803: Jan 10 15:31:29.312: //41206/8C30A0B3947D/CCAPI/ccCallSetContext:
   Context=0x8ADF50A4
005804: Jan 10 15:31:29.316: //41206/8C30A0B3947D/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 41206 with tag 3004 to app "_ManagedAppProcess_Default"
005805: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD427FC; count=1
005806: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number=6148888888 type=unknown plan=unknown numbertype=calling
005807: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_get_RegXrule: Translation ruleset with tag=3265 doesn't exist
005808: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
005809: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: No match: number=6148888888 type=unknown plan=unknown
005810: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
005811: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
005812: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
005813: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
005814: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number=6147777777 type=unknown plan=unknown numbertype=called
005815: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 8
005816: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 8
005817: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/sed_subst: Successful substitution; pattern=6147777777 matchPattern=6147777777 replacePattern=500 replaced pattern=500
005818: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
005819: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
005820: Jan 10 15:31:29.316: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: xlt_number=500 xlt_type=unknown xlt_plan=unknown
005821: Jan 10 15:31:29.316: //41206/8C30A0B3947D/CCAPI/ccCallProceeding:
005822: Jan 10 15:31:29.316: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=500, Peer Info Type=DIALPEER_INFO_SPEECH
005823: Jan 10 15:31:29.316: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=500
005824: Jan 10 15:31:29.316: //-1/8C30A0B3947D/DPM/dpMatchCore:
   Dial String=500, Expanded String=500, Calling Number=
005825: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2001 Is Matched
005826: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
005827: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchSafModulePlugin:
   dialstring=500, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
005828: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2001
005829: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
005830: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
005831: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchCore:
005832: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/MatchNextPeer:
005833: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
005834: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchSafModulePlugin:
005835: Jan 10 15:31:29.320: //-1/8C30A0B3947D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
005836: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=500, Called Number=500, Peer Info Type=DIALPEER_INFO_SPEECH
005837: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005838: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=500, Expanded String=500, Calling Number=500T
005839: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
005840: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005841: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
005842: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
005843: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=500, Called Number=, Voice-Interface=0x0,
005844: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=500
005845: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005846: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=500T
005847: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005848: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005849: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=500
005850: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005851: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005852: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=2001 Is Matched
005853: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005854: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2001
005855: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
005856: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
005857: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005858: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005859: Jan 10 15:31:29.320: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005860: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005861: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005862: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005863: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005864: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005865: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005866: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
005867: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005868: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005869: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
005870: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
005871: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005872: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005873: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005874: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
005875: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005876: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
005877: Jan 10 15:31:29.324: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
005878: Jan 10 15:31:29.324: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
005879: Jan 10 15:31:29.324: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
005880: Jan 10 15:31:29.324: //-1/8C30A0B3947D/DPM/dpMatchCore:
005881: Jan 10 15:31:29.328: //-1/8C30A0B3947D/DPM/MatchNextPeer:
005882: Jan 10 15:31:29.328: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
005883: Jan 10 15:31:29.328: //-1/8C30A0B3947D/DPM/dpMatchSafModulePlugin:
   dialstring=500, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
005884: Jan 10 15:31:29.328: //-1/8C30A0B3947D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
005885: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
005886: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number=6148888888 type=unknown plan=unknown numbertype=calling
005887: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
005888: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
005889: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: No match: number=6148888888 type=unknown plan=unknown
005890: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number=500 type=unknown plan=unknown numbertype=called
005891: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
005892: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
005893: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: No match: number=500 type=unknown plan=unknown
005894: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
005895: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
005896: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
005897: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
005898: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_rule_match: partial match found, partial_match 15
005899: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
005900: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: partial match found
005901: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
005902: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
005903: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
005904: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
005905: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_rule_match: partial match found, partial_match 15
005906: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
005907: Jan 10 15:31:29.328: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: partial match found
005908: Jan 10 15:31:29.328: //41206/8C30A0B3947D/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=2001, Params=0x8ADF65B4, Progress Indication=NULL(0)
005909: Jan 10 15:31:29.328: //41206/8C30A0B3947D/CCAPI/ccCheckClipClir:
005910: Jan 10 15:31:29.328: //41206/8C30A0B3947D/CCAPI/ccCheckClipClir:
005911: Jan 10 15:31:29.328: //41206/8C30A0B3947D/CCAPI/ccCallSetupRequest:
   Destination Pattern=500, Called Number=500, Digit Strip=FALSE
005912: Jan 10 15:31:29.328: //41206/8C30A0B3947D/CCAPI/ccCallSetupRequest:
   Called Number=500(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=6148888888
   Account Number=6148888888, Final Destination Flag=TRUE,
   Guid=8C30A0B3-5A9B-11E2-947D-B2297E69AAE1, Outgoing Dial-peer=2001
005913: Jan 10 15:31:29.328: //41206/8C30A0B3947D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=500
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
005914: Jan 10 15:31:29.328: //41206/8C30A0B3947D/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x873D58C8, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=6148888888,(Calling Name=6148888888)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=500(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
005915: Jan 10 15:31:29.328: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005916: Jan 10 15:31:29.332: :cc_get_feature_vsa malloc success
005917: Jan 10 15:31:29.332: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005918: Jan 10 15:31:29.332:  cc_get_feature_vsa count is 4
005919: Jan 10 15:31:29.332: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005920: Jan 10 15:31:29.332: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329770240,feature_id:15982
005921: Jan 10 15:31:29.332: //41207/8C30A0B3947D/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
005922: Jan 10 15:31:29.332: //41207/8C30A0B3947D/CCAPI/ccCallSetContext:
   Context=0x8ADF6564
005923: Jan 10 15:31:29.332: //41206/8C30A0B3947D/CCAPI/ccSaveDialpeerTag:
005924: Jan 10 15:31:29.336: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD427FC; count=1
005925: Jan 10 15:31:29.336: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E1EA7C
005926: Jan 10 15:31:29.336: //-1/8C30A0B3947D/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD427FC; count=1
005927: Jan 10 15:31:29.336: //41207/8C30A0B3947D/CCAPI/cc_api_call_proceeding:
   Interface=0x873D58C8, Progress Indication=NULL(0)
005928: Jan 10 15:31:29.340: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 10 Jan 2013 20:31:29 GMT
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
005929: Jan 10 15:31:29.340: //41207/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:500@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK95D2DA1
From: "6148888888" <sip:6148888888@montreal.voip.ms>;tag=6F7BF7A4-214A
To: <sip:500@10.1.10.1>
Call-ID: 8C36BB73-5A9B11E2-9483B229-7E69AAE1@voip.ms
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2351997107-1520112098-2491265577-2120854241
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1357849889
Contact: <sip:6148888888@10.1.10.2:5060>
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 217
v=0
o=CiscoSystemsSIP-GW-UserAgent 9777 250 IN IP4 10.1.10.2
s=SIP Call
t=0 0
m=audio 16666 RTP/AVP 0 101
c=IN IP4 10.1.10.2
a=fmtp:101 0-16
a=ptime:20
005930: Jan 10 15:31:29.352: //41207/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
005931: Jan 10 15:31:29.408: //41207/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:500@10.1.10.1>;tag=ds4a9131e2
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:500@10.1.10.1:5060;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 8C36BB73-5A9B11E2-9483B229-7E69AAE1@voip.ms
005932: Jan 10 15:31:29.408: //41207/8C30A0B3947D/CCAPI/cc_api_call_alert:
   Interface=0x873D58C8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
005933: Jan 10 15:31:29.408: //41207/8C30A0B3947D/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
005934: Jan 10 15:31:29.408: //41206/8C30A0B3947D/CCAPI/ccCallAlert:
005935: Jan 10 15:31:29.412: //41206/8C30A0B3947D/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
005936: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6148888888, Peer Info Type=DIALPEER_INFO_SPEECH
005937: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6148888888
005938: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=6148888888, Expanded String=6148888888, Calling Number=
005939: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005940: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
005941: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
005942: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
005943: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005944: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005945: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005946: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005947: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005948: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005949: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005950: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
005951: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005952: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
005953: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
005954: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
005955: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
005956: Jan 10 15:31:29.412: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
005957: Jan 10 15:31:29.416: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:6147777777@69.111.111.11:56192>;tag=6F7BF7F0-15D8
CSeq: 102 INVITE
Contact: <sip:500@69.111.111.11:5060>
Content-Length: 0
005958: Jan 10 15:31:29.464: //41207/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 183
v=0
o=CUE 2689610 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 20856 RTP/AVP 0 101
a=fmtp:101 0-15
005959: Jan 10 15:31:29.468: //41207/8C30A0B3947D/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Removal Is Failed
005960: Jan 10 15:31:29.468: //41207/8C30A0B3947D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=41207,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
005961: Jan 10 15:31:29.468: //41207/8C30A0B3947D/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
005962: Jan 10 15:31:29.468: //41206/8C30A0B3947D/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=41207, Source Call Id=41206,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
005963: Jan 10 15:31:29.468: //41206/8C30A0B3947D/CCAPI/cc_api_caps_ack:
005964: Jan 10 15:31:29.468: //41207/8C30A0B3947D/CCAPI/cc_api_event_indication:
   Event=171, Call Id=41207
005965: Jan 10 15:31:29.468: //41207/8C30A0B3947D/CCAPI/cc_api_event_indication:
   Event Is Sent To Conferenced SPI(s) Directly
005966: Jan 10 15:31:29.468: //41207/8C30A0B3947D/CCAPI/cc_api_call_connected:
   Interface=0x873D58C8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
005967: Jan 10 15:31:29.468: //41207/8C30A0B3947D/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
005968: Jan 10 15:31:29.472: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
   (confID=0x8963F39C, callID1=0xA0F6, gcid=8C3275C3-5A9B11E2-9480B229-7E69AAE1, tag=0x0)
005969: Jan 10 15:31:29.472: //41207/8C30A0B3947D/CCAPI/ccConferenceCreate:
   (confID=0x8963F39C, callID2=0xA0F7, gcid=8C3275C3-5A9B11E2-9480B229-7E69AAE1, tag=0x0)
005970: Jan 10 15:31:29.472: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
   Conference Id=0x8963F39C, Call Id1=41206, Call Id2=41207, Tag=0x0
005971: Jan 10 15:31:29.472: //41206/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
005972: Jan 10 15:31:29.472: cc_api_get_xcode_stream : 4702
005973: Jan 10 15:31:29.472: //41207/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
005974: Jan 10 15:31:29.472: cc_api_get_xcode_stream : 4702
005975: Jan 10 15:31:29.472: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
005976: Jan 10 15:31:29.472: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
005977: Jan 10 15:31:29.472: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
   delay media to slow start case, codec negotation is not done
005978: Jan 10 15:31:29.472: //41206/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
005979: Jan 10 15:31:29.472: cc_api_get_xcode_stream : 4702
005980: Jan 10 15:31:29.472: //41206/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
005981: Jan 10 15:31:29.472: cc_api_get_xcode_stream : 4702
005982: Jan 10 15:31:29.472: //41206/8C30A0B3947D/CCAPI/cc_api_bridge_done:
   Conference Id=0xAC6, Source Interface=0x873D58C8, Source Call Id=41206,
   Destination Call Id=41207, Disposition=0x0, Tag=0x0
005983: Jan 10 15:31:29.476: //41207/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
005984: Jan 10 15:31:29.476: cc_api_get_xcode_stream : 4702
005985: Jan 10 15:31:29.476: //41207/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
005986: Jan 10 15:31:29.476: cc_api_get_xcode_stream : 4702
005987: Jan 10 15:31:29.476: //41207/8C30A0B3947D/CCAPI/cc_api_bridge_done:
   Conference Id=0xAC6, Source Interface=0x873D58C8, Source Call Id=41207,
   Destination Call Id=41206, Disposition=0x0, Tag=0x0
005988: Jan 10 15:31:29.476: //41206/8C30A0B3947D/CCAPI/cc_generic_bridge_done:
005989: Jan 10 15:31:29.476: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xAC6, Destination Call Id=41207)
005990: Jan 10 15:31:29.476: //41207/8C30A0B3947D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xAC6, Destination Call Id=41206)
005991: Jan 10 15:31:29.476: //41206/8C30A0B3947D/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xAC6, Call Id1=41206, Call Id2=41207
005992: Jan 10 15:31:29.476: //41207/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:500@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK95D32437
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
005993: Jan 10 15:31:29.480: //41206/8C30A0B3947D/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
005994: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005995: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005996: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
005997: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
005998: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
005999: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006000: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
006001: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006002: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006003: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006004: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006005: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006006: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006007: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006008: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006009: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006010: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006011: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006012: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006013: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006014: Jan 10 15:31:29.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006015: Jan 10 15:31:29.480: //41206/8C30A0B3947D/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
006016: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006017: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006018: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006019: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006020: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006021: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006022: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006023: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006024: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006025: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006026: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006027: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006028: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006029: Jan 10 15:31:29.484: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006030: Jan 10 15:31:29.488: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: <sip:6147777777@69.111.111.11:5060>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 226
v=0
o=CiscoSystemsSIP-GW-UserAgent 6717 8350 IN IP4 69.111.111.11
s=SIP Call
t=0 0
m=audio 18324 RTP/AVP 0 101
c=IN IP4 69.111.111.11
a=fmtp:101 0-16
a=ptime:20
006031: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006032: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006033: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006034: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006035: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006036: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006037: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006038: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006039: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006040: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006041: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006042: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006043: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006044: Jan 10 15:31:29.588: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006045: Jan 10 15:31:29.592: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
006046: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006047: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006048: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006049: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006050: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006051: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006052: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006053: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006054: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006055: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006056: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006057: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006058: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006059: Jan 10 15:31:29.788: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006060: Jan 10 15:31:29.792: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
006061: Jan 10 15:31:30.088: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:6147777777@69.111.111.11:5060 SIP/2.0
Via: SIP/2.0/UDP 67.205.74.164:5060;branch=z9hG4bK20961634;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
006062: Jan 10 15:31:37.180:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E69 timestamp 0x50007263
006063: Jan 10 15:31:37.180:  <<<Rcv> Pt:101    Evt:1       Pkt:07 01 18
006064: Jan 10 15:31:37.180:          s=DSP d=VoIP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E69 timestamp 0x50007263
006065: Jan 10 15:31:37.180:          Pt:101    Evt:1       Pkt:07 01 18  <Snd>>>
006066: Jan 10 15:31:37.200:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6A timestamp 0x50007263
006067: Jan 10 15:31:37.200:  <<<Rcv> Pt:101    Evt:1       Pkt:07 01 18
006068: Jan 10 15:31:37.200:          s=DSP d=VoIP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6A timestamp 0x50007263
006069: Jan 10 15:31:37.200:          Pt:101    Evt:1       Pkt:07 01 18  <Snd>>>
006070: Jan 10 15:31:37.220:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6B timestamp 0x50007263
006071: Jan 10 15:31:37.220:  <<<Rcv> Pt:101    Evt:1       Pkt:07 01 68
006072: Jan 10 15:31:37.220:          s=DSP d=VoIP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6B timestamp 0x50007263
006073: Jan 10 15:31:37.220:          Pt:101    Evt:1       Pkt:07 01 68  <Snd>>>
006074: Jan 10 15:31:37.240:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6C timestamp 0x50007263
006075: Jan 10 15:31:37.240:  <<<Rcv> Pt:101    Evt:1       Pkt:07 02 08
006076: Jan 10 15:31:37.240:          s=DSP d=VoIP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6C timestamp 0x50007263
006077: Jan 10 15:31:37.240:          Pt:101    Evt:1       Pkt:07 02 08  <Snd>>>
006078: Jan 10 15:31:37.260:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6D timestamp 0x50007263
006079: Jan 10 15:31:37.260:  <<<Rcv> Pt:101    Evt:1       Pkt:07 02 A8
006080: Jan 10 15:31:37.260:          s=DSP d=VoIP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6D timestamp 0x50007263
006081: Jan 10 15:31:37.264:          Pt:101    Evt:1       Pkt:07 02 A8  <Snd>>>
006082: Jan 10 15:31:37.272: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:6148888888@10.1.10.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.1:5060;branch=z9hG4bKMs1hd7eCNa1bce5HT01qyA~~912
Max-Forwards: 70
To: <sip:6148888888@montreal.voip.ms>;tag=6F7BF7A4-214A
CSeq: 1 BYE
Content-Length: 0
Also: <sip:501@10.1.10.2:5060;user=phone>
006083: Jan 10 15:31:37.272: //41206/8C30A0B3947D/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=41206
006084: Jan 10 15:31:37.272: //41207/8C30A0B3947D/CCAPI/cc_api_call_facility:
   Interface=0x873D58C8, Call Id=41207
006085: Jan 10 15:31:37.276: //41207/8C30A0B3947D/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
006086: Jan 10 15:31:37.276: //41206/8C30A0B3947D/CCAPI/ccConferenceDestroy:
   Conference Id=0xAC6, Tag=0x0
006087: Jan 10 15:31:37.276: //41206/8C30A0B3947D/CCAPI/cc_api_bridge_drop_done:
006088: Jan 10 15:31:37.276: //41207/8C30A0B3947D/CCAPI/cc_api_bridge_drop_done:
006089: Jan 10 15:31:37.276: //41206/8C30A0B3947D/CCAPI/cc_generic_bridge_done:
006090: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006091: Jan 10 15:31:37.276: :cc_get_feature_vsa malloc success
006092: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006093: Jan 10 15:31:37.276:  cc_get_feature_vsa count is 5
006094: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006095: Jan 10 15:31:37.276: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329776288,feature_id:15983
006096: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006097: Jan 10 15:31:37.276:  feature_vsa is 8ADD78F8,featname is 0
006098: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006099: Jan 10 15:31:37.276: :cc_get_feature_vsa malloc success
006100: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006101: Jan 10 15:31:37.276:  cc_get_feature_vsa count is 6
006102: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006103: Jan 10 15:31:37.276: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329769568,feature_id:15984
006104: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006105: Jan 10 15:31:37.276: : Generating new featurevsa,inserting it
006106: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006107: Jan 10 15:31:37.276:  feature call forward featname is 4
006108: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006109: Jan 10 15:31:37.276:  feature_vsa is 8ADD8378,featname is 0
006110: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006111: Jan 10 15:31:37.276: :cc_get_feature_vsa malloc success
006112: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006113: Jan 10 15:31:37.276:  cc_get_feature_vsa count is 7
006114: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006115: Jan 10 15:31:37.276: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329765760,feature_id:15985
006116: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006117: Jan 10 15:31:37.276: : Generating new featurevsa,inserting it
006118: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006119: Jan 10 15:31:37.276:  feature call forward featname is 4
006120: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006121: Jan 10 15:31:37.276: :cc_free_feature_vsa freeing 8ADD9098
006122: Jan 10 15:31:37.276: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006123: Jan 10 15:31:37.276:  vsacount in free is 6
006124: Jan 10 15:31:37.280: //41207/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "6148888888" <sip:6148888888@montreal.voip.ms>;tag=6F7BF7A4-214A
Date: Thu, 10 Jan 2013 20:31:37 GMT
CSeq: 1 BYE
P-RTP-Stat: PS=353,OS=55700,PR=387,OR=61602,PL=0,JI=0,LA=0,DU=7
Content-Length: 0
006125: Jan 10 15:31:37.280: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=501, Peer Info Type=DIALPEER_INFO_SPEECH
006126: Jan 10 15:31:37.280: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=501
006127: Jan 10 15:31:37.280: //-1/8C30A0B3947D/DPM/dpMatchCore:
   Dial String=501, Expanded String=501, Calling Number=
006128: Jan 10 15:31:37.280: //-1/8C30A0B3947D/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2006 Is Matched
006129: Jan 10 15:31:37.280: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
