10-22-2009 05:29 AM - edited 03-21-2019 01:41 AM
I setup multisite dialing using CCA2.1. When I dial the other site, after it rings for the specified number of seconds, it transfers the call to the remote site extension's voicemail. It says this user does not have voicemail setup even though they really do. Is this an easy configuration change?
10-22-2009 05:44 AM
CCA 2.1 should have placed these two (bold) statements in your CLI. Did it? That allows terminating call control and should fix that.....
10-22-2009 05:59 AM
Interesting.
Those bold lines were already there.
These lines were not:
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
I added those and it worked.
Thanks.
One more thing. Is it possible to setup a translation rule to add the prefix and site number to the extension. Site 1 extensions are 812xx. Site 2 extensions are 821xx. From site 1, could they dial 1xx to dial an extension at site 2 and the translation rule would add the 8 and 2?
10-22-2009 06:07 AM
I am happy your working now.
I will relay this infor to the CCA team post haste. If it is a problem we will fix it and thank you for finding this!
Regarding site to site dialing, the Multisite manager is based on having a Transation Rule and Dial peer that enforces a Ext Dialing prefix + a Site Index + actual extension. I dont have a hack for that and dont recommend it, but I am sure its possible.
Steve
