Community Member
<Protect_IVR_FactoryReset> does not work on SPA525G
Does not protect LCD display for factory reset
Firmware is 525G , works on 504 . 502, 942,962
<Protect_IVR_FactoryReset ua="na">Yes</Protect_IVR_FactoryReset>
Everyone's tags (1)
Re: <Protect_IVR_FactoryReset> does not work on SPA525G
What firmware are you running on the 525?
CSCtd35385 spa525: factory reset is allowed with admin pw and protect IVRfactoryres
This should be fixed in 7.4.3.
Community Member
Sorry Thought I had put firmware version
is 7.4.3
problem is that admin password not set via
set password on Web and factory reset prompts for password as should
FYI  - some LDAP config fields are also broken on the 525 - could be related
Admin password is required for this Protect_IVR_FactoryReset to work.
Which LDAP fields are you saying do not work?
Community Member
I know the admin password is required
What I am saying is that is not being set by the xml
Can you send me the XML you are using?
Community Member
Our  XML is generated dynamically so there is no file, I would not post our config on a public forum anyway
This is the bit you need - I have changed the passowrd
This works on 941,942 962, 504 and 502
......xxxxxxxxxYes........
Community Member
it is another 525 gratuitous field  name change  -> is now (only on 525)   Admin_Password
Community Member
What is meant by xml generated dynamically?  The xml is usually made by using the spc tool.
Community Member
we have many 1000's  of phones - we generate the xml on the fly when requested by the device
The issue here is not how the XML is generated , but inconsistences in the field names between the 525G and other devices
Community Member
Please go into more details regarding inconsistent info between the products, I'll be able to write a bug report based on this info.
Community Member
The list is growing
  • Programmable_Softkey_Enable  only on 525
  • Admin_Password different
  • Several LDAP Directory fields different
Community Member
Ok, thanks.  I'll write up a bug regarding these field name issues.
1293