006130: Jan 10 15:31:37.280: //-1/8C30A0B3947D/DPM/dpMatchSafModulePlugin:
   dialstring=501, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
006131: Jan 10 15:31:37.280: //-1/8C30A0B3947D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2006
006132: Jan 10 15:31:37.280: //41206/8C30A0B3947D/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=0
006133: Jan 10 15:31:37.280:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6E timestamp 0x50007263
006134: Jan 10 15:31:37.280:  <<<Rcv> Pt:101    Evt:1       Pkt:07 03 48
006135: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006136: Jan 10 15:31:37.284: :cc_get_feature_vsa malloc success
006137: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006138: Jan 10 15:31:37.284:  cc_get_feature_vsa count is 7
006139: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006140: Jan 10 15:31:37.284: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329776288,feature_id:15986
006141: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006142: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006143: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006144: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006145: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006146: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006147: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
006148: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006149: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006150: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006151: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006152: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006153: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006154: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
006155: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006156: Jan 10 15:31:37.284: : updating existing feature vsa
006157: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006158: Jan 10 15:31:37.284:  feature call forward featname is 4
006159: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006160: Jan 10 15:31:37.284: :cc_free_feature_vsa freeing 8ADD9098
006161: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006162: Jan 10 15:31:37.284:  vsacount in free is 6
006163: Jan 10 15:31:37.284: //41206/8C30A0B3947D/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
006164: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006165: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006166: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006167: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006168: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006169: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006170: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006171: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006172: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006173: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006174: Jan 10 15:31:37.284: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006175: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006176: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006177: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006178: Jan 10 15:31:37.288: //41206/8C30A0B3947D/CCAPI/ccCallResume:
   Call Id=41206
006179: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=501, Called Number=, Voice-Interface=0x0,
006180: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=501
006181: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006182: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=501T
006183: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006184: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006185: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=501
006186: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006187: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006188: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=2006 Is Matched
006189: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006190: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2006
006191: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006192: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006193: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006194: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006195: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006196: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006197: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006198: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006199: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006200: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006201: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006202: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006203: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006204: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006205: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006206: Jan 10 15:31:37.288: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006207: Jan 10 15:31:37.292: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
006208: Jan 10 15:31:37.292: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
006209: Jan 10 15:31:37.292: //-1/8C30A0B3947D/DPM/dpMatchCore:
006210: Jan 10 15:31:37.292: //-1/8C30A0B3947D/DPM/MatchNextPeer:
006211: Jan 10 15:31:37.292: //-1/8C30A0B3947D/DPM/dpMatchPeersCore:
006212: Jan 10 15:31:37.292: //-1/8C30A0B3947D/DPM/dpMatchSafModulePlugin:
   dialstring=501, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
006213: Jan 10 15:31:37.292: //-1/8C30A0B3947D/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006214: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
006215: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number=6148888888 type=unknown plan=unknown numbertype=calling
006216: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
006217: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
006218: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: No match: number=6148888888 type=unknown plan=unknown
006219: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number=501 type=unknown plan=unknown numbertype=called
006220: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
006221: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
006222: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: No match: number=501 type=unknown plan=unknown
006223: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
006224: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
006225: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
006226: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
006227: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_rule_match: partial match found, partial_match 15
006228: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
006229: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: partial match found
006230: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: number=500 type=unknown plan=unknown numbertype=redirect-called
006231: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: No match; number=500 rule precedence=1
006232: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: No match; number=500 rule precedence=2
006233: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 410
006234: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: No match; number=500 rule precedence=1
006235: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: No match; number=500 rule precedence=2
006236: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 410
006237: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: No match; number=500 rule precedence=1
006238: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_match: No match; number=500 rule precedence=2
006239: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/sed_subst: Successful substitution; pattern=500 matchPattern=^...$ replacePattern=6147777777 replaced pattern=6147777777
006240: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
006241: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
006242: Jan 10 15:31:37.292: //-1/8C30A0B3947D/RXRULE/regxrule_profile_translate_internal: xlt_number=6147777777 xlt_type=unknown xlt_plan=unknown
006243: Jan 10 15:31:37.292: //41206/8C30A0B3947D/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2006, Params=0x8AE07374, Progress Indication=NULL(0)
006244: Jan 10 15:31:37.296: //41206/8C30A0B3947D/CCAPI/ccCheckClipClir:
006245: Jan 10 15:31:37.296: //41206/8C30A0B3947D/CCAPI/ccCheckClipClir:
006246: Jan 10 15:31:37.296: //41206/8C30A0B3947D/CCAPI/ccCallSetupRequest:
   Destination Pattern=501, Called Number=501, Digit Strip=FALSE
006247: Jan 10 15:31:37.296: //41206/8C30A0B3947D/CCAPI/ccCallSetupRequest:
   Called Number=501(TON=Unknown, NPI=Unknown),
   Guid=8C30A0B3-5A9B-11E2-947D-B2297E69AAE1, Outgoing Dial-peer=2006
006248: Jan 10 15:31:37.296: //41206/8C30A0B3947D/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=501
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=6147777777
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
006249: Jan 10 15:31:37.296: //41206/8C30A0B3947D/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=501(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2006, Call Count On=FALSE,
006250: Jan 10 15:31:37.296: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006251: Jan 10 15:31:37.296: :cc_get_feature_vsa malloc success
006252: Jan 10 15:31:37.296: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006253: Jan 10 15:31:37.296:  cc_get_feature_vsa count is 7
006254: Jan 10 15:31:37.296: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006255: Jan 10 15:31:37.296: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329776288,feature_id:15987
006256: Jan 10 15:31:37.296: //41209/8C30A0B3947D/CCAPI/ccIFCallSetupRequestPrivate:
006257: Jan 10 15:31:37.296: //41209/8C30A0B3947D/CCAPI/ccCallSetContext:
   Context=0x8AE07324
006258: Jan 10 15:31:37.296: //41206/8C30A0B3947D/CCAPI/ccSaveDialpeerTag:
006259: Jan 10 15:31:37.300: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD427FC; count=1
006260: Jan 10 15:31:37.300: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E1EA7C
006261: Jan 10 15:31:37.300: //-1/8C30A0B3947D/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD427FC; count=1
006262: Jan 10 15:31:37.300:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E6F timestamp 0x50007263
006263: Jan 10 15:31:37.300:  <<<Rcv> Pt:101    Evt:1       Pkt:07 03 E8
006264: Jan 10 15:31:37.300: //41209/8C30A0B3947D/CCAPI/cc_api_call_proceeding:
006265: Jan 10 15:31:37.304: //41209/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:501@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK95D42685
From: "6148888888" <sip:6148888888@montreal.voip.ms>;tag=6F7C16C4-EA5
To: <sip:501@10.1.10.1>
Call-ID: 90F5FB95-5A9B11E2-9485B229-7E69AAE1@voip.ms
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1357849897
Expires: 180
Max-Forwards: 69
Content-Length: 218
v=0
o=CiscoSystemsSIP-GW-UserAgent 9694 2637 IN IP4 10.1.10.2
s=SIP Call
t=0 0
m=audio 18014 RTP/AVP 0 101
c=IN IP4 10.1.10.2
a=fmtp:101 0-16
a=ptime:20
006266: Jan 10 15:31:37.312: //41209/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
006267: Jan 10 15:31:37.320:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E70 timestamp 0x50007263
006268: Jan 10 15:31:37.320:  <<<Rcv> Pt:101    Evt:1       Pkt:07 04 88
006269: Jan 10 15:31:37.340:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E71 timestamp 0x50007263
006270: Jan 10 15:31:37.340:  <<<Rcv> Pt:101    Evt:1       Pkt:07 05 28
006271: Jan 10 15:31:37.360:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E72 timestamp 0x50007263
006272: Jan 10 15:31:37.360:  <<<Rcv> Pt:101    Evt:1       Pkt:07 05 C8
006273: Jan 10 15:31:37.380:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E73 timestamp 0x50007263
006274: Jan 10 15:31:37.380:  <<<Rcv> Pt:101    Evt:1       Pkt:07 06 68
006275: Jan 10 15:31:37.400:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E74 timestamp 0x50007263
006276: Jan 10 15:31:37.400:  <<<Rcv> Pt:101    Evt:1       Pkt:07 07 08
006277: Jan 10 15:31:37.404: //41209/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:501@10.1.10.1>;tag=dsd870511e
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:501@10.1.10.1:5060;transport=udp>
Cisco-Gcid: 90F5FB95-5A9B11E2-9485B229-7E69AAE1@voip.ms
006278: Jan 10 15:31:37.404: //41209/8C30A0B3947D/CCAPI/cc_api_call_alert:
006279: Jan 10 15:31:37.404: //41209/8C30A0B3947D/CCAPI/cc_api_call_alert:
006280: Jan 10 15:31:37.408: //41206/8C30A0B3947D/CCAPI/ccAssociateStream:
   Coder=5, DTMF Relay=1, Vad=0,
   Record Function=0x0, Event Queue=0x8815FB68, Stream Context=8B5A6B88,
   Record Context=0x0, Stream Call Id=41210, Call Id=41206
006281: Jan 10 15:31:37.408: //41206/8C30A0B3947D/CCAPI/ccAssociateStream:
   Call Entry(Stream Status=2, Digit Enable=FALSE)
006282: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006283: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006284: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006285: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006286: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006287: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006288: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
006289: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006290: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006291: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
006292: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006293: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
006294: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006295: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
006296: Jan 10 15:31:37.408: //41206/8C30A0B3947D/CCAPI/ccCallNotify:
   Data Bitmask=0x17, Call Id=41206
006297: Jan 10 15:31:37.408: //41207/8C30A0B3947D/CCAPI/ccCallFacility:
   Call Id=41207
006298: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006299: Jan 10 15:31:37.408: :cc_get_feature_vsa malloc success
006300: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006301: Jan 10 15:31:37.408:  cc_get_feature_vsa count is 8
006302: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006303: Jan 10 15:31:37.408: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329767776,feature_id:15988
006304: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006305: Jan 10 15:31:37.408: :cc_free_feature_vsa freeing 8ADD6F58
006306: Jan 10 15:31:37.408: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006307: Jan 10 15:31:37.408:  vsacount in free is 7
006308: Jan 10 15:31:37.412: //41206/8C30A0B3947D/CCAPI/cc_api_call_associated:
   Interface=0x0, CallId=41206, Disposition=0
   Play Function=0x83205A3C, Codec=0x5, Vad=0x0
   Media Type=0x3, SPI Context=0x8B638F20, Stream CallId=41210
   TX Dynamic Pt=0x0, RX Dynamic Pt=0x0
006309: Jan 10 15:31:37.420:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E75 timestamp 0x50007263
006310: Jan 10 15:31:37.420:  <<<Rcv> Pt:101    Evt:1       Pkt:07 07 A8
006311: Jan 10 15:31:37.440:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E76 timestamp 0x50007263
006312: Jan 10 15:31:37.440:  <<<Rcv> Pt:101    Evt:1       Pkt:87 07 D0
006313: Jan 10 15:31:37.448: //41209/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 183
Content-Type: application/sdp
v=0
o=CUE 2697573 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 20802 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
006314: Jan 10 15:31:37.448: //41209/8C30A0B3947D/CCAPI/cc_set_post_tagdata:
006315: Jan 10 15:31:37.448: //41209/8C30A0B3947D/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=41209,
006316: Jan 10 15:31:37.448: //41209/8C30A0B3947D/CCAPI/cc_api_caps_ind:
006317: Jan 10 15:31:37.452: //41206/8C30A0B3947D/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=41209, Source Call Id=41206,
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=403)
006318: Jan 10 15:31:37.452: //41206/8C30A0B3947D/CCAPI/cc_api_caps_ack:
006319: Jan 10 15:31:37.452: //41209/8C30A0B3947D/CCAPI/cc_api_event_indication:
   Event=171, Call Id=41209
006320: Jan 10 15:31:37.452: //41209/8C30A0B3947D/CCAPI/cc_api_event_indication:
006321: Jan 10 15:31:37.452: //41209/8C30A0B3947D/CCAPI/cc_api_call_connected:
   Connection Handle=0
006322: Jan 10 15:31:37.452: //41209/8C30A0B3947D/CCAPI/cc_api_call_connected:
006323: Jan 10 15:31:37.460: //41206/8C30A0B3947D/CCAPI/ccDisassociateStream:
006324: Jan 10 15:31:37.460: //41206/8C30A0B3947D/CCAPI/ccDisassociateStream:
   Call Entry(Stream Status=1, Digit Enable=FALSE)
006325: Jan 10 15:31:37.460: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
   (confID=0x8963F504, callID1=0xA0F6, gcid=8C3275C3-5A9B11E2-9480B229-7E69AAE1, tag=0x0)
006326: Jan 10 15:31:37.460: //41209/8C30A0B3947D/CCAPI/ccConferenceCreate:
   (confID=0x8963F504, callID2=0xA0F9, gcid=8C3275C3-5A9B11E2-9480B229-7E69AAE1, tag=0x0)
006327: Jan 10 15:31:37.460: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
   Conference Id=0x8963F504, Call Id1=41206, Call Id2=41209, Tag=0x0
006328: Jan 10 15:31:37.460: //41206/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006329: Jan 10 15:31:37.460: cc_api_get_xcode_stream : 4702
006330: Jan 10 15:31:37.460: //41209/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006331: Jan 10 15:31:37.460: cc_api_get_xcode_stream : 4702
006332: Jan 10 15:31:37.460: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
006333: Jan 10 15:31:37.460: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=0, dtmf1=6
006334: Jan 10 15:31:37.460: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
006335: Jan 10 15:31:37.460: //41206/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006336: Jan 10 15:31:37.460: cc_api_get_xcode_stream : 4702
006337: Jan 10 15:31:37.460: //41206/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006338: Jan 10 15:31:37.460: cc_api_get_xcode_stream : 4702
006339: Jan 10 15:31:37.460:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E77 timestamp 0x50007263
006340: Jan 10 15:31:37.460:  <<<Rcv> Pt:101    Evt:1       Pkt:87 07 D0
006341: Jan 10 15:31:37.460: //41206/8C30A0B3947D/CCAPI/cc_api_bridge_done:
   Conference Id=0xAC7, Source Interface=0x873D58C8, Source Call Id=41206,
   Destination Call Id=41209, Disposition=0x0, Tag=0x0
006342: Jan 10 15:31:37.464: //41209/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006343: Jan 10 15:31:37.464: cc_api_get_xcode_stream : 4702
006344: Jan 10 15:31:37.464: //41209/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006345: Jan 10 15:31:37.464: cc_api_get_xcode_stream : 4702
006346: Jan 10 15:31:37.464: //41209/8C30A0B3947D/CCAPI/cc_api_bridge_done:
   Conference Id=0xAC7, Source Interface=0x873D58C8, Source Call Id=41209,
006347: Jan 10 15:31:37.464: //41206/8C30A0B3947D/CCAPI/cc_generic_bridge_done:
006348: Jan 10 15:31:37.464: //41206/8C30A0B3947D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xAC7, Destination Call Id=41209)
006349: Jan 10 15:31:37.464: //41209/8C30A0B3947D/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xAC7, Destination Call Id=41206)
006350: Jan 10 15:31:37.464: //41207/8C30A0B3947D/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
006351: Jan 10 15:31:37.464: //41207/8C30A0B3947D/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
006352: Jan 10 15:31:37.464: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006353: Jan 10 15:31:37.464: :cc_get_feature_vsa malloc success
006354: Jan 10 15:31:37.464: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006355: Jan 10 15:31:37.464:  cc_get_feature_vsa count is 8
006356: Jan 10 15:31:37.464: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006357: Jan 10 15:31:37.464: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329767776,feature_id:15989
006358: Jan 10 15:31:37.464: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006359: Jan 10 15:31:37.464: :cc_free_feature_vsa freeing 8ADD6F58
006360: Jan 10 15:31:37.464: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006361: Jan 10 15:31:37.464:  vsacount in free is 7
006362: Jan 10 15:31:37.464: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006363: Jan 10 15:31:37.464: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006364: Jan 10 15:31:37.464: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006365: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006366: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006367: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
006368: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
006369: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006370: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006371: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006372: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006373: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006374: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
006375: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
006376: Jan 10 15:31:37.468: //41206/8C30A0B3947D/CCAPI/ccCallNotify:
006377: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006378: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006379: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006380: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006381: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006382: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006383: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
006384: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006385: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006386: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006387: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006388: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006389: Jan 10 15:31:37.468: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006390: Jan 10 15:31:37.472: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
006391: Jan 10 15:31:37.472: //41206/8C30A0B3947D/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=41206
006392: Jan 10 15:31:37.472: //41206/8C30A0B3947D/CCAPI/ccCallResume:
   Call Id=41206
006393: Jan 10 15:31:37.472: //41206/8C30A0B3947D/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xAC7, Call Id1=41206, Call Id2=41209
006394: Jan 10 15:31:37.472: //41209/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:501@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK95D51A7F
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
006395: Jan 10 15:31:37.476: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:6148888888@67.205.74.164:5060 SIP/2.0
Via: SIP/2.0/UDP 69.111.111.11:5060;branch=z9hG4bK95D61EAB
From: <sip:6147777777@69.111.111.11:56192>;tag=6F7BF7F0-15D8
To: "6148888888" <sip:6148888888@67.205.74.164>;tag=as04151a62
Call-ID: 705d89895386fab10f0244b85e64a684@67.205.74.164
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 226
v=0
o=CiscoSystemsSIP-GW-UserAgent 6717 8351 IN IP4 69.111.111.11
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
006396: Jan 10 15:31:37.476: //41207/8C30A0B3947D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x873D58C8, Tag=0x0, Call Id=41207,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
006397: Jan 10 15:31:37.476: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
006398: Jan 10 15:31:37.476: //41207/8C30A0B3947D/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
006399: Jan 10 15:31:37.476: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006400: Jan 10 15:31:37.476: :cc_free_feature_vsa freeing 8ADD7658
006401: Jan 10 15:31:37.476: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006402: Jan 10 15:31:37.476:  vsacount in free is 6
006403: Jan 10 15:31:37.476: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006404: Jan 10 15:31:37.476:  vsacount in free is 5
006405: Jan 10 15:31:37.480:          s=VoIP d=DSP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E78 timestamp 0x50007263
006406: Jan 10 15:31:37.480:  <<<Rcv> Pt:101    Evt:1       Pkt:87 07 D0
006407: Jan 10 15:31:37.480:          s=DSP d=VoIP payload 0x65 ssrc 0x3AE26D33 sequence 0x6E78 timestamp 0x50007263
006408: Jan 10 15:31:37.480:          Pt:101    Evt:1       Pkt:87 07 D0  <Snd>>>
006409: Jan 10 15:31:37.956: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
006410: Jan 10 15:31:38.956: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 10 Jan 2013 20:31:38 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1357849898
Expires: 180
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
006411: Jan 10 15:31:40.956: //41206/8C30A0B3947D/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x873D58C8, Call Id=41206
006412: Jan 10 15:31:40.956: //41206/8C30A0B3947D/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
006413: Jan 10 15:31:40.956: //41209/8C30A0B3947D/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=41209
006414: Jan 10 15:31:40.956: //41206/8C30A0B3947D/CCAPI/ccConferenceDestroy:
   Conference Id=0xAC7, Tag=0x0
006415: Jan 10 15:31:40.956: //41206/8C30A0B3947D/CCAPI/cc_api_bridge_drop_done:
006416: Jan 10 15:31:40.956: //41209/8C30A0B3947D/CCAPI/cc_api_bridge_drop_done:
006417: Jan 10 15:31:40.956: //41206/8C30A0B3947D/CCAPI/cc_generic_bridge_done:
006418: Jan 10 15:31:40.960: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:6148888888@67.205.74.164:5060 SIP/2.0
Via: SIP/2.0/UDP 69.111.111.11:5060;branch=z9hG4bK95D72618
Max-Forwards: 70
Timestamp: 1357849900
CSeq: 102 BYE
Reason: Q.850;cause=86
P-RTP-Stat: PS=557,OS=88643,PR=538,OR=83584,PL=0,JI=0,LA=0,DU=11
Content-Length: 0
006419: Jan 10 15:31:40.960: //41206/8C30A0B3947D/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
006420: Jan 10 15:31:40.960: //41206/8C30A0B3947D/CCAPI/ccCallDisconnect:
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
006421: Jan 10 15:31:40.960: //41209/8C30A0B3947D/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
006422: Jan 10 15:31:40.960: //41209/8C30A0B3947D/CCAPI/ccCallDisconnect:
006423: Jan 10 15:31:40.964: //41209/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:501@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK95D81D7D
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=102
P-RTP-Stat: PS=175,OS=27844,PR=167,OR=26561,PL=0,JI=0,LA=0,DU=3
Content-Length: 0
006424: Jan 10 15:31:40.968: //41209/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
006425: Jan 10 15:31:40.972: //41209/8C30A0B3947D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x873D58C8, Tag=0x0, Call Id=41209,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
006426: Jan 10 15:31:40.972: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
006427: Jan 10 15:31:40.972: //41209/8C30A0B3947D/CCAPI/cc_api_call_disconnect_done:
006428: Jan 10 15:31:40.972: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006429: Jan 10 15:31:40.972: :cc_free_feature_vsa freeing 8ADD9098
006430: Jan 10 15:31:40.972: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006431: Jan 10 15:31:40.972:  vsacount in free is 4
006432: Jan 10 15:31:41.456: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
Timestamp: 1357849901
CSeq: 102 BYE
Content-Length: 0
006433: Jan 10 15:31:42.456: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
Timestamp: 1357849902
CSeq: 102 BYE
Content-Length: 0
006434: Jan 10 15:31:44.456: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
Timestamp: 1357849904
CSeq: 102 BYE
Content-Length: 0
006435: Jan 10 15:31:44.712: //41206/8C30A0B3947D/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 69.111.111.11:5060;branch=z9hG4bK95D72618;received=69.111.111.11
CSeq: 102 BYE
User-Agent: VoIPMS/SERAST
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Length: 0
006436: Jan 10 15:31:44.712: //41206/8C30A0B3947D/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x873D58C8, Tag=0x0, Call Id=41206,
006437: Jan 10 15:31:44.712: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD427FC; count=1
006438: Jan 10 15:31:44.712: //-1/8C30A0B3947D/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E1EA7C
006439: Jan 10 15:31:44.712: //41206/8C30A0B3947D/CCAPI/cc_api_call_disconnect_done:
006440: Jan 10 15:31:44.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006441: Jan 10 15:31:44.712: :cc_free_feature_vsa freeing 8ADD6778
006442: Jan 10 15:31:44.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006443: Jan 10 15:31:44.712:  vsacount in free is 3
006444: Jan 10 15:31:44.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006445: Jan 10 15:31:44.712:  vsacount in free is 2
Re: Issues with Dropped Calls on UC520
Hello Reid,
It seems that you are not receiving confirmation from the SIP provider and then you are disconnecting.
