Community Member
Max number of SPA525G2 with UC320W?
Does any one know for sure how many SPA525G2 Wireless IP Phones I can use with the UC320W?
Femi
Femi,
Would the SPA525G2 be in a wired or wireless configuration? The UC320W supports 24 devices.
Randy
Community Member
The maximum I would consider would be (5) SPA525G2 phones and all could not be in use at the same time.  I think you could probably use (4) simultaneously without issue.  The constraining factor is that you are using 802.11g on the phone to connect to the voice VLAN.  This limits you to only a 54mbps data rate from the phone to the accesspoint in a best case scenario.
Community Member
Hi Randall, sorry I missed out to say how many phones can be connected wirelessly at the same time.
Hi Rob, Cisco actually recommends 8 as I found out later today from here:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps11388/guide_c07-641629.pdf
Thanks anyway for your comments, will be sure to keep that paging in mind.
Femi
273
