It is possible to make a SPA9000 sent a call on a mobile phone, if no answer for inbound calls ??
a-gruzdov
How to make so that at a call of a city, in a case if internal abonents haven't taken the call, the SPA9000 has sent a call on a mobile phone?
Whether probably such?
Alberto Montilla
Yes, it is possible...but depends on the Contact List (destination) selected.
On the contact list (on SPA9000 [line] tab) set the call forward no answer to the number. This can be used if the contact list is e.g. a receptionist or a hunt group (does not work if it is an auto attendant).
Alberto
Sorry to divert the thread but it's pretty close to my requirement.
Is it possible to have a hunt group ringing and forward the call to an external mobile at the same time? I really need both my extensions and my mobile all ringing together if possible.
If not, I would like both my extensions to ring (1 Spa 942 and one dect phone on the FXS1 of the SPA900) unless I set cfwd to my mobile from the SPA942. I can only make it work if the SPA942 is the only ringing phone. Otherwise when I set the cfwd to mobile the DECT phone keeps ringing.
Hope that makes sense.