You may want to check if you have enabled the servers of the provider in the access lists and voice source groups if there are any.
Also if the provider sends the response to the source port of the sender you may need to use connection-reuse under sip-ua.
HTH,
Alex
*Please rate helpful posts
Community Member
Hi Alex,
Thanks for the reponse.  I talked to the SIP Provider and they said I needed to have the following ports opened:
SIP:
5060 UDP
RTP Range:
10001-20000 UDP
Here is my access list:
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.10.1
access-list 2 permit 192.168.10.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 3 permit 67.205.74.164
access-list 3 permit 74.63.41.222
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 174.142.75.171
access-list 3 permit 174.137.63.206
access-list 3 deny   any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host 10.1.10.2 eq non500-isakmp
access-list 101 permit udp any host 10.1.10.2 eq isakmp
access-list 101 permit esp any host 10.1.10.2
access-list 101 permit ahp any host 10.1.10.2
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit udp any host 192.168.10.1 eq non500-isakmp
access-list 102 permit udp any host 192.168.10.1 eq isakmp
access-list 102 permit esp any host 192.168.10.1
access-list 102 permit ahp any host 192.168.10.1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any host 10.1.1.1 eq non500-isakmp
access-list 103 permit udp any host 10.1.1.1 eq isakmp
access-list 103 permit esp any host 10.1.1.1
access-list 103 permit ahp any host 10.1.1.1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_28##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit udp any any eq non500-isakmp
access-list 104 permit udp any any eq isakmp
access-list 104 permit esp any any
access-list 104 permit ahp any any
access-list 104 permit udp host 174.142.75.171 eq 5060 any
access-list 104 permit udp host 174.142.75.171 any eq 5060
access-list 104 permit udp host 174.137.63.206 eq 5060 any
access-list 104 permit udp host 174.137.63.206 any eq 5060
access-list 104 permit udp host 192.168.10.1 eq 5060 any
access-list 104 permit udp host 192.168.10.1 any eq 5060
access-list 104 permit udp host 67.205.74.164 range 5060 5080 any
access-list 104 permit udp host 67.205.74.164 any range 5060 5080
access-list 104 permit udp host 74.63.41.222 eq 5060 any
access-list 104 permit udp host 74.63.41.222 any eq 5060
access-list 104 permit udp any any range 10000 32767
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp host 206.248.154.22 eq domain any
access-list 104 permit udp host 206.248.154.170 eq domain any
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 permit udp host 67.205.74.164 range 10000 20000 any
access-list 104 permit udp host 67.205.74.164 any range 10000 20000
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip host 0.0.0.0 any
access-list 104 deny   ip any any
access-list 105 remark SDM_ACL Category=2
access-list 105 deny   ip any host 192.168.10.110
access-list 105 deny   ip any host 192.168.10.111
access-list 105 deny   ip any host 192.168.10.112
access-list 105 deny   ip any host 192.168.10.113
access-list 105 deny   ip any host 192.168.10.114
access-list 105 deny   ip any host 192.168.10.115
access-list 105 deny   ip any host 192.168.10.116
access-list 105 deny   ip any host 192.168.10.117
access-list 105 deny   ip any host 192.168.10.118
access-list 105 deny   ip any host 192.168.10.119
access-list 105 deny   ip any host 192.168.10.120
access-list 105 permit ip 10.1.10.0 0.0.0.3 any
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
Today, I had more issues with dropped calls.  Please find below the SIP log for two calls from my cell phone to our UC520.  The first call worked fine.  The second call dropped.
--------------------------show logging--------------------------
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: disabled
    Buffer logging:  level debugging, 2653 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 4615 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (1000000 bytes):
006481: Jan 17 21:19:47.563: %SYS-5-CONFIG_I: Configured from console by Reid on vty0 (192.168.10.30)
006482: Jan 17 16:19:49.692: //54150/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:montreal.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC6582301
To:
Date: Thu, 17 Jan 2013 21:19:49 GMT
Call-ID: 75DA1F98-602211E2-BE87B229-7E69AAE1@voip.ms
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <66.166.166.22:5060>
Content-Length: 0
006483: Jan 17 16:19:51.724: //54151/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC659131F
To:
Date: Thu, 17 Jan 2013 21:19:51 GMT
Call-ID: 7710316B-602211E2-BE88B229-7E69AAE1@voip.ms
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
006484: Jan 17 16:19:55.756: //54152/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC65A166E
To:
Date: Thu, 17 Jan 2013 21:19:55 GMT
Call-ID: 797772A1-602211E2-BE89B229-7E69AAE1@voip.ms
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
006485: Jan 17 16:20:03.788: //54153/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC65B1D0E
To:
Date: Thu, 17 Jan 2013 21:20:03 GMT
Call-ID: 7E411334-602211E2-BE8AB229-7E69AAE1@voip.ms
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
006486: Jan 17 16:20:04.124: //54153/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC65B1D0E;received=66.166.166.22
To: ;tag=as379e8d60
CSeq: 101 OPTIONS
Supported: replaces
Contact: <67.205.74.164>
Accept: application/sdp
Content-Length: 0
006487: Jan 17 16:20:07.124: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:montreal.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC65C18D4
From: <>103902_line@montreal.voip.ms>;tag=93B4B17C-205A
To: <>103902_line@montreal.voip.ms>
Date: Thu, 17 Jan 2013 21:20:07 GMT
Call-ID: 7A4542F4-499911E2-8002B229-7E69AAE1
Max-Forwards: 70
Timestamp: 1358457607
CSeq: 1725 REGISTER
Contact: <103902_LINE>
Expires:  3600
Supported: path
Content-Length: 0
006488: Jan 17 16:20:07.624: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 1725 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
006489: Jan 17 16:20:08.624: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:20:08 GMT
Max-Forwards: 70
Timestamp: 1358457608
CSeq: 1725 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
006490: Jan 17 16:20:10.624: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:20:10 GMT
Max-Forwards: 70
Timestamp: 1358457610
CSeq: 1725 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
006491: Jan 17 16:20:14.624: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:20:14 GMT
Max-Forwards: 70
Timestamp: 1358457614
CSeq: 1725 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
006492: Jan 17 16:20:18.625: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:20:18 GMT
Max-Forwards: 70
Timestamp: 1358457618
CSeq: 1725 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
006493: Jan 17 16:20:19.073: //54154/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC65C18D4;received=66.166.166.22
CSeq: 1725 REGISTER
Supported: replaces
Content-Length: 0
006494: Jan 17 16:20:19.077: //54154/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <>103902_line@montreal.voip.ms>;tag=as3ce20550
CSeq: 1725 REGISTER
Supported: replaces
WWW-Authenticate: Digest algorithm=MD5, realm="montreal.voip.ms", nonce="4ce0adad"
Content-Length: 0
006495: Jan 17 16:20:19.081: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC65D1F9F
Date: Thu, 17 Jan 2013 21:20:19 GMT
Max-Forwards: 70
Timestamp: 1358457619
CSeq: 1726 REGISTER
Expires: 3600
Authorization: Digest username="103902_line",realm="montreal.voip.ms",uri="sip:montreal.voip.ms:5060",response="14055a89df82d9e502325b91a4d2b590",nonce="4ce0adad",algorithm=MD5
Content-Length: 0
006496: Jan 17 16:20:19.257: //54154/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC65D1F9F;received=66.166.166.22
CSeq: 1726 REGISTER
Supported: replaces
Content-Length: 0
006497: Jan 17 16:20:19.269: //54154/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 1726 REGISTER
Supported: replaces
Expires: 3600
Contact: <103902_LINE>;expires=3600
Date: Thu, 17 Jan 2013 21:20:59 GMT
Content-Length: 0
006498: Jan 17 16:20:31.565: //-1/xxxxxxxxxxxx/RXRULE/regxrule_queue_getfirst: NULL queue
006499: Jan 17 16:20:33.061: //-1/xxxxxxxxxxxx/RXRULE/regxrule_queue_getfirst: NULL queue
006500: Jan 17 16:20:34.517: //-1/xxxxxxxxxxxx/RXRULE/regxrule_queue_getfirst: NULL queue
006501: Jan 17 21:20:35.861: %SYS-5-CONFIG_I: Configured from console by Reid on vty0 (192.168.10.30)
006502: Jan 17 16:20:59.246: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:9154441234@66.166.166.22:56192 SIP/2.0
Via: SIP/2.0/UDP 67.205.74.164:5060;branch=z9hG4bK2b531731;rport
To: <9154441234>
Contact: <6141234567>
Call-ID: 457e7ab472485f234b58d9014570a976@67.205.74.164
CSeq: 102 INVITE
Max-Forwards: 70
Remote-Party-ID: "6141234567" <6141234567>;privacy=off;screen=no
Date: Thu, 17 Jan 2013 21:21:39 GMT
Supported: replaces
Content-Length: 242
v=0
o=root 15546 15546 IN IP4 67.205.74.164
s=session
c=IN IP4 67.205.74.164
t=0 0
m=audio 17532 RTP/AVP 0 101
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
006503: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=9154441234, Called Number=9154441234, Peer Info Type=DIALPEER_INFO_SPEECH
006504: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=9154441234
006505: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=9154441234, Expanded String=9154441234, Calling Number=9154441234T
006506: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20002 Is Matched
006507: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006508: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=9154441234, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
006509: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20002
006510: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6141234567, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
006511: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=6141234567
006512: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
006513: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=6141234567T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
006514: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006515: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006516: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=6141234567
006517: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006518: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006519: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006520: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006521: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
006522: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006523: Jan 17 16:20:59.250: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006524: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006525: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006526: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006527: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006528: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006529: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006530: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006531: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006532: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006533: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006534: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006535: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006536: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006537: Jan 17 16:20:59.254: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006538: Jan 17 16:20:59.254: //-1/9F4F475DBE8B/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6141234567, Called Number=9154441234, Voice-Interface=0x0,
006539: Jan 17 16:20:59.254: //-1/9F4F475DBE8B/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_VIA_URI; URI=sip:67.205.74.164:5060
006540: Jan 17 16:20:59.254: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:
006541: Jan 17 16:20:59.254: //-1/9F4F475DBE8B/DPM/dpMatchCore:
006542: Jan 17 16:20:59.254: //-1/9F4F475DBE8B/DPM/dpMatchCore:
   Result=-1
006543: Jan 17 16:20:59.254: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:exit@5985
006544: Jan 17 16:20:59.254: //-1/9F4F475DBE8B/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_REQUEST_URI; URI=sip:9154441234@66.166.166.22:56192
006545: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:
006546: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchCore:
006547: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchCore:
   Result=-1
006548: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:exit@5985
006549: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_TO_URI; URI=sip:9154441234@66.166.166.22:56192
006550: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:
006551: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchCore:
006552: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchCore:
   Result=-1
006553: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:exit@5985
006554: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_FROM_URI; URI=sip:6141234567@67.205.74.164
006555: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:
006556: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchCore:
006557: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchCore:
   Result=-1
006558: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:exit@5985
006559: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=9154441234
006560: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:
006561: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchCore:
006562: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=6 Is Matched
006563: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1000 Is Matched
006564: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=3004 Is Matched
006565: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchPeertype:exit@5985
006566: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=3004
006567: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpMatchSafModulePlugin:
006568: Jan 17 16:20:59.258: //-1/9F4F475DBE8B/DPM/dpAssociateIncomingPeerSPI:exit@6564
006569: Jan 17 16:20:59.262: //-1/xxxxxxxxxxxx/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Set Is Failed
006570: Jan 17 16:20:59.262: //-1/9F4F475DBE8B/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=6141234567
   ----- ccCallInfo IE subfields -----
   cisco-ani=6141234567
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9154441234
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
006571: Jan 17 16:20:59.262: //-1/9F4F475DBE8B/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x873D58C8, Call Info(
   Calling Number=6141234567,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=9154441234(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3004, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=54155
006572: Jan 17 16:20:59.262: //-1/9F4F475DBE8B/CCAPI/ccCheckClipClir:
   In: Calling Number=6141234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
006573: Jan 17 16:20:59.262: //-1/9F4F475DBE8B/CCAPI/ccCheckClipClir:
   Out: Calling Number=6141234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
006574: Jan 17 16:20:59.262: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006575: Jan 17 16:20:59.262: :cc_get_feature_vsa malloc success
006576: Jan 17 16:20:59.262: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006577: Jan 17 16:20:59.262:  cc_get_feature_vsa count is 3
006578: Jan 17 16:20:59.262: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006579: Jan 17 16:20:59.262: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329765760,feature_id:18794
006580: Jan 17 16:20:59.262: //54155/9F4F475DBE8B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=6141234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=9154441234(TON=Unknown, NPI=Unknown))
006581: Jan 17 16:20:59.262: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD3D0AC; count=1
006582: Jan 17 16:20:59.262: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E20480
006583: Jan 17 16:20:59.266: //54155/9F4F475DBE8B/CCAPI/cc_process_call_setup_ind:
   Event=0x884CB2E8
006584: Jan 17 16:20:59.266: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9154441234, Peer Info Type=DIALPEER_INFO_SPEECH
006585: Jan 17 16:20:59.266: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006586: Jan 17 16:20:59.266: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006587: Jan 17 16:20:59.266: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006588: Jan 17 16:20:59.266: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006589: Jan 17 16:20:59.266: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=9154441234, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
006590: Jan 17 16:20:59.266: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006591: Jan 17 16:20:59.266: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9154441234
006592: Jan 17 16:20:59.266: //54155/9F4F475DBE8B/CCAPI/ccCallSetContext:
   Context=0x8ADFF6A4
006593: Jan 17 16:20:59.266: //54155/9F4F475DBE8B/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 54155 with tag 3004 to app "_ManagedAppProcess_Default"
006594: Jan 17 16:20:59.266: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD3D0AC; count=1
006595: Jan 17 16:20:59.266: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number=6141234567 type=unknown plan=unknown numbertype=calling
006596: Jan 17 16:20:59.266: //-1/9F4F475DBE8B/RXRULE/regxrule_get_RegXrule: Translation ruleset with tag=3265 doesn't exist
006597: Jan 17 16:20:59.266: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
006598: Jan 17 16:20:59.266: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: No match: number=6141234567 type=unknown plan=unknown
006599: Jan 17 16:20:59.266: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
006600: Jan 17 16:20:59.266: //-1/9F4F475DBE8B/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
006601: Jan 17 16:20:59.266: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
006602: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
006603: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number=9154441234 type=unknown plan=unknown numbertype=called
006604: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 8
006605: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 8
006606: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/RXRULE/sed_subst: Successful substitution; pattern=9154441234 matchPattern=9154441234 replacePattern=500 replaced pattern=500
006607: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
006608: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
006609: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: xlt_number=500 xlt_type=unknown xlt_plan=unknown
006610: Jan 17 16:20:59.270: //54155/9F4F475DBE8B/CCAPI/ccCallProceeding:
006611: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=500, Peer Info Type=DIALPEER_INFO_SPEECH
006612: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=500
006613: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchCore:
   Dial String=500, Expanded String=500, Calling Number=
006614: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2001 Is Matched
006615: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
006616: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchSafModulePlugin:
   dialstring=500, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
006617: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2001
006618: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
006619: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
006620: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchCore:
006621: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/MatchNextPeer:
006622: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
006623: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchSafModulePlugin:
006624: Jan 17 16:20:59.270: //-1/9F4F475DBE8B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006625: Jan 17 16:20:59.270: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=500, Called Number=500, Peer Info Type=DIALPEER_INFO_SPEECH
006626: Jan 17 16:20:59.270: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006627: Jan 17 16:20:59.270: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=500, Expanded String=500, Calling Number=500T
006628: Jan 17 16:20:59.270: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006629: Jan 17 16:20:59.270: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006630: Jan 17 16:20:59.270: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006631: Jan 17 16:20:59.270: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006632: Jan 17 16:20:59.270: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=500, Called Number=, Voice-Interface=0x0,
006633: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=500
006634: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006635: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=500T
006636: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006637: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006638: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=500
006639: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006640: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006641: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=2001 Is Matched
006642: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006643: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2001
006644: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006645: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006646: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006647: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006648: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006649: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006650: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006651: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006652: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006653: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006654: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006655: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006656: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006657: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006658: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006659: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006660: Jan 17 16:20:59.274: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006661: Jan 17 16:20:59.278: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006662: Jan 17 16:20:59.278: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006663: Jan 17 16:20:59.278: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006664: Jan 17 16:20:59.278: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006665: Jan 17 16:20:59.278: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006666: Jan 17 16:20:59.278: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006667: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
006668: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
006669: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/DPM/dpMatchCore:
006670: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/DPM/MatchNextPeer:
006671: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
006672: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/DPM/dpMatchSafModulePlugin:
   dialstring=500, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
006673: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006674: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
006675: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number=6141234567 type=unknown plan=unknown numbertype=calling
006676: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
006677: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
006678: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: No match: number=6141234567 type=unknown plan=unknown
006679: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number=500 type=unknown plan=unknown numbertype=called
006680: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
006681: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
