Community Member
Make calls on Cisco IP Phones from applications on a computer!
Hello, i was wondering is it possible to make calls on a cisco ip phone (SPA 508G) from an application (MS Outlook) on my computer?
Paul
Re: Make calls on Cisco IP Phones from applications on a compute
Hi Paul,
Consider visiting the folk at http://www.uctrlit.com
I believe they're busy developing exactly what you're looking for.
Patrick
Community Member
The exact URL is www.uctrlit.com/CallCtrl and can download a 30-Day trail.
If you have any questions you can find support contact information in the User Guide.
Steve
Community Member
Thanks guys, I already knew about CallCtrl but it means my Cisco Clients need to purchase the SPA9000 which is going to cost them a few hundred euro more.
Paul
Community Member
We are working w/ Cisco to support the SPA IP Phones when used outside the SPA9000 IP PBX.
You can download Call Ctrl trial and you will then be registered to recieve product updates or contact directly w/ your contact information.
Steve Wofford
Call Ctrl Call Manager for
SPA900 - SPA500 IP Phones
4063
