Community Member
Login problem after 2.1.4(3) update
Hi:
following UC320w instructions I updated firmware to V2.1.4(3). Te update went throughg just fine but when I tried to relog into the system it kept telling me that user and/or password was not correct.
I reset system to factory defoults and went through the whole configuration from scrath and everything was smooth, i loged out and when trying to log in again same problem the usar and password I introduced during config is no good AGAIN, I tried cisco/cisco also but no luck.
Is there any way i can access without the need to reset it AGAIN to factory??. Is this a known issue wit fw version??, shoul I downgrade fw??
Community Member
Hello Alejandro,
I work in the Cisco Small Business Support in Europe.
Can you please confirm that the Cisco Small Business Support was able to solve your issue.
Friedrich
Community Member
Re: Login problem after 2.1.4(3) update
Yes it is fixed, thans a lot.
2012/1/17 fscharz
Home <> Re: Login
problem after 2.1.4(3) update created by Friedrich Scharz<>in
UC300 Series - View the full discussion<>
355