006682: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: No match: number=500 type=unknown plan=unknown
006683: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
006684: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
006685: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
006686: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
006687: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_rule_match: partial match found, partial_match 15
006688: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
006689: Jan 17 16:20:59.278: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: partial match found
006690: Jan 17 16:20:59.282: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
006691: Jan 17 16:20:59.282: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
006692: Jan 17 16:20:59.282: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
006693: Jan 17 16:20:59.282: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
006694: Jan 17 16:20:59.282: //-1/9F4F475DBE8B/RXRULE/regxrule_rule_match: partial match found, partial_match 15
006695: Jan 17 16:20:59.282: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
006696: Jan 17 16:20:59.282: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: partial match found
006697: Jan 17 16:20:59.282: //54155/9F4F475DBE8B/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=2001, Params=0x8ADF65B4, Progress Indication=NULL(0)
006698: Jan 17 16:20:59.282: //54155/9F4F475DBE8B/CCAPI/ccCheckClipClir:
006699: Jan 17 16:20:59.282: //54155/9F4F475DBE8B/CCAPI/ccCheckClipClir:
006700: Jan 17 16:20:59.282: //54155/9F4F475DBE8B/CCAPI/ccCallSetupRequest:
   Destination Pattern=500, Called Number=500, Digit Strip=FALSE
006701: Jan 17 16:20:59.282: //54155/9F4F475DBE8B/CCAPI/ccCallSetupRequest:
   Called Number=500(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=6141234567
   Account Number=6141234567, Final Destination Flag=TRUE,
   Guid=9F4F475D-6022-11E2-BE8B-B2297E69AAE1, Outgoing Dial-peer=2001
006702: Jan 17 16:20:59.282: //54155/9F4F475DBE8B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=500
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
006703: Jan 17 16:20:59.282: //54155/9F4F475DBE8B/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x873D58C8, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=6141234567,(Calling Name=6141234567)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=500(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
006704: Jan 17 16:20:59.282: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006705: Jan 17 16:20:59.282: :cc_get_feature_vsa malloc success
006706: Jan 17 16:20:59.282: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006707: Jan 17 16:20:59.282:  cc_get_feature_vsa count is 4
006708: Jan 17 16:20:59.282: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006709: Jan 17 16:20:59.282: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329772256,feature_id:18795
006710: Jan 17 16:20:59.282: //54156/9F4F475DBE8B/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
006711: Jan 17 16:20:59.282: //54156/9F4F475DBE8B/CCAPI/ccCallSetContext:
   Context=0x8ADF6564
006712: Jan 17 16:20:59.282: //54155/9F4F475DBE8B/CCAPI/ccSaveDialpeerTag:
006713: Jan 17 16:20:59.286: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD3D0AC; count=1
006714: Jan 17 16:20:59.286: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E20480
006715: Jan 17 16:20:59.286: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD3D0AC; count=1
006716: Jan 17 16:20:59.286: //54156/9F4F475DBE8B/CCAPI/cc_api_call_proceeding:
   Interface=0x873D58C8, Progress Indication=NULL(0)
006717: Jan 17 16:20:59.290: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <9154441234>
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
006718: Jan 17 16:20:59.294: //54156/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:500@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC65E3F9
From: "6141234567" <>6141234567@montreal.voip.ms>;tag=93B57D40-2228
To: <500>
Call-ID: 9F55621E-602211E2-BE91B229-7E69AAE1@voip.ms
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2672772957-1612845538-3196826153-2120854241
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1358457659
Expires: 180
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 218
v=0
o=CiscoSystemsSIP-GW-UserAgent 3363 2521 IN IP4 10.1.10.2
s=SIP Call
t=0 0
m=audio 19054 RTP/AVP 0 101
c=IN IP4 10.1.10.2
a=fmtp:101 0-16
a=ptime:20
006719: Jan 17 16:20:59.306: //54156/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <500>
CSeq: 101 INVITE
Content-Length: 0
006720: Jan 17 16:20:59.346: //54156/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <500>;tag=dsd6352b6f
CSeq: 101 INVITE
Content-Length: 0
Contact: <500>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 9F55621E-602211E2-BE91B229-7E69AAE1@voip.ms
006721: Jan 17 16:20:59.346: //54156/9F4F475DBE8B/CCAPI/cc_api_call_alert:
   Interface=0x873D58C8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
006722: Jan 17 16:20:59.346: //54156/9F4F475DBE8B/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
006723: Jan 17 16:20:59.346: //54155/9F4F475DBE8B/CCAPI/ccCallAlert:
006724: Jan 17 16:20:59.346: //54155/9F4F475DBE8B/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
006725: Jan 17 16:20:59.346: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6141234567, Peer Info Type=DIALPEER_INFO_SPEECH
006726: Jan 17 16:20:59.346: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6141234567
006727: Jan 17 16:20:59.346: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=6141234567, Expanded String=6141234567, Calling Number=
006728: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006729: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
006730: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006731: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
006732: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006733: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006734: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006735: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006736: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006737: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006738: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006739: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006740: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006741: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006742: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006743: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006744: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006745: Jan 17 16:20:59.350: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006746: Jan 17 16:20:59.354: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <9154441234>;tag=93B57D7C-83E
CSeq: 102 INVITE
Contact: <500>
Content-Length: 0
006747: Jan 17 16:20:59.418: //54156/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 183
Contact: <500>
v=0
o=CUE 6479787 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 21228 RTP/AVP 0 101
a=fmtp:101 0-15
006748: Jan 17 16:20:59.418: //54156/9F4F475DBE8B/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Removal Is Failed
006749: Jan 17 16:20:59.418: //54156/9F4F475DBE8B/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=54156,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
006750: Jan 17 16:20:59.418: //54156/9F4F475DBE8B/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
006751: Jan 17 16:20:59.422: //54155/9F4F475DBE8B/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=54156, Source Call Id=54155,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
006752: Jan 17 16:20:59.422: //54155/9F4F475DBE8B/CCAPI/cc_api_caps_ack:
006753: Jan 17 16:20:59.422: //54156/9F4F475DBE8B/CCAPI/cc_api_event_indication:
   Event=171, Call Id=54156
006754: Jan 17 16:20:59.422: //54156/9F4F475DBE8B/CCAPI/cc_api_event_indication:
   Event Is Sent To Conferenced SPI(s) Directly
006755: Jan 17 16:20:59.422: //54156/9F4F475DBE8B/CCAPI/cc_api_call_connected:
   Interface=0x873D58C8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
006756: Jan 17 16:20:59.422: //54156/9F4F475DBE8B/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
006757: Jan 17 16:20:59.426: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   (confID=0x8963F354, callID1=0xD38B, gcid=9F511C6D-602211E2-BE8EB229-7E69AAE1, tag=0x0)
006758: Jan 17 16:20:59.426: //54156/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   (confID=0x8963F354, callID2=0xD38C, gcid=9F511C6D-602211E2-BE8EB229-7E69AAE1, tag=0x0)
006759: Jan 17 16:20:59.426: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   Conference Id=0x8963F354, Call Id1=54155, Call Id2=54156, Tag=0x0
006760: Jan 17 16:20:59.426: //54155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006761: Jan 17 16:20:59.426: cc_api_get_xcode_stream : 4702
006762: Jan 17 16:20:59.426: //54156/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006763: Jan 17 16:20:59.426: cc_api_get_xcode_stream : 4702
006764: Jan 17 16:20:59.426: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
006765: Jan 17 16:20:59.426: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
006766: Jan 17 16:20:59.426: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   delay media to slow start case, codec negotation is not done
006767: Jan 17 16:20:59.426: //54155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006768: Jan 17 16:20:59.426: cc_api_get_xcode_stream : 4702
006769: Jan 17 16:20:59.426: //54155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006770: Jan 17 16:20:59.426: cc_api_get_xcode_stream : 4702
006771: Jan 17 16:20:59.426: //54155/9F4F475DBE8B/CCAPI/cc_api_bridge_done:
   Conference Id=0xCD1, Source Interface=0x873D58C8, Source Call Id=54155,
   Destination Call Id=54156, Disposition=0x0, Tag=0x0
006772: Jan 17 16:20:59.426: //54156/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006773: Jan 17 16:20:59.426: cc_api_get_xcode_stream : 4702
006774: Jan 17 16:20:59.426: //54156/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
006775: Jan 17 16:20:59.426: cc_api_get_xcode_stream : 4702
006776: Jan 17 16:20:59.426: //54156/9F4F475DBE8B/CCAPI/cc_api_bridge_done:
   Conference Id=0xCD1, Source Interface=0x873D58C8, Source Call Id=54156,
   Destination Call Id=54155, Disposition=0x0, Tag=0x0
006777: Jan 17 16:20:59.426: //54155/9F4F475DBE8B/CCAPI/cc_generic_bridge_done:
006778: Jan 17 16:20:59.430: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xCD1, Destination Call Id=54156)
006779: Jan 17 16:20:59.430: //54156/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xCD1, Destination Call Id=54155)
006780: Jan 17 16:20:59.430: //54155/9F4F475DBE8B/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xCD1, Call Id1=54155, Call Id2=54156
006781: Jan 17 16:20:59.430: //54156/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:500@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC65F22F9
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
006782: Jan 17 16:20:59.430: //54155/9F4F475DBE8B/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
006783: Jan 17 16:20:59.430: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006784: Jan 17 16:20:59.430: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006785: Jan 17 16:20:59.430: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
006786: Jan 17 16:20:59.430: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006787: Jan 17 16:20:59.430: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006788: Jan 17 16:20:59.430: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006789: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
006790: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006791: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006792: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006793: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006794: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006795: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006796: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006797: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006798: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006799: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006800: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006801: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006802: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006803: Jan 17 16:20:59.434: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006804: Jan 17 16:20:59.434: //54155/9F4F475DBE8B/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
006805: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006806: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006807: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006808: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006809: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006810: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006811: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006812: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006813: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006814: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006815: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006816: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006817: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006818: Jan 17 16:20:59.438: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006819: Jan 17 16:20:59.442: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: <9154441234>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Type: application/sdp
Content-Length: 225
v=0
o=CiscoSystemsSIP-GW-UserAgent 3752 889 IN IP4 66.166.166.22
s=SIP Call
t=0 0
m=audio 17924 RTP/AVP 0 101
c=IN IP4 66.166.166.22
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
006820: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006821: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006822: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006823: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006824: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006825: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006826: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006827: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006828: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006829: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006830: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006831: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006832: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006833: Jan 17 16:20:59.538: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006834: Jan 17 16:20:59.542: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 225
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
006835: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006836: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006837: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006838: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006839: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006840: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006841: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006842: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006843: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006844: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006845: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006846: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
006847: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006848: Jan 17 16:20:59.738: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006849: Jan 17 16:20:59.742: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 225
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
006850: Jan 17 16:20:59.898: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:9154441234@66.166.166.22:5060 SIP/2.0
Via: SIP/2.0/UDP 67.205.74.164:5060;branch=z9hG4bK5b6026a6;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
006851: Jan 17 16:21:03.786:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA02 timestamp 0xF7805366
006852: Jan 17 16:21:03.786:  << Pt:101    Evt:1       Pkt:07 01 18
006853: Jan 17 16:21:03.786:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA02 timestamp 0xF7805366
006854: Jan 17 16:21:03.786:          Pt:101    Evt:1       Pkt:07 01 18  >>
006855: Jan 17 16:21:03.802:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA03 timestamp 0xF7805366
006856: Jan 17 16:21:03.802:  << Pt:101    Evt:1       Pkt:07 01 18
006857: Jan 17 16:21:03.802:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA03 timestamp 0xF7805366
006858: Jan 17 16:21:03.802:          Pt:101    Evt:1       Pkt:07 01 18  >>
006859: Jan 17 16:21:03.826:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA04 timestamp 0xF7805366
006860: Jan 17 16:21:03.826:  << Pt:101    Evt:1       Pkt:07 01 68
006861: Jan 17 16:21:03.826:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA04 timestamp 0xF7805366
006862: Jan 17 16:21:03.826:          Pt:101    Evt:1       Pkt:07 01 68  >>
006863: Jan 17 16:21:03.842:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA05 timestamp 0xF7805366
006864: Jan 17 16:21:03.846:  << Pt:101    Evt:1       Pkt:07 02 08
006865: Jan 17 16:21:03.846:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA05 timestamp 0xF7805366
006866: Jan 17 16:21:03.846:          Pt:101    Evt:1       Pkt:07 02 08  >>
006867: Jan 17 16:21:03.862:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA06 timestamp 0xF7805366
006868: Jan 17 16:21:03.862:  << Pt:101    Evt:1       Pkt:07 02 A8
006869: Jan 17 16:21:03.866:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA06 timestamp 0xF7805366
006870: Jan 17 16:21:03.866:          Pt:101    Evt:1       Pkt:07 02 A8  >>
006871: Jan 17 16:21:03.886:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA07 timestamp 0xF7805366
006872: Jan 17 16:21:03.886:  << Pt:101    Evt:1       Pkt:07 03 48
006873: Jan 17 16:21:03.886:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA07 timestamp 0xF7805366
006874: Jan 17 16:21:03.886:          Pt:101    Evt:1       Pkt:07 03 48  >>
006875: Jan 17 16:21:03.906:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA08 timestamp 0xF7805366
006876: Jan 17 16:21:03.906:  << Pt:101    Evt:1       Pkt:07 03 E8
006877: Jan 17 16:21:03.906:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA08 timestamp 0xF7805366
006878: Jan 17 16:21:03.906:          Pt:101    Evt:1       Pkt:07 03 E8  >>
006879: Jan 17 16:21:03.918: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:6141234567@10.1.10.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.1:5060;branch=z9hG4bKMs1hd7eCNa1bce5HT01qyA~~1067
Max-Forwards: 70
To: <>6141234567@montreal.voip.ms>;tag=93B57D40-2228
CSeq: 1 BYE
Content-Length: 0
Also: <501>
006880: Jan 17 16:21:03.918: //54155/9F4F475DBE8B/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=54155
006881: Jan 17 16:21:03.918: //54156/9F4F475DBE8B/CCAPI/cc_api_call_facility:
   Interface=0x873D58C8, Call Id=54156
006882: Jan 17 16:21:03.922: //54156/9F4F475DBE8B/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
006883: Jan 17 16:21:03.922: //54155/9F4F475DBE8B/CCAPI/ccConferenceDestroy:
   Conference Id=0xCD1, Tag=0x0
006884: Jan 17 16:21:03.922: //54155/9F4F475DBE8B/CCAPI/cc_api_bridge_drop_done:
006885: Jan 17 16:21:03.922: //54156/9F4F475DBE8B/CCAPI/cc_api_bridge_drop_done:
006886: Jan 17 16:21:03.922: //54155/9F4F475DBE8B/CCAPI/cc_generic_bridge_done:
006887: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006888: Jan 17 16:21:03.922: :cc_get_feature_vsa malloc success
006889: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006890: Jan 17 16:21:03.922:  cc_get_feature_vsa count is 5
006891: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006892: Jan 17 16:21:03.922: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329776736,feature_id:18796
006893: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006894: Jan 17 16:21:03.922:  feature_vsa is 8ADD80D8,featname is 0
006895: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006896: Jan 17 16:21:03.922: :cc_get_feature_vsa malloc success
006897: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006898: Jan 17 16:21:03.922:  cc_get_feature_vsa count is 6
006899: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006900: Jan 17 16:21:03.922: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329766208,feature_id:18797
006901: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006902: Jan 17 16:21:03.922: : Generating new featurevsa,inserting it
006903: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006904: Jan 17 16:21:03.922:  feature call forward featname is 4
006905: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006906: Jan 17 16:21:03.922:  feature_vsa is 8ADD6778,featname is 0
006907: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006908: Jan 17 16:21:03.922: :cc_get_feature_vsa malloc success
006909: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006910: Jan 17 16:21:03.922:  cc_get_feature_vsa count is 7
006911: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006912: Jan 17 16:21:03.922: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329767328,feature_id:18798
006913: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006914: Jan 17 16:21:03.922: : Generating new featurevsa,inserting it
006915: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006916: Jan 17 16:21:03.922:  feature call forward featname is 4
006917: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006918: Jan 17 16:21:03.922: :cc_free_feature_vsa freeing 8ADD9258
006919: Jan 17 16:21:03.922: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006920: Jan 17 16:21:03.922:  vsacount in free is 6
006921: Jan 17 16:21:03.926:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA09 timestamp 0xF7805366
006922: Jan 17 16:21:03.926:  << Pt:101    Evt:1       Pkt:07 04 88
006923: Jan 17 16:21:03.926: //54156/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "6141234567" <>6141234567@montreal.voip.ms>;tag=93B57D40-2228
Date: Thu, 17 Jan 2013 21:21:03 GMT
CSeq: 1 BYE
P-RTP-Stat: PS=194,OS=29948,PR=221,OR=35042,PL=0,JI=0,LA=0,DU=4
Content-Length: 0
006924: Jan 17 16:21:03.926: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=501, Peer Info Type=DIALPEER_INFO_SPEECH
006925: Jan 17 16:21:03.930: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=501
006926: Jan 17 16:21:03.930: //-1/9F4F475DBE8B/DPM/dpMatchCore:
   Dial String=501, Expanded String=501, Calling Number=
006927: Jan 17 16:21:03.930: //-1/9F4F475DBE8B/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2006 Is Matched
006928: Jan 17 16:21:03.930: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
006929: Jan 17 16:21:03.930: //-1/9F4F475DBE8B/DPM/dpMatchSafModulePlugin:
   dialstring=501, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
006930: Jan 17 16:21:03.930: //-1/9F4F475DBE8B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=2006
006931: Jan 17 16:21:03.930: //54155/9F4F475DBE8B/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=0
006932: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006933: Jan 17 16:21:03.930: :cc_get_feature_vsa malloc success
006934: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006935: Jan 17 16:21:03.930:  cc_get_feature_vsa count is 7
006936: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
006937: Jan 17 16:21:03.930: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329776736,feature_id:18799
006938: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006939: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006940: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006941: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006942: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006943: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
006944: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
006945: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006946: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006947: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006948: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006949: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006950: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
