Logging in to manage UC-320W doesn't get past Cisco logo
Hi All,
ANy ideas? I had set the unit up last week, and for the most part everything went smoothly. Now, when I try to log in to the unit to check/change configuration, I can't get past the initial Cisco spash screen with the green bar. I have tried unplugging power to restart it, thinking maybe it was stuck. The system seems to be working fine, but I can't get in.
I tried it from several computers, and also from the Cisco OnPlus remote device. I tried several different browsers and operating systems. Nothing. I try to open 192.168.10.1 and get nowhere past the Cisco splash screen.
Help! Anyone have any ideas?
Gene O'Brien
Technology Service of Long Island
www.techservice-li.com
1 ACCEPTED SOLUTION
Hi Gene,
We do have a compatibility problem with the latest Adobe Flash Player 11.x.  Please downgrade the Adobe Flash Player to version 10.x.
From announcement:
_____________________________________________________________
UC320W Configuration Utility GUI fails at start up if the user has installed Flash Player 11.  We are working to understand the root cause and identify a fix.  In the meantime, please downgrade your version of Flash Player to version 10.
Please visit Adobe’s archives download area to download a version suitable for your operating system.
http://kb2.adobe.com/cps/142/tn_14266.html#main_Archived_versions
_______________________________________________________________
Cheers,
Julio
1 REPLY
Hi Gene,
From announcement:
Cheers,
Julio
1003