006951: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
006952: Jan 17 16:21:03.930: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006953: Jan 17 16:21:03.930: : updating existing feature vsa
006954: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
006955: Jan 17 16:21:03.934:  feature call forward featname is 4
006956: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006957: Jan 17 16:21:03.934: :cc_free_feature_vsa freeing 8ADD9258
006958: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
006959: Jan 17 16:21:03.934:  vsacount in free is 6
006960: Jan 17 16:21:03.934: //54155/9F4F475DBE8B/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
006961: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006962: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006963: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006964: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006965: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006966: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006967: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006968: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006969: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006970: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006971: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006972: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006973: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006974: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006975: Jan 17 16:21:03.934: //54155/9F4F475DBE8B/CCAPI/ccCallResume:
   Call Id=54155
006976: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=501, Called Number=, Voice-Interface=0x0,
006977: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=501
006978: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006979: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=501T
006980: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
006981: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006982: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=501
006983: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
006984: Jan 17 16:21:03.934: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006985: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=2006 Is Matched
006986: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
006987: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2006
006988: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006989: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
006990: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006991: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006992: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
006993: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
006994: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006995: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
006996: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
006997: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006998: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
006999: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007000: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007001: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007002: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007003: Jan 17 16:21:03.938: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007004: Jan 17 16:21:03.938: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
007005: Jan 17 16:21:03.938: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
007006: Jan 17 16:21:03.938: //-1/9F4F475DBE8B/DPM/dpMatchCore:
007007: Jan 17 16:21:03.938: //-1/9F4F475DBE8B/DPM/MatchNextPeer:
007008: Jan 17 16:21:03.938: //-1/9F4F475DBE8B/DPM/dpMatchPeersCore:
007009: Jan 17 16:21:03.938: //-1/9F4F475DBE8B/DPM/dpMatchSafModulePlugin:
   dialstring=501, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
007010: Jan 17 16:21:03.938: //-1/9F4F475DBE8B/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007011: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
007012: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number=6141234567 type=unknown plan=unknown numbertype=calling
007013: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007014: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
007015: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: No match: number=6141234567 type=unknown plan=unknown
007016: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number=501 type=unknown plan=unknown numbertype=called
007017: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007018: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
007019: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: No match: number=501 type=unknown plan=unknown
007020: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
007021: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
007022: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
007023: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
007024: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_rule_match: partial match found, partial_match 15
007025: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
007026: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: partial match found
007027: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: number=500 type=unknown plan=unknown numbertype=redirect-called
007028: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: No match; number=500 rule precedence=1
007029: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: No match; number=500 rule precedence=2
007030: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 410
007031: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: No match; number=500 rule precedence=1
007032: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: No match; number=500 rule precedence=2
007033: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 410
007034: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: No match; number=500 rule precedence=1
007035: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_match: No match; number=500 rule precedence=2
007036: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/sed_subst: Successful substitution; pattern=500 matchPattern=^...$ replacePattern=9154441234 replaced pattern=9154441234
007037: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
007038: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
007039: Jan 17 16:21:03.942: //-1/9F4F475DBE8B/RXRULE/regxrule_profile_translate_internal: xlt_number=9154441234 xlt_type=unknown xlt_plan=unknown
007040: Jan 17 16:21:03.942: //54155/9F4F475DBE8B/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2006, Params=0x8B751908, Progress Indication=NULL(0)
007041: Jan 17 16:21:03.942: //54155/9F4F475DBE8B/CCAPI/ccCheckClipClir:
007042: Jan 17 16:21:03.942: //54155/9F4F475DBE8B/CCAPI/ccCheckClipClir:
007043: Jan 17 16:21:03.942: //54155/9F4F475DBE8B/CCAPI/ccCallSetupRequest:
   Destination Pattern=501, Called Number=501, Digit Strip=FALSE
007044: Jan 17 16:21:03.942: //54155/9F4F475DBE8B/CCAPI/ccCallSetupRequest:
   Called Number=501(TON=Unknown, NPI=Unknown),
   Guid=9F4F475D-6022-11E2-BE8B-B2297E69AAE1, Outgoing Dial-peer=2006
007045: Jan 17 16:21:03.942: //54155/9F4F475DBE8B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=501
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=9154441234
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
007046: Jan 17 16:21:03.942: //54155/9F4F475DBE8B/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=501(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2006, Call Count On=FALSE,
007047: Jan 17 16:21:03.942: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007048: Jan 17 16:21:03.942: :cc_get_feature_vsa malloc success
007049: Jan 17 16:21:03.942: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007050: Jan 17 16:21:03.942:  cc_get_feature_vsa count is 7
007051: Jan 17 16:21:03.942: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007052: Jan 17 16:21:03.942: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329776736,feature_id:18800
007053: Jan 17 16:21:03.946: //54158/9F4F475DBE8B/CCAPI/ccIFCallSetupRequestPrivate:
007054: Jan 17 16:21:03.946: //54158/9F4F475DBE8B/CCAPI/ccCallSetContext:
   Context=0x8B7518B8
007055: Jan 17 16:21:03.946: //54155/9F4F475DBE8B/CCAPI/ccSaveDialpeerTag:
007056: Jan 17 16:21:03.950: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD3D0AC; count=1
007057: Jan 17 16:21:03.950: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E20480
007058: Jan 17 16:21:03.950: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD3D0AC; count=1
007059: Jan 17 16:21:03.950: //54158/9F4F475DBE8B/CCAPI/cc_api_call_proceeding:
007060: Jan 17 16:21:03.954: //54158/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:501@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC6601C6D
From: "6141234567" <>6141234567@montreal.voip.ms>;tag=93B58F74-1ED4
To: <501>
Call-ID: A21D124B-602211E2-BE93B229-7E69AAE1@voip.ms
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1358457663
Expires: 180
Max-Forwards: 69
Content-Length: 218
v=0
o=CiscoSystemsSIP-GW-UserAgent 2338 7130 IN IP4 10.1.10.2
s=SIP Call
t=0 0
m=audio 17430 RTP/AVP 0 101
c=IN IP4 10.1.10.2
a=fmtp:101 0-16
a=ptime:20
007061: Jan 17 16:21:03.962: //54158/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <501>
CSeq: 101 INVITE
Content-Length: 0
007062: Jan 17 16:21:03.982:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA0A timestamp 0xF7805366
007063: Jan 17 16:21:03.982:  << Pt:101    Evt:1       Pkt:87 04 D8
007064: Jan 17 16:21:03.982:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA0B timestamp 0xF7805366
007065: Jan 17 16:21:03.982:  << Pt:101    Evt:1       Pkt:87 04 D8
007066: Jan 17 16:21:03.986:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDA0C timestamp 0xF7805366
007067: Jan 17 16:21:03.986:  << Pt:101    Evt:1       Pkt:87 04 D8
007068: Jan 17 16:21:04.014: //54158/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <501>;tag=ds82793dab
CSeq: 101 INVITE
Content-Length: 0
Contact: <501>
Cisco-Gcid: A21D124B-602211E2-BE93B229-7E69AAE1@voip.ms
007069: Jan 17 16:21:04.014: //54158/9F4F475DBE8B/CCAPI/cc_api_call_alert:
007070: Jan 17 16:21:04.014: //54158/9F4F475DBE8B/CCAPI/cc_api_call_alert:
007071: Jan 17 16:21:04.018: //54155/9F4F475DBE8B/CCAPI/ccAssociateStream:
   Coder=5, DTMF Relay=1, Vad=0,
   Record Function=0x0, Event Queue=0x8815FB68, Stream Context=8B0A6938,
   Record Context=0x0, Stream Call Id=54159, Call Id=54155
007072: Jan 17 16:21:04.018: //54155/9F4F475DBE8B/CCAPI/ccAssociateStream:
   Call Entry(Stream Status=2, Digit Enable=FALSE)
007073: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007074: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007075: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007076: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007077: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007078: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007079: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007080: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007081: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007082: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007083: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007084: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007085: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007086: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
007087: Jan 17 16:21:04.018: //54155/9F4F475DBE8B/CCAPI/ccCallNotify:
   Data Bitmask=0x17, Call Id=54155
007088: Jan 17 16:21:04.018: //54156/9F4F475DBE8B/CCAPI/ccCallFacility:
   Call Id=54156
007089: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007090: Jan 17 16:21:04.018: :cc_get_feature_vsa malloc success
007091: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007092: Jan 17 16:21:04.018:  cc_get_feature_vsa count is 8
007093: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007094: Jan 17 16:21:04.018: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329770240,feature_id:18801
007095: Jan 17 16:21:04.018: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007096: Jan 17 16:21:04.018: :cc_free_feature_vsa freeing 8ADD78F8
007097: Jan 17 16:21:04.022: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007098: Jan 17 16:21:04.022:  vsacount in free is 7
007099: Jan 17 16:21:04.022: //54155/9F4F475DBE8B/CCAPI/cc_api_call_associated:
   Interface=0x0, CallId=54155, Disposition=0
   Play Function=0x83205A3C, Codec=0x5, Vad=0x0
   Media Type=0x3, SPI Context=0x8B638F20, Stream CallId=54159
   TX Dynamic Pt=0x0, RX Dynamic Pt=0x0
007100: Jan 17 16:21:04.142: //54158/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 183
Contact: <501>
v=0
o=CUE 6484445 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 20546 RTP/AVP 0 101
a=fmtp:101 0-15
007101: Jan 17 16:21:04.146: //54158/9F4F475DBE8B/CCAPI/cc_set_post_tagdata:
007102: Jan 17 16:21:04.146: //54158/9F4F475DBE8B/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=54158,
007103: Jan 17 16:21:04.146: //54158/9F4F475DBE8B/CCAPI/cc_api_caps_ind:
007104: Jan 17 16:21:04.146: //54155/9F4F475DBE8B/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=54158, Source Call Id=54155,
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9248)
007105: Jan 17 16:21:04.146: //54155/9F4F475DBE8B/CCAPI/cc_api_caps_ack:
007106: Jan 17 16:21:04.146: //54158/9F4F475DBE8B/CCAPI/cc_api_event_indication:
   Event=171, Call Id=54158
007107: Jan 17 16:21:04.146: //54158/9F4F475DBE8B/CCAPI/cc_api_event_indication:
007108: Jan 17 16:21:04.150: //54158/9F4F475DBE8B/CCAPI/cc_api_call_connected:
   Connection Handle=0
007109: Jan 17 16:21:04.150: //54158/9F4F475DBE8B/CCAPI/cc_api_call_connected:
007110: Jan 17 16:21:04.154: //54155/9F4F475DBE8B/CCAPI/ccDisassociateStream:
007111: Jan 17 16:21:04.154: //54155/9F4F475DBE8B/CCAPI/ccDisassociateStream:
   Call Entry(Stream Status=1, Digit Enable=FALSE)
007112: Jan 17 16:21:04.158: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   (confID=0x8963F504, callID1=0xD38B, gcid=9F511C6D-602211E2-BE8EB229-7E69AAE1, tag=0x0)
007113: Jan 17 16:21:04.158: //54158/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   (confID=0x8963F504, callID2=0xD38E, gcid=9F511C6D-602211E2-BE8EB229-7E69AAE1, tag=0x0)
007114: Jan 17 16:21:04.158: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   Conference Id=0x8963F504, Call Id1=54155, Call Id2=54158, Tag=0x0
007115: Jan 17 16:21:04.158: //54155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007116: Jan 17 16:21:04.158: cc_api_get_xcode_stream : 4702
007117: Jan 17 16:21:04.158: //54158/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007118: Jan 17 16:21:04.158: cc_api_get_xcode_stream : 4702
007119: Jan 17 16:21:04.158: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
007120: Jan 17 16:21:04.158: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=0, dtmf1=6
007121: Jan 17 16:21:04.158: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
007122: Jan 17 16:21:04.158: //54155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007123: Jan 17 16:21:04.158: cc_api_get_xcode_stream : 4702
007124: Jan 17 16:21:04.158: //54155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007125: Jan 17 16:21:04.158: cc_api_get_xcode_stream : 4702
007126: Jan 17 16:21:04.158: //54155/9F4F475DBE8B/CCAPI/cc_api_bridge_done:
   Conference Id=0xCD2, Source Interface=0x873D58C8, Source Call Id=54155,
   Destination Call Id=54158, Disposition=0x0, Tag=0x0
007127: Jan 17 16:21:04.158: //54158/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007128: Jan 17 16:21:04.158: cc_api_get_xcode_stream : 4702
007129: Jan 17 16:21:04.158: //54158/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007130: Jan 17 16:21:04.158: cc_api_get_xcode_stream : 4702
007131: Jan 17 16:21:04.158: //54158/9F4F475DBE8B/CCAPI/cc_api_bridge_done:
   Conference Id=0xCD2, Source Interface=0x873D58C8, Source Call Id=54158,
007132: Jan 17 16:21:04.158: //54155/9F4F475DBE8B/CCAPI/cc_generic_bridge_done:
007133: Jan 17 16:21:04.158: //54155/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xCD2, Destination Call Id=54158)
007134: Jan 17 16:21:04.162: //54158/9F4F475DBE8B/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xCD2, Destination Call Id=54155)
007135: Jan 17 16:21:04.162: //54156/9F4F475DBE8B/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
007136: Jan 17 16:21:04.162: //54156/9F4F475DBE8B/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
007137: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007138: Jan 17 16:21:04.162: :cc_get_feature_vsa malloc success
007139: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007140: Jan 17 16:21:04.162:  cc_get_feature_vsa count is 8
007141: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007142: Jan 17 16:21:04.162: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329770240,feature_id:18802
007143: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007144: Jan 17 16:21:04.162: :cc_free_feature_vsa freeing 8ADD78F8
007145: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007146: Jan 17 16:21:04.162:  vsacount in free is 7
007147: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007148: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007149: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007150: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007151: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007152: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007153: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007154: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007155: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007156: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007157: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007158: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007159: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007160: Jan 17 16:21:04.162: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
007161: Jan 17 16:21:04.162: //54155/9F4F475DBE8B/CCAPI/ccCallNotify:
007162: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007163: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007164: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007165: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007166: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007167: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007168: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007169: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007170: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007171: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007172: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007173: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007174: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007175: Jan 17 16:21:04.166: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
007176: Jan 17 16:21:04.166: //54155/9F4F475DBE8B/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=54155
007177: Jan 17 16:21:04.166: //54155/9F4F475DBE8B/CCAPI/ccCallResume:
   Call Id=54155
007178: Jan 17 16:21:04.170: //54155/9F4F475DBE8B/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xCD2, Call Id1=54155, Call Id2=54158
007179: Jan 17 16:21:04.170: //54158/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:501@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC661181
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007180: Jan 17 16:21:04.170: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:6141234567@67.205.74.164:5060 SIP/2.0
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC6621A49
To: "6141234567" <6141234567>;tag=as362cc109
Date: Thu, 17 Jan 2013 21:21:04 GMT
Call-ID: 457e7ab472485f234b58d9014570a976@67.205.74.164
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1358457664
Expires: 180
Content-Length: 225
v=0
o=CiscoSystemsSIP-GW-UserAgent 3752 890 IN IP4 66.166.166.22
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
007181: Jan 17 16:21:04.174: //54156/9F4F475DBE8B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x873D58C8, Tag=0x0, Call Id=54156,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
007182: Jan 17 16:21:04.174: //-1/9F4F475DBE8B/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
007183: Jan 17 16:21:04.174: //54156/9F4F475DBE8B/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
007184: Jan 17 16:21:04.174: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007185: Jan 17 16:21:04.174: :cc_free_feature_vsa freeing 8ADD6938
007186: Jan 17 16:21:04.174: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007187: Jan 17 16:21:04.174:  vsacount in free is 6
007188: Jan 17 16:21:04.174: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007189: Jan 17 16:21:04.174:  vsacount in free is 5
007190: Jan 17 16:21:04.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC6621A49;received=66.166.166.22
CSeq: 101 INVITE
User-Agent: VoIPMS/SERAST
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Contact: <6141234567>
Content-Length: 0
007191: Jan 17 16:21:04.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 242
v=0
o=root 15546 15547 IN IP4 67.205.74.164
s=session
c=IN IP4 67.205.74.164
t=0 0
m=audio 17532 RTP/AVP 0 101
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
007192: Jan 17 16:21:04.502: //54155/9F4F475DBE8B/CCAPI/cc_set_post_tagdata:
007193: Jan 17 16:21:04.502: //54155/9F4F475DBE8B/CCAPI/cc_api_caps_ind:
   Destination Interface=0x873D58C8, Destination Call Id=54158, Source Call Id=54155,
   Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
007194: Jan 17 16:21:04.502: //54155/9F4F475DBE8B/CCAPI/cc_api_caps_ind:
007195: Jan 17 16:21:04.502: //54158/9F4F475DBE8B/CCAPI/cc_api_caps_ack:
   Destination Interface=0x873D58C8, Destination Call Id=54155, Source Call Id=54158,
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9722)
007196: Jan 17 16:21:04.502: //54158/9F4F475DBE8B/CCAPI/cc_api_caps_ack:
007197: Jan 17 16:21:04.502: //54155/9F4F475DBE8B/CCAPI/cc_api_event_indication:
   Event=171, Call Id=54155
007198: Jan 17 16:21:04.502: //54155/9F4F475DBE8B/CCAPI/cc_api_event_indication:
007199: Jan 17 16:21:04.510: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:6141234567@67.205.74.164:5060 SIP/2.0
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC663C64
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007200: Jan 17 16:21:05.494: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 242
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
007201: Jan 17 16:21:05.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007202: Jan 17 16:21:06.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 242
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
007203: Jan 17 16:21:06.502: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007204: Jan 17 16:21:08.494: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 242
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
007205: Jan 17 16:21:08.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007206: Jan 17 16:21:12.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 242
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
007207: Jan 17 16:21:12.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007208: Jan 17 16:21:16.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 242
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
007209: Jan 17 16:21:16.498: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007210: Jan 17 16:21:20.499: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Content-Length: 242
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
007211: Jan 17 16:21:20.499: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007212: Jan 17 16:21:31.183:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF5D timestamp 0xF783ABCE
007213: Jan 17 16:21:31.183:  << Pt:101    Evt:1       Pkt:07 01 18
007214: Jan 17 16:21:31.183:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF5D timestamp 0xF783ABCE
007215: Jan 17 16:21:31.187:          Pt:101    Evt:1       Pkt:07 01 18  >>
007216: Jan 17 16:21:31.203:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF5E timestamp 0xF783ABCE
007217: Jan 17 16:21:31.203:  << Pt:101    Evt:1       Pkt:07 01 18
007218: Jan 17 16:21:31.203:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF5E timestamp 0xF783ABCE
007219: Jan 17 16:21:31.203:          Pt:101    Evt:1       Pkt:07 01 18  >>
007220: Jan 17 16:21:31.223:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF5F timestamp 0xF783ABCE
007221: Jan 17 16:21:31.223:  << Pt:101    Evt:1       Pkt:07 01 40
007222: Jan 17 16:21:31.223:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF5F timestamp 0xF783ABCE
007223: Jan 17 16:21:31.223:          Pt:101    Evt:1       Pkt:07 01 40  >>
007224: Jan 17 16:21:31.243:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF60 timestamp 0xF783ABCE
007225: Jan 17 16:21:31.243:  << Pt:101    Evt:1       Pkt:07 01 E0
007226: Jan 17 16:21:31.243:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF60 timestamp 0xF783ABCE
007227: Jan 17 16:21:31.243:          Pt:101    Evt:1       Pkt:07 01 E0  >>
007228: Jan 17 16:21:31.263:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF61 timestamp 0xF783ABCE
007229: Jan 17 16:21:31.263:  << Pt:101    Evt:1       Pkt:07 02 80
007230: Jan 17 16:21:31.263:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF61 timestamp 0xF783ABCE
007231: Jan 17 16:21:31.263:          Pt:101    Evt:1       Pkt:07 02 80  >>
007232: Jan 17 16:21:31.283:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF62 timestamp 0xF783ABCE
007233: Jan 17 16:21:31.283:  << Pt:101    Evt:1       Pkt:07 03 20
007234: Jan 17 16:21:31.283:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF62 timestamp 0xF783ABCE
007235: Jan 17 16:21:31.283:          Pt:101    Evt:1       Pkt:07 03 20  >>
007236: Jan 17 16:21:31.303:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF63 timestamp 0xF783ABCE
007237: Jan 17 16:21:31.303:  << Pt:101    Evt:1       Pkt:07 03 C0
007238: Jan 17 16:21:31.303:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF63 timestamp 0xF783ABCE
007239: Jan 17 16:21:31.303:          Pt:101    Evt:1       Pkt:07 03 C0  >>
007240: Jan 17 16:21:31.323:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF64 timestamp 0xF783ABCE
007241: Jan 17 16:21:31.323:  << Pt:101    Evt:1       Pkt:07 04 60
007242: Jan 17 16:21:31.323:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF64 timestamp 0xF783ABCE
007243: Jan 17 16:21:31.323:          Pt:101    Evt:1       Pkt:07 04 60  >>
007244: Jan 17 16:21:31.343:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF65 timestamp 0xF783ABCE
007245: Jan 17 16:21:31.343:  << Pt:101    Evt:1       Pkt:07 05 00
007246: Jan 17 16:21:31.343:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF65 timestamp 0xF783ABCE
007247: Jan 17 16:21:31.343:          Pt:101    Evt:1       Pkt:07 05 00  >>
007248: Jan 17 16:21:31.363:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF66 timestamp 0xF783ABCE
007249: Jan 17 16:21:31.363:  << Pt:101    Evt:1       Pkt:87 05 78
007250: Jan 17 16:21:31.363:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF66 timestamp 0xF783ABCE
007251: Jan 17 16:21:31.363:          Pt:101    Evt:1       Pkt:87 05 78  >>
007252: Jan 17 16:21:31.383:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF67 timestamp 0xF783ABCE
007253: Jan 17 16:21:31.383:  << Pt:101    Evt:1       Pkt:87 05 78
007254: Jan 17 16:21:31.383:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF67 timestamp 0xF783ABCE
007255: Jan 17 16:21:31.383:          Pt:101    Evt:1       Pkt:87 05 78  >>
007256: Jan 17 16:21:31.403:          s=VoIP d=DSP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF68 timestamp 0xF783ABCE
007257: Jan 17 16:21:31.403:  << Pt:101    Evt:1       Pkt:87 05 78
007258: Jan 17 16:21:31.403:          s=DSP d=VoIP payload 0x65 ssrc 0x26BE5D2A sequence 0xDF68 timestamp 0xF783ABCE
007259: Jan 17 16:21:31.403:          Pt:101    Evt:1       Pkt:87 05 78  >>
007260: Jan 17 16:21:44.171: //54161/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:montreal.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC664EB9
To:
Date: Thu, 17 Jan 2013 21:21:44 GMT
Call-ID: BA15C28E-602211E2-BE94B229-7E69AAE1@voip.ms
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <66.166.166.22:5060>
Content-Length: 0
007261: Jan 17 16:21:44.703: //54162/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC665776
To:
Call-ID: BA66EEA4-602211E2-BE95B229-7E69AAE1@voip.ms
Max-Forwards: 70
CSeq: 101 OPTIONS
Content-Length: 0
007262: Jan 17 16:21:44.999: //54162/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC665776;received=66.166.166.22
To: ;tag=as3a8c1624
CSeq: 101 OPTIONS
Supported: replaces
Contact: <67.205.74.164>
Accept: application/sdp
Content-Length: 0
007263: Jan 17 16:22:00.348: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:9154441234@66.166.166.22:56192 SIP/2.0
Via: SIP/2.0/UDP 67.205.74.164:5060;branch=z9hG4bK4919ed8f;rport
To: <9154441234>
Call-ID: 06b05c4466f817b0205094ff11124bcc@67.205.74.164
CSeq: 102 INVITE
Max-Forwards: 70
Remote-Party-ID: "6141234567" <6141234567>;privacy=off;screen=no
Date: Thu, 17 Jan 2013 21:22:40 GMT
Supported: replaces
Content-Length: 242
v=0
o=root 15546 15546 IN IP4 67.205.74.164
s=session
t=0 0
m=audio 12502 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
007264: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=9154441234, Called Number=9154441234, Peer Info Type=DIALPEER_INFO_SPEECH
007265: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=9154441234
007266: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=9154441234, Expanded String=9154441234, Calling Number=9154441234T
007267: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=20002 Is Matched
007268: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007269: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=9154441234, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
007270: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=20002
007271: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6141234567, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
007272: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=6141234567
007273: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
007274: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=6141234567T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
007275: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007276: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007277: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=6141234567
007278: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007279: Jan 17 16:22:00.352: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007280: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007281: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007282: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
007283: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007284: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007285: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007286: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007287: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007288: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007289: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007290: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007291: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007292: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007293: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007294: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007295: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007296: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007297: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007298: Jan 17 16:22:00.356: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007299: Jan 17 16:22:00.356: //-1/C3BB522CBE96/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6141234567, Called Number=9154441234, Voice-Interface=0x0,
007300: Jan 17 16:22:00.356: //-1/C3BB522CBE96/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_VIA_URI; URI=sip:67.205.74.164:5060
007301: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:
007302: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
007303: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
   Result=-1
007304: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:exit@5985
007305: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_REQUEST_URI; URI=sip:9154441234@66.166.166.22:56192
007306: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:
007307: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
007308: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
   Result=-1
007309: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:exit@5985
007310: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_TO_URI; URI=sip:9154441234@66.166.166.22:56192
007311: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:
007312: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
007313: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
   Result=-1
007314: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:exit@5985
007315: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_FROM_URI; URI=sip:6141234567@67.205.74.164
007316: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:
007317: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
007318: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
   Result=-1
007319: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:exit@5985
007320: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=9154441234
007321: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:
007322: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchCore:
007323: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=6 Is Matched
007324: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1000 Is Matched
007325: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=3004 Is Matched
007326: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchPeertype:exit@5985
007327: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=3004
007328: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpMatchSafModulePlugin:
007329: Jan 17 16:22:00.360: //-1/C3BB522CBE96/DPM/dpAssociateIncomingPeerSPI:exit@6564
007330: Jan 17 16:22:00.364: //-1/xxxxxxxxxxxx/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Set Is Failed
007331: Jan 17 16:22:00.364: //-1/C3BB522CBE96/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=6141234567
   ----- ccCallInfo IE subfields -----
   cisco-ani=6141234567
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=9154441234
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
007332: Jan 17 16:22:00.364: //-1/C3BB522CBE96/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x873D58C8, Call Info(
   Calling Number=6141234567,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=9154441234(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3004, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=54163
007333: Jan 17 16:22:00.364: //-1/C3BB522CBE96/CCAPI/ccCheckClipClir:
   In: Calling Number=6141234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007334: Jan 17 16:22:00.364: //-1/C3BB522CBE96/CCAPI/ccCheckClipClir:
   Out: Calling Number=6141234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
007335: Jan 17 16:22:00.364: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007336: Jan 17 16:22:00.364: :cc_get_feature_vsa malloc success
007337: Jan 17 16:22:00.364: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007338: Jan 17 16:22:00.364:  cc_get_feature_vsa count is 6
007339: Jan 17 16:22:00.364: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007340: Jan 17 16:22:00.364: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329772256,feature_id:18803
007341: Jan 17 16:22:00.364: //54163/C3BB522CBE96/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=6141234567(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=9154441234(TON=Unknown, NPI=Unknown))
007342: Jan 17 16:22:00.364: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD3C764; count=1
007343: Jan 17 16:22:00.364: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E205A8
007344: Jan 17 16:22:00.368: //54163/C3BB522CBE96/CCAPI/cc_process_call_setup_ind:
   Event=0x884C8708
007345: Jan 17 16:22:00.368: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=9154441234, Peer Info Type=DIALPEER_INFO_SPEECH
007346: Jan 17 16:22:00.368: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007347: Jan 17 16:22:00.368: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007348: Jan 17 16:22:00.368: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007349: Jan 17 16:22:00.368: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007350: Jan 17 16:22:00.368: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=9154441234, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
007351: Jan 17 16:22:00.368: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007352: Jan 17 16:22:00.368: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 9154441234
007353: Jan 17 16:22:00.368: //54163/C3BB522CBE96/CCAPI/ccCallSetContext:
   Context=0x8ADFE1E4
007354: Jan 17 16:22:00.368: //54163/C3BB522CBE96/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 54163 with tag 3004 to app "_ManagedAppProcess_Default"
007355: Jan 17 16:22:00.368: //-1/C3BB522CBE96/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD3C764; count=1
007356: Jan 17 16:22:00.368: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number=6141234567 type=unknown plan=unknown numbertype=calling
007357: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_get_RegXrule: Translation ruleset with tag=3265 doesn't exist
007358: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
007359: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: No match: number=6141234567 type=unknown plan=unknown
007360: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
007361: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007362: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Error: ruleset for redirect-called number not found
007363: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: No match: number= type=unknown plan=unknown
007364: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number=9154441234 type=unknown plan=unknown numbertype=called
007365: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 8
007366: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Matched with rule 1 in ruleset 8
007367: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/sed_subst: Successful substitution; pattern=9154441234 matchPattern=9154441234 replacePattern=500 replaced pattern=500
007368: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
007369: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
007370: Jan 17 16:22:00.372: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: xlt_number=500 xlt_type=unknown xlt_plan=unknown
007371: Jan 17 16:22:00.372: //54163/C3BB522CBE96/CCAPI/ccCallProceeding:
007372: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=500, Peer Info Type=DIALPEER_INFO_SPEECH
007373: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=500
007374: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchCore:
   Dial String=500, Expanded String=500, Calling Number=
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
007375: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2001 Is Matched
007376: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007377: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchSafModulePlugin:
   dialstring=500, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
007378: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2001
007379: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007380: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007381: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchCore:
007382: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/MatchNextPeer:
007383: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007384: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchSafModulePlugin:
007385: Jan 17 16:22:00.372: //-1/C3BB522CBE96/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007386: Jan 17 16:22:00.372: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=500, Called Number=500, Peer Info Type=DIALPEER_INFO_SPEECH
007387: Jan 17 16:22:00.372: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007388: Jan 17 16:22:00.372: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=500, Expanded String=500, Calling Number=500T
007389: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007390: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007391: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007392: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007393: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=500, Called Number=, Voice-Interface=0x0,
007394: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=500
007395: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007396: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=500T
007397: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007398: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007399: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=500
007400: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007401: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007402: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=2001 Is Matched
007403: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007404: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2001
007405: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007406: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007407: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007408: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007409: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007410: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007411: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007412: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007413: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007414: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007415: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007416: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007417: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007418: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007419: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007420: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007421: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007422: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007423: Jan 17 16:22:00.376: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007424: Jan 17 16:22:00.380: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007425: Jan 17 16:22:00.380: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007426: Jan 17 16:22:00.380: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007427: Jan 17 16:22:00.380: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007428: Jan 17 16:22:00.380: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007429: Jan 17 16:22:00.380: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007430: Jan 17 16:22:00.380: //-1/C3BB522CBE96/DPM/dpMatchCore:
007431: Jan 17 16:22:00.380: //-1/C3BB522CBE96/DPM/MatchNextPeer:
007432: Jan 17 16:22:00.380: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007433: Jan 17 16:22:00.380: //-1/C3BB522CBE96/DPM/dpMatchSafModulePlugin:
   dialstring=500, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
007434: Jan 17 16:22:00.380: //-1/C3BB522CBE96/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007435: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
007436: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number=6141234567 type=unknown plan=unknown numbertype=calling
007437: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007438: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
007439: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: No match: number=6141234567 type=unknown plan=unknown
007440: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number=500 type=unknown plan=unknown numbertype=called
007441: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007442: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
007443: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: No match: number=500 type=unknown plan=unknown
007444: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
007445: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
007446: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
007447: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
007448: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_rule_match: partial match found, partial_match 15
007449: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
007450: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: partial match found
007451: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-called
007452: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
007453: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
007454: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
007455: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_rule_match: partial match found, partial_match 15
007456: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
007457: Jan 17 16:22:00.380: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: partial match found
007458: Jan 17 16:22:00.380: //54163/C3BB522CBE96/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=2001, Params=0x8ADF12B4, Progress Indication=NULL(0)
007459: Jan 17 16:22:00.380: //54163/C3BB522CBE96/CCAPI/ccCheckClipClir:
007460: Jan 17 16:22:00.384: //54163/C3BB522CBE96/CCAPI/ccCheckClipClir:
007461: Jan 17 16:22:00.384: //54163/C3BB522CBE96/CCAPI/ccCallSetupRequest:
   Destination Pattern=500, Called Number=500, Digit Strip=FALSE
007462: Jan 17 16:22:00.384: //54163/C3BB522CBE96/CCAPI/ccCallSetupRequest:
   Called Number=500(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=6141234567
   Account Number=6141234567, Final Destination Flag=TRUE,
   Guid=C3BB522C-6022-11E2-BE96-B2297E69AAE1, Outgoing Dial-peer=2001
007463: Jan 17 16:22:00.384: //54163/C3BB522CBE96/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=500
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
007464: Jan 17 16:22:00.384: //54163/C3BB522CBE96/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x873D58C8, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=6141234567,(Calling Name=6141234567)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=500(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
007465: Jan 17 16:22:00.384: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007466: Jan 17 16:22:00.384: :cc_get_feature_vsa malloc success
007467: Jan 17 16:22:00.384: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007468: Jan 17 16:22:00.384:  cc_get_feature_vsa count is 7
007469: Jan 17 16:22:00.384: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007470: Jan 17 16:22:00.384: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329766208,feature_id:18804
007471: Jan 17 16:22:00.384: //54164/C3BB522CBE96/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
007472: Jan 17 16:22:00.384: //54164/C3BB522CBE96/CCAPI/ccCallSetContext:
   Context=0x8ADF1264
007473: Jan 17 16:22:00.384: //54163/C3BB522CBE96/CCAPI/ccSaveDialpeerTag:
007474: Jan 17 16:22:00.388: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD3C764; count=1
007475: Jan 17 16:22:00.388: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E205A8
007476: Jan 17 16:22:00.388: //-1/C3BB522CBE96/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD3C764; count=1
007477: Jan 17 16:22:00.388: //54164/C3BB522CBE96/CCAPI/cc_api_call_proceeding:
   Interface=0x873D58C8, Progress Indication=NULL(0)
007478: Jan 17 16:22:00.392: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <9154441234>
Date: Thu, 17 Jan 2013 21:22:00 GMT
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
007479: Jan 17 16:22:00.392: //54164/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:500@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC666F64
From: "6141234567" <>6141234567@montreal.voip.ms>;tag=93B66BE8-1490
To: <500>
Call-ID: C3C0D0C5-602211E2-BE9CB229-7E69AAE1@voip.ms
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3283833388-1612845538-3197547049-2120854241
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1358457720
Expires: 180
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 218
v=0
o=CiscoSystemsSIP-GW-UserAgent 8116 9092 IN IP4 10.1.10.2
s=SIP Call
t=0 0
m=audio 19520 RTP/AVP 0 101
c=IN IP4 10.1.10.2
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
007480: Jan 17 16:22:00.400: //54164/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <500>
CSeq: 101 INVITE
Content-Length: 0
007481: Jan 17 16:22:00.476: //54164/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <500>;tag=dsf3741a3b
CSeq: 101 INVITE
Content-Length: 0
Contact: <500>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: C3C0D0C5-602211E2-BE9CB229-7E69AAE1@voip.ms
007482: Jan 17 16:22:00.476: //54164/C3BB522CBE96/CCAPI/cc_api_call_alert:
   Interface=0x873D58C8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
007483: Jan 17 16:22:00.476: //54164/C3BB522CBE96/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
007484: Jan 17 16:22:00.480: //54163/C3BB522CBE96/CCAPI/ccCallAlert:
007485: Jan 17 16:22:00.480: //54163/C3BB522CBE96/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
007486: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6141234567, Peer Info Type=DIALPEER_INFO_SPEECH
007487: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=6141234567
007488: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=6141234567, Expanded String=6141234567, Calling Number=
007489: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007490: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
007491: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007492: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007493: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007494: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007495: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007496: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007497: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007498: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007499: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007500: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007501: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007502: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007503: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007504: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007505: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
007506: Jan 17 16:22:00.480: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007507: Jan 17 16:22:00.484: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <9154441234>;tag=93B66C44-7FD
CSeq: 102 INVITE
Contact: <500>
Content-Length: 0
007508: Jan 17 16:22:00.528: //54164/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 183
Contact: <500>
v=0
o=CUE 6540885 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 20586 RTP/AVP 0 101
a=fmtp:101 0-15
007509: Jan 17 16:22:00.532: //54164/C3BB522CBE96/CCAPI/cc_set_post_tagdata:
   CALL_ERROR; Avlist Removal Is Failed
007510: Jan 17 16:22:00.532: //54164/C3BB522CBE96/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=54164,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
007511: Jan 17 16:22:00.532: //54164/C3BB522CBE96/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
007512: Jan 17 16:22:00.532: //54163/C3BB522CBE96/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=54164, Source Call Id=54163,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
007513: Jan 17 16:22:00.532: //54163/C3BB522CBE96/CCAPI/cc_api_caps_ack:
007514: Jan 17 16:22:00.536: //54164/C3BB522CBE96/CCAPI/cc_api_event_indication:
   Event=171, Call Id=54164
007515: Jan 17 16:22:00.536: //54164/C3BB522CBE96/CCAPI/cc_api_event_indication:
   Event Is Sent To Conferenced SPI(s) Directly
007516: Jan 17 16:22:00.536: //54164/C3BB522CBE96/CCAPI/cc_api_call_connected:
   Interface=0x873D58C8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
007517: Jan 17 16:22:00.536: //54164/C3BB522CBE96/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
007518: Jan 17 16:22:00.540: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
   (confID=0x8963F42C, callID1=0xD393, gcid=C3BC8B14-602211E2-BE99B229-7E69AAE1, tag=0x0)
007519: Jan 17 16:22:00.540: //54164/C3BB522CBE96/CCAPI/ccConferenceCreate:
   (confID=0x8963F42C, callID2=0xD394, gcid=C3BC8B14-602211E2-BE99B229-7E69AAE1, tag=0x0)
007520: Jan 17 16:22:00.540: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
   Conference Id=0x8963F42C, Call Id1=54163, Call Id2=54164, Tag=0x0
007521: Jan 17 16:22:00.540: //54163/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007522: Jan 17 16:22:00.540: cc_api_get_xcode_stream : 4702
007523: Jan 17 16:22:00.540: //54164/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007524: Jan 17 16:22:00.540: cc_api_get_xcode_stream : 4702
007525: Jan 17 16:22:00.540: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
007526: Jan 17 16:22:00.540: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
007527: Jan 17 16:22:00.540: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
   delay media to slow start case, codec negotation is not done
007528: Jan 17 16:22:00.540: //54163/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007529: Jan 17 16:22:00.540: cc_api_get_xcode_stream : 4702
007530: Jan 17 16:22:00.540: //54163/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007531: Jan 17 16:22:00.540: cc_api_get_xcode_stream : 4702
007532: Jan 17 16:22:00.540: //54163/C3BB522CBE96/CCAPI/cc_api_bridge_done:
   Conference Id=0xCD3, Source Interface=0x873D58C8, Source Call Id=54163,
   Destination Call Id=54164, Disposition=0x0, Tag=0x0
007533: Jan 17 16:22:00.540: //54164/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007534: Jan 17 16:22:00.540: cc_api_get_xcode_stream : 4702
007535: Jan 17 16:22:00.540: //54164/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007536: Jan 17 16:22:00.540: cc_api_get_xcode_stream : 4702
007537: Jan 17 16:22:00.540: //54164/C3BB522CBE96/CCAPI/cc_api_bridge_done:
   Conference Id=0xCD3, Source Interface=0x873D58C8, Source Call Id=54164,
   Destination Call Id=54163, Disposition=0x0, Tag=0x0
007538: Jan 17 16:22:00.540: //54163/C3BB522CBE96/CCAPI/cc_generic_bridge_done:
007539: Jan 17 16:22:00.540: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xCD3, Destination Call Id=54164)
007540: Jan 17 16:22:00.540: //54164/C3BB522CBE96/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xCD3, Destination Call Id=54163)
007541: Jan 17 16:22:00.544: //54163/C3BB522CBE96/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xCD3, Call Id1=54163, Call Id2=54164
007542: Jan 17 16:22:00.544: //54164/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:500@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC6671456
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007543: Jan 17 16:22:00.544: //54163/C3BB522CBE96/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
007544: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007545: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007546: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007547: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007548: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007549: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
007550: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007551: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007552: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007553: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007554: Jan 17 16:22:00.544: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007555: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007556: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007557: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007558: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007559: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007560: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007561: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007562: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007563: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007564: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007565: Jan 17 16:22:00.548: //54163/C3BB522CBE96/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
007566: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007567: Jan 17 16:22:00.548: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007568: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007569: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007570: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007571: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007572: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007573: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007574: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007575: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007576: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007577: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007578: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007579: Jan 17 16:22:00.552: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007580: Jan 17 16:22:00.552: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: <9154441234>
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 226
v=0
o=CiscoSystemsSIP-GW-UserAgent 4972 4348 IN IP4 66.166.166.22
s=SIP Call
t=0 0
m=audio 16418 RTP/AVP 0 101
c=IN IP4 66.166.166.22
a=fmtp:101 0-16
a=ptime:20
007581: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007582: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007583: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007584: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007585: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007586: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007587: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007588: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007589: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007590: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007591: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007592: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007593: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007594: Jan 17 16:22:00.652: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007595: Jan 17 16:22:00.656: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
007596: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007597: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007598: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007599: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007600: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007601: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007602: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007603: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007604: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007605: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007606: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007607: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
007608: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007609: Jan 17 16:22:00.852: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007610: Jan 17 16:22:00.856: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
007611: Jan 17 16:22:01.088: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:9154441234@66.166.166.22:5060 SIP/2.0
Via: SIP/2.0/UDP 67.205.74.164:5060;branch=z9hG4bK6a15621d;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
007612: Jan 17 16:22:04.564:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB01E timestamp 0x71C4673F
007613: Jan 17 16:22:04.564:  << Pt:101    Evt:1       Pkt:07 01 18
007614: Jan 17 16:22:04.564:          s=DSP d=VoIP payload 0x65 ssrc 0x25A71AFA sequence 0xB01E timestamp 0x71C4673F
007615: Jan 17 16:22:04.564:          Pt:101    Evt:1       Pkt:07 01 18  >>
007616: Jan 17 16:22:04.584:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB01F timestamp 0x71C4673F
007617: Jan 17 16:22:04.584:  << Pt:101    Evt:1       Pkt:07 01 18
007618: Jan 17 16:22:04.584:          s=DSP d=VoIP payload 0x65 ssrc 0x25A71AFA sequence 0xB01F timestamp 0x71C4673F
007619: Jan 17 16:22:04.584:          Pt:101    Evt:1       Pkt:07 01 18  >>
007620: Jan 17 16:22:04.604:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB020 timestamp 0x71C4673F
007621: Jan 17 16:22:04.604:  << Pt:101    Evt:1       Pkt:07 01 40
007622: Jan 17 16:22:04.604:          s=DSP d=VoIP payload 0x65 ssrc 0x25A71AFA sequence 0xB020 timestamp 0x71C4673F
007623: Jan 17 16:22:04.604:          Pt:101    Evt:1       Pkt:07 01 40  >>
007624: Jan 17 16:22:04.624:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB021 timestamp 0x71C4673F
007625: Jan 17 16:22:04.624:  << Pt:101    Evt:1       Pkt:07 01 E0
007626: Jan 17 16:22:04.624:          s=DSP d=VoIP payload 0x65 ssrc 0x25A71AFA sequence 0xB021 timestamp 0x71C4673F
007627: Jan 17 16:22:04.624:          Pt:101    Evt:1       Pkt:07 01 E0  >>
007628: Jan 17 16:22:04.644:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB022 timestamp 0x71C4673F
007629: Jan 17 16:22:04.644:  << Pt:101    Evt:1       Pkt:07 02 80
007630: Jan 17 16:22:04.644:          s=DSP d=VoIP payload 0x65 ssrc 0x25A71AFA sequence 0xB022 timestamp 0x71C4673F
007631: Jan 17 16:22:04.644:          Pt:101    Evt:1       Pkt:07 02 80  >>
007632: Jan 17 16:22:04.664:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB023 timestamp 0x71C4673F
007633: Jan 17 16:22:04.664:  << Pt:101    Evt:1       Pkt:07 03 20
007634: Jan 17 16:22:04.664:          s=DSP d=VoIP payload 0x65 ssrc 0x25A71AFA sequence 0xB023 timestamp 0x71C4673F
007635: Jan 17 16:22:04.664:          Pt:101    Evt:1       Pkt:07 03 20  >>
007636: Jan 17 16:22:04.684:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB024 timestamp 0x71C4673F
007637: Jan 17 16:22:04.684:  << Pt:101    Evt:1       Pkt:07 03 C0
007638: Jan 17 16:22:04.684:          s=DSP d=VoIP payload 0x65 ssrc 0x25A71AFA sequence 0xB024 timestamp 0x71C4673F
007639: Jan 17 16:22:04.684:          Pt:101    Evt:1       Pkt:07 03 C0  >>
007640: Jan 17 16:22:04.704:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB025 timestamp 0x71C4673F
007641: Jan 17 16:22:04.704:  << Pt:101    Evt:1       Pkt:07 04 60
007642: Jan 17 16:22:04.704:          s=DSP d=VoIP payload 0x65 ssrc 0x25A71AFA sequence 0xB025 timestamp 0x71C4673F
007643: Jan 17 16:22:04.704:          Pt:101    Evt:1       Pkt:07 04 60  >>
007644: Jan 17 16:22:04.704: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:6141234567@10.1.10.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.1:5060;branch=z9hG4bKMs1hd7eCNa1bce5HT01qyA~~1068
Max-Forwards: 70
To: <>6141234567@montreal.voip.ms>;tag=93B66BE8-1490
CSeq: 1 BYE
Content-Length: 0
Also: <501>
007645: Jan 17 16:22:04.708: //54163/C3BB522CBE96/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=54163
007646: Jan 17 16:22:04.708: //54164/C3BB522CBE96/CCAPI/cc_api_call_facility:
   Interface=0x873D58C8, Call Id=54164
007647: Jan 17 16:22:04.708: //54164/C3BB522CBE96/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
007648: Jan 17 16:22:04.708: //54163/C3BB522CBE96/CCAPI/ccConferenceDestroy:
   Conference Id=0xCD3, Tag=0x0
007649: Jan 17 16:22:04.708: //54163/C3BB522CBE96/CCAPI/cc_api_bridge_drop_done:
007650: Jan 17 16:22:04.708: //54164/C3BB522CBE96/CCAPI/cc_api_bridge_drop_done:
007651: Jan 17 16:22:04.708: //54163/C3BB522CBE96/CCAPI/cc_generic_bridge_done:
007652: Jan 17 16:22:04.708: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007653: Jan 17 16:22:04.708: :cc_get_feature_vsa malloc success
007654: Jan 17 16:22:04.708: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007655: Jan 17 16:22:04.708:  cc_get_feature_vsa count is 8
007656: Jan 17 16:22:04.708: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007657: Jan 17 16:22:04.708: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329770240,feature_id:18805
007658: Jan 17 16:22:04.708: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007659: Jan 17 16:22:04.708:  feature_vsa is 8ADD6938,featname is 0
007660: Jan 17 16:22:04.708: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007661: Jan 17 16:22:04.708: :cc_get_feature_vsa malloc success
007662: Jan 17 16:22:04.708: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007663: Jan 17 16:22:04.708:  cc_get_feature_vsa count is 9
007664: Jan 17 16:22:04.708: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007665: Jan 17 16:22:04.712: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329774048,feature_id:18806
007666: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007667: Jan 17 16:22:04.712: : Generating new featurevsa,inserting it
007668: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007669: Jan 17 16:22:04.712:  feature call forward featname is 4
007670: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007671: Jan 17 16:22:04.712:  feature_vsa is 8ADD80D8,featname is 0
007672: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007673: Jan 17 16:22:04.712: :cc_get_feature_vsa malloc success
007674: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007675: Jan 17 16:22:04.712:  cc_get_feature_vsa count is 10
007676: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007677: Jan 17 16:22:04.712: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329768224,feature_id:18807
007678: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007679: Jan 17 16:22:04.712: : Generating new featurevsa,inserting it
007680: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007681: Jan 17 16:22:04.712:  feature call forward featname is 4
007682: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007683: Jan 17 16:22:04.712: :cc_free_feature_vsa freeing 8ADD78F8
007684: Jan 17 16:22:04.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007685: Jan 17 16:22:04.712:  vsacount in free is 9
007686: Jan 17 16:22:04.712: //54164/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "6141234567" <>6141234567@montreal.voip.ms>;tag=93B66BE8-1490
Date: Thu, 17 Jan 2013 21:22:04 GMT
CSeq: 1 BYE
P-RTP-Stat: PS=174,OS=26592,PR=203,OR=32162,PL=0,JI=0,LA=0,DU=4
Content-Length: 0
007687: Jan 17 16:22:04.712: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=501, Peer Info Type=DIALPEER_INFO_SPEECH
007688: Jan 17 16:22:04.712: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=501
007689: Jan 17 16:22:04.712: //-1/C3BB522CBE96/DPM/dpMatchCore:
   Dial String=501, Expanded String=501, Calling Number=
007690: Jan 17 16:22:04.716: //-1/C3BB522CBE96/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=2006 Is Matched
007691: Jan 17 16:22:04.716: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
007692: Jan 17 16:22:04.716: //-1/C3BB522CBE96/DPM/dpMatchSafModulePlugin:
   dialstring=501, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
007693: Jan 17 16:22:04.716: //-1/C3BB522CBE96/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=2006
007694: Jan 17 16:22:04.716: //54163/C3BB522CBE96/CCAPI/ccSaveDialpeerTag:
   Outgoing Dial-peer=0
007695: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007696: Jan 17 16:22:04.716: :cc_get_feature_vsa malloc success
007697: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007698: Jan 17 16:22:04.716:  cc_get_feature_vsa count is 10
007699: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007700: Jan 17 16:22:04.716: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329770240,feature_id:18808
007701: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007702: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007703: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007704: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007705: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007706: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007707: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007708: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007709: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007710: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007711: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007712: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007713: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007714: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
007715: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007716: Jan 17 16:22:04.716: : updating existing feature vsa
007717: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
007718: Jan 17 16:22:04.716:  feature call forward featname is 4
007719: Jan 17 16:22:04.716: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007720: Jan 17 16:22:04.720: :cc_free_feature_vsa freeing 8ADD78F8
007721: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007722: Jan 17 16:22:04.720:  vsacount in free is 9
007723: Jan 17 16:22:04.720: //54163/C3BB522CBE96/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
007724: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007725: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007726: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007727: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007728: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007729: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007730: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007731: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007732: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007733: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007734: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007735: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007736: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007737: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007738: Jan 17 16:22:04.720: //54163/C3BB522CBE96/CCAPI/ccCallResume:
   Call Id=54163
007739: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=501, Called Number=, Voice-Interface=0x0,
007740: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=501
007741: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007742: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=501T
007743: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007744: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007745: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=501
007746: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
007747: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007748: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=2006 Is Matched
007749: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
007750: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2006
007751: Jan 17 16:22:04.720: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007752: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
007753: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007754: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007755: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007756: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007757: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007758: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007759: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007760: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007761: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007762: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007763: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007764: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007765: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007766: Jan 17 16:22:04.724: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007767: Jan 17 16:22:04.724: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007768: Jan 17 16:22:04.724: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007769: Jan 17 16:22:04.724: //-1/C3BB522CBE96/DPM/dpMatchCore:
007770: Jan 17 16:22:04.724: //-1/C3BB522CBE96/DPM/MatchNextPeer:
007771: Jan 17 16:22:04.724: //-1/C3BB522CBE96/DPM/dpMatchPeersCore:
007772: Jan 17 16:22:04.724: //-1/C3BB522CBE96/DPM/dpMatchSafModulePlugin:
   dialstring=501, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
007773: Jan 17 16:22:04.724: //-1/C3BB522CBE96/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
007774: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_translate_exist_internal: no rule for callback-number number
007775: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number=6141234567 type=unknown plan=unknown numbertype=calling
007776: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007777: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Error: ruleset for calling number not found
007778: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: No match: number=6141234567 type=unknown plan=unknown
007779: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number=501 type=unknown plan=unknown numbertype=called
007780: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
007781: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Error: ruleset for called number not found
007782: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: No match: number=501 type=unknown plan=unknown
007783: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number= type=unknown plan=unknown numbertype=redirect-target
007784: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=1
007785: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=2
007786: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: more digits needed; number= rule precedence=15
007787: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_rule_match: partial match found, partial_match 15
007788: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: partial match found with rule 15 ruleset 410
007789: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: partial match found
007790: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: number=500 type=unknown plan=unknown numbertype=redirect-called
007791: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: No match; number=500 rule precedence=1
007792: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: No match; number=500 rule precedence=2
007793: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 410
007794: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: No match; number=500 rule precedence=1
007795: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: No match; number=500 rule precedence=2
007796: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_match_internal: Matched with rule 15 in ruleset 410
007797: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: No match; number=500 rule precedence=1
007798: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_match: No match; number=500 rule precedence=2
007799: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/sed_subst: Successful substitution; pattern=500 matchPattern=^...$ replacePattern=9154441234 replaced pattern=9154441234
007800: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = unknown
007801: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = unknown
007802: Jan 17 16:22:04.728: //-1/C3BB522CBE96/RXRULE/regxrule_profile_translate_internal: xlt_number=9154441234 xlt_type=unknown xlt_plan=unknown
007803: Jan 17 16:22:04.728: //54163/C3BB522CBE96/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2006, Params=0x8ADF2774, Progress Indication=NULL(0)
007804: Jan 17 16:22:04.728: //54163/C3BB522CBE96/CCAPI/ccCheckClipClir:
007805: Jan 17 16:22:04.728: //54163/C3BB522CBE96/CCAPI/ccCheckClipClir:
007806: Jan 17 16:22:04.728: //54163/C3BB522CBE96/CCAPI/ccCallSetupRequest:
   Destination Pattern=501, Called Number=501, Digit Strip=FALSE
007807: Jan 17 16:22:04.728: //54163/C3BB522CBE96/CCAPI/ccCallSetupRequest:
   Called Number=501(TON=Unknown, NPI=Unknown),
   Guid=C3BB522C-6022-11E2-BE96-B2297E69AAE1, Outgoing Dial-peer=2006
007808: Jan 17 16:22:04.728: //54163/C3BB522CBE96/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=501
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=9154441234
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
007809: Jan 17 16:22:04.728: //54163/C3BB522CBE96/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=501(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2006, Call Count On=FALSE,
007810: Jan 17 16:22:04.728: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007811: Jan 17 16:22:04.728: :cc_get_feature_vsa malloc success
007812: Jan 17 16:22:04.728: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007813: Jan 17 16:22:04.728:  cc_get_feature_vsa count is 10
007814: Jan 17 16:22:04.728: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007815: Jan 17 16:22:04.728: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329770240,feature_id:18809
007816: Jan 17 16:22:04.732: //54166/C3BB522CBE96/CCAPI/ccIFCallSetupRequestPrivate:
007817: Jan 17 16:22:04.732: //54166/C3BB522CBE96/CCAPI/ccCallSetContext:
   Context=0x8ADF2724
007818: Jan 17 16:22:04.732: //54163/C3BB522CBE96/CCAPI/ccSaveDialpeerTag:
007819: Jan 17 16:22:04.736: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD3C764; count=1
007820: Jan 17 16:22:04.736: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E205A8
007821: Jan 17 16:22:04.736: //-1/C3BB522CBE96/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x8AD3C764; count=1
007822: Jan 17 16:22:04.736: //54166/C3BB522CBE96/CCAPI/cc_api_call_proceeding:
007823: Jan 17 16:22:04.744: //54166/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:501@10.1.10.1:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC6681DC8
From: "6141234567" <>6141234567@montreal.voip.ms>;tag=93B67CE4-159C
To: <501>
Call-ID: C65848DD-602211E2-BE9EB229-7E69AAE1@voip.ms
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-12.x
CSeq: 101 INVITE
Timestamp: 1358457724
Contact: <6141234567>
Expires: 180
Max-Forwards: 69
Content-Length: 218
v=0
o=CiscoSystemsSIP-GW-UserAgent 4240 9061 IN IP4 10.1.10.2
s=SIP Call
t=0 0
m=audio 18212 RTP/AVP 0 101
c=IN IP4 10.1.10.2
a=fmtp:101 0-16
a=ptime:20
007824: Jan 17 16:22:04.744:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB027 timestamp 0x71C4673F
007825: Jan 17 16:22:04.744:  << Pt:101    Evt:1       Pkt:87 05 00
007826: Jan 17 16:22:04.748: //54166/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <501>
CSeq: 101 INVITE
Content-Length: 0
007827: Jan 17 16:22:04.784:          s=VoIP d=DSP payload 0x65 ssrc 0x25A71AFA sequence 0xB028 timestamp 0x71C4673F
007828: Jan 17 16:22:04.784:  << Pt:101    Evt:1       Pkt:87 05 00
007829: Jan 17 16:22:04.796: //54166/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <501>;tag=dscaa62b19
CSeq: 101 INVITE
Content-Length: 0
Contact: <501>
Cisco-Gcid: C65848DD-602211E2-BE9EB229-7E69AAE1@voip.ms
007830: Jan 17 16:22:04.796: //54166/C3BB522CBE96/CCAPI/cc_api_call_alert:
007831: Jan 17 16:22:04.796: //54166/C3BB522CBE96/CCAPI/cc_api_call_alert:
007832: Jan 17 16:22:04.796: //54163/C3BB522CBE96/CCAPI/ccAssociateStream:
   Coder=5, DTMF Relay=1, Vad=0,
   Record Function=0x0, Event Queue=0x8815FB68, Stream Context=8B022148,
   Record Context=0x0, Stream Call Id=54167, Call Id=54163
007833: Jan 17 16:22:04.796: //54163/C3BB522CBE96/CCAPI/ccAssociateStream:
   Call Entry(Stream Status=2, Digit Enable=FALSE)
007834: Jan 17 16:22:04.796: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007835: Jan 17 16:22:04.796: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007836: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007837: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007838: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007839: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007840: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007841: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007842: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007843: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007844: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007845: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007846: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007847: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
007848: Jan 17 16:22:04.800: //54163/C3BB522CBE96/CCAPI/ccCallNotify:
   Data Bitmask=0x17, Call Id=54163
007849: Jan 17 16:22:04.800: //54164/C3BB522CBE96/CCAPI/ccCallFacility:
   Call Id=54164
007850: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007851: Jan 17 16:22:04.800: :cc_get_feature_vsa malloc success
007852: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007853: Jan 17 16:22:04.800:  cc_get_feature_vsa count is 11
007854: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007855: Jan 17 16:22:04.800: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329773376,feature_id:18810
007856: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007857: Jan 17 16:22:04.800: :cc_free_feature_vsa freeing 8ADD8538
007858: Jan 17 16:22:04.800: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007859: Jan 17 16:22:04.800:  vsacount in free is 10
007860: Jan 17 16:22:04.804: //54163/C3BB522CBE96/CCAPI/cc_api_call_associated:
   Interface=0x0, CallId=54163, Disposition=0
   Play Function=0x83205A3C, Codec=0x5, Vad=0x0
   Media Type=0x3, SPI Context=0x8B76DDE0, Stream CallId=54167
   TX Dynamic Pt=0x0, RX Dynamic Pt=0x0
007861: Jan 17 16:22:05.112: //54166/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 183
Contact: <501>
v=0
o=CUE 6545234 2 IN IP4 10.1.10.1
s=SIP Call
c=IN IP4 10.1.10.1
t=0 0
m=audio 21284 RTP/AVP 0 101
a=fmtp:101 0-15
007862: Jan 17 16:22:05.116: //54166/C3BB522CBE96/CCAPI/cc_set_post_tagdata:
007863: Jan 17 16:22:05.116: //54166/C3BB522CBE96/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=54166,
007864: Jan 17 16:22:05.116: //54166/C3BB522CBE96/CCAPI/cc_api_caps_ind:
007865: Jan 17 16:22:05.116: //54163/C3BB522CBE96/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=54166, Source Call Id=54163,
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8610)
007866: Jan 17 16:22:05.116: //54163/C3BB522CBE96/CCAPI/cc_api_caps_ack:
007867: Jan 17 16:22:05.116: //54166/C3BB522CBE96/CCAPI/cc_api_event_indication:
   Event=171, Call Id=54166
007868: Jan 17 16:22:05.116: //54166/C3BB522CBE96/CCAPI/cc_api_event_indication:
007869: Jan 17 16:22:05.116: //54166/C3BB522CBE96/CCAPI/cc_api_call_connected:
   Connection Handle=0
007870: Jan 17 16:22:05.116: //54166/C3BB522CBE96/CCAPI/cc_api_call_connected:
007871: Jan 17 16:22:05.124: //54163/C3BB522CBE96/CCAPI/ccDisassociateStream:
007872: Jan 17 16:22:05.124: //54163/C3BB522CBE96/CCAPI/ccDisassociateStream:
   Call Entry(Stream Status=1, Digit Enable=FALSE)
007873: Jan 17 16:22:05.128: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
   (confID=0x8963F4BC, callID1=0xD393, gcid=C3BC8B14-602211E2-BE99B229-7E69AAE1, tag=0x0)
007874: Jan 17 16:22:05.128: //54166/C3BB522CBE96/CCAPI/ccConferenceCreate:
   (confID=0x8963F4BC, callID2=0xD396, gcid=C3BC8B14-602211E2-BE99B229-7E69AAE1, tag=0x0)
007875: Jan 17 16:22:05.128: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
   Conference Id=0x8963F4BC, Call Id1=54163, Call Id2=54166, Tag=0x0
007876: Jan 17 16:22:05.128: //54163/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007877: Jan 17 16:22:05.128: cc_api_get_xcode_stream : 4702
007878: Jan 17 16:22:05.128: //54166/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007879: Jan 17 16:22:05.128: cc_api_get_xcode_stream : 4702
007880: Jan 17 16:22:05.128: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
007881: Jan 17 16:22:05.128: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=0, dtmf1=6
007882: Jan 17 16:22:05.128: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
007883: Jan 17 16:22:05.128: //54163/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007884: Jan 17 16:22:05.128: cc_api_get_xcode_stream : 4702
007885: Jan 17 16:22:05.128: //54163/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007886: Jan 17 16:22:05.128: cc_api_get_xcode_stream : 4702
007887: Jan 17 16:22:05.128: //54163/C3BB522CBE96/CCAPI/cc_api_bridge_done:
   Conference Id=0xCD4, Source Interface=0x873D58C8, Source Call Id=54163,
   Destination Call Id=54166, Disposition=0x0, Tag=0x0
007888: Jan 17 16:22:05.128: //54166/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007889: Jan 17 16:22:05.128: cc_api_get_xcode_stream : 4702
007890: Jan 17 16:22:05.128: //54166/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
007891: Jan 17 16:22:05.128: cc_api_get_xcode_stream : 4702
007892: Jan 17 16:22:05.128: //54166/C3BB522CBE96/CCAPI/cc_api_bridge_done:
   Conference Id=0xCD4, Source Interface=0x873D58C8, Source Call Id=54166,
007893: Jan 17 16:22:05.128: //54163/C3BB522CBE96/CCAPI/cc_generic_bridge_done:
007894: Jan 17 16:22:05.128: //54163/C3BB522CBE96/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xCD4, Destination Call Id=54166)
007895: Jan 17 16:22:05.128: //54166/C3BB522CBE96/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0xCD4, Destination Call Id=54163)
007896: Jan 17 16:22:05.132: //54164/C3BB522CBE96/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
007897: Jan 17 16:22:05.132: //54164/C3BB522CBE96/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
007898: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007899: Jan 17 16:22:05.132: :cc_get_feature_vsa malloc success
007900: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007901: Jan 17 16:22:05.132:  cc_get_feature_vsa count is 11
007902: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
007903: Jan 17 16:22:05.132: :FEATURE_VSA attributes are: feature_name:0,feature_time:2329773376,feature_id:18811
007904: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007905: Jan 17 16:22:05.132: :cc_free_feature_vsa freeing 8ADD8538
007906: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007907: Jan 17 16:22:05.132:  vsacount in free is 10
007908: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007909: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007910: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007911: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007912: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007913: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007914: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007915: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007916: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007917: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007918: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007919: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007920: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007921: Jan 17 16:22:05.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
007922: Jan 17 16:22:05.132: //54163/C3BB522CBE96/CCAPI/ccCallNotify:
007923: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007924: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007925: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007926: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
007927: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007928: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007929: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
007930: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007931: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007932: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
007933: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
007934: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
007935: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
007936: Jan 17 16:22:05.136: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
007937: Jan 17 16:22:05.136: //54163/C3BB522CBE96/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=54163
007938: Jan 17 16:22:05.136: //54163/C3BB522CBE96/CCAPI/ccCallResume:
   Call Id=54163
007939: Jan 17 16:22:05.136: //54163/C3BB522CBE96/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xCD4, Call Id1=54163, Call Id2=54166
007940: Jan 17 16:22:05.140: //54166/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:501@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC669108F
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
007941: Jan 17 16:22:05.140: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:6141234567@67.205.74.164:5060 SIP/2.0
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC66A1E93
To: "6141234567" <6141234567>;tag=as4c22e24d
Date: Thu, 17 Jan 2013 21:22:05 GMT
Call-ID: 06b05c4466f817b0205094ff11124bcc@67.205.74.164
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1358457725
Expires: 180
Content-Length: 226
v=0
o=CiscoSystemsSIP-GW-UserAgent 4972 4349 IN IP4 66.166.166.22
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
007942: Jan 17 16:22:05.144: //54164/C3BB522CBE96/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x873D58C8, Tag=0x0, Call Id=54164,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
007943: Jan 17 16:22:05.144: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
007944: Jan 17 16:22:05.144: //54164/C3BB522CBE96/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
007945: Jan 17 16:22:05.144: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007946: Jan 17 16:22:05.144: :cc_free_feature_vsa freeing 8ADD87D8
007947: Jan 17 16:22:05.144: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007948: Jan 17 16:22:05.144:  vsacount in free is 9
007949: Jan 17 16:22:05.144: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007950: Jan 17 16:22:05.144:  vsacount in free is 8
007951: Jan 17 16:22:05.624: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
007952: Jan 17 16:22:06.572: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:montreal.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC66B2691
From: <>9154441234@montreal.voip.ms>;tag=93B68410-AB0
To: <>9154441234@montreal.voip.ms>
Date: Thu, 17 Jan 2013 21:22:06 GMT
Call-ID: 7A8C0F31-499911E2-8003B229-7E69AAE1
Max-Forwards: 70
Timestamp: 1358457726
CSeq: 13734 REGISTER
Expires:  3600
Supported: path
Content-Length: 0
007953: Jan 17 16:22:06.624: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 180
Content-Length: 226
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
007954: Jan 17 16:22:07.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:22:07 GMT
Max-Forwards: 70
Timestamp: 1358457727
Expires:  3600
Supported: path
Content-Length: 0
007955: Jan 17 16:22:08.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:22:08 GMT
Max-Forwards: 70
Timestamp: 1358457728
Expires:  3600
Supported: path
Content-Length: 0
007956: Jan 17 16:22:08.624: //54163/C3BB522CBE96/CCAPI/cc_api_call_disconnected:
   Cause Value=102, Interface=0x873D58C8, Call Id=54163
007957: Jan 17 16:22:08.624: //54163/C3BB522CBE96/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=102, Retry Count=0)
007958: Jan 17 16:22:08.624: //54166/C3BB522CBE96/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=54166
007959: Jan 17 16:22:08.624: //54163/C3BB522CBE96/CCAPI/ccConferenceDestroy:
   Conference Id=0xCD4, Tag=0x0
007960: Jan 17 16:22:08.624: //54163/C3BB522CBE96/CCAPI/cc_api_bridge_drop_done:
007961: Jan 17 16:22:08.624: //54166/C3BB522CBE96/CCAPI/cc_api_bridge_drop_done:
007962: Jan 17 16:22:08.624: //54163/C3BB522CBE96/CCAPI/cc_generic_bridge_done:
007963: Jan 17 16:22:08.628: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:6141234567@67.205.74.164:5060 SIP/2.0
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC66C1667
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=86
P-RTP-Stat: PS=393,OS=62403,PR=369,OR=57324,PL=0,JI=0,LA=0,DU=8
Content-Length: 0
007964: Jan 17 16:22:08.628: //54163/C3BB522CBE96/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=102)
007965: Jan 17 16:22:08.628: //54163/C3BB522CBE96/CCAPI/ccCallDisconnect:
   Cause Value=102, Call Entry(Responsed=TRUE, Cause Value=102)
007966: Jan 17 16:22:08.628: //54166/C3BB522CBE96/CCAPI/ccCallDisconnect:
   Cause Value=102, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
007967: Jan 17 16:22:08.628: //54166/C3BB522CBE96/CCAPI/ccCallDisconnect:
007968: Jan 17 16:22:08.632: //54166/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:501@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bKC66D1129
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=102
P-RTP-Stat: PS=175,OS=28000,PR=174,OR=27681,PL=0,JI=0,LA=0,DU=3
Content-Length: 0
007969: Jan 17 16:22:08.636: //54166/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 BYE
Content-Length: 0
007970: Jan 17 16:22:08.640: //54166/C3BB522CBE96/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x873D58C8, Tag=0x0, Call Id=54166,
   Call Entry(Disconnect Cause=102, Voice Class Cause Code=0, Retry Count=0)
007971: Jan 17 16:22:08.640: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
007972: Jan 17 16:22:08.640: //54166/C3BB522CBE96/CCAPI/cc_api_call_disconnect_done:
007973: Jan 17 16:22:08.640: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007974: Jan 17 16:22:08.640: :cc_free_feature_vsa freeing 8ADD78F8
007975: Jan 17 16:22:08.640: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007976: Jan 17 16:22:08.640:  vsacount in free is 7
007977: Jan 17 16:22:08.848: //54163/C3BB522CBE96/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC66C1667;received=66.166.166.22
CSeq: 102 BYE
User-Agent: VoIPMS/SERAST
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Length: 0
007978: Jan 17 16:22:08.848: //54163/C3BB522CBE96/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x873D58C8, Tag=0x0, Call Id=54163,
007979: Jan 17 16:22:08.848: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x8AD3C764; count=1
007980: Jan 17 16:22:08.848: //-1/C3BB522CBE96/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x88E205A8
007981: Jan 17 16:22:08.848: //54163/C3BB522CBE96/CCAPI/cc_api_call_disconnect_done:
007982: Jan 17 16:22:08.848: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007983: Jan 17 16:22:08.848: :cc_free_feature_vsa freeing 8ADD7118
007984: Jan 17 16:22:08.848: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007985: Jan 17 16:22:08.848:  vsacount in free is 6
007986: Jan 17 16:22:08.848: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
007987: Jan 17 16:22:08.848:  vsacount in free is 5
007988: Jan 17 16:22:10.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:22:10 GMT
Max-Forwards: 70
Timestamp: 1358457730
Expires:  3600
Supported: path
Content-Length: 0
007989: Jan 17 16:22:14.072: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:22:14 GMT
Max-Forwards: 70
Timestamp: 1358457734
Expires:  3600
Supported: path
Content-Length: 0
007990: Jan 17 16:22:18.073: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:22:18 GMT
Max-Forwards: 70
Timestamp: 1358457738
Expires:  3600
Supported: path
Content-Length: 0
007991: Jan 17 16:22:22.073: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Thu, 17 Jan 2013 21:22:22 GMT
Max-Forwards: 70
Timestamp: 1358457742
Expires:  3600
Supported: path
Content-Length: 0
007992: Jan 17 16:22:22.389: //54169/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 66.166.166.22:5060;branch=z9hG4bKC66B2691;received=66.166.166.22
Supported: replaces
Content-Length: 0
007993: Jan 17 16:22:22.389: //54169/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <>9154441234@montreal.voip.ms>;tag=as3e126da4
Supported: replaces
WWW-Authenticate: Digest algorithm=MD5, realm="montreal.voip.ms", nonce="0acce897"
Content-Length: 0
Any thoughts?
Thanks!
Re: Issues with Dropped Calls on UC520
Hello Reid,
If you look at the debug starting message 006502 you receive invite for call id :457e7ab472485f234b58d9014570a976.
The you sent the following messages:
006717: Jan 17 16:20:59.290: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
006746: Jan 17 16:20:59.354: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
006819: Jan 17 16:20:59.442: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
006834: Jan 17 16:20:59.542: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
006849: Jan 17 16:20:59.742: //54155/9F4F475DBE8B/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
And after the third 200 OK you are receiving the response from the SIP provider:
006850: Jan 17 16:20:59.898: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Then you are sending invites for the same call, could you please clarify the call frow?
Also you are not receiving ACK from the SIP provider as indicated earlier, after the third OK you are receiving the ACK from the provder it should be after the first 200 OK.
Please check with the provider this information.
You have the necessary ip and ports opened from what I can see.
HTH,
Alex
*Please rate helpful posts
686
