Community Member
Multisites Deployment
Hi there,
I'm implementing a UC520 system for three branches, in my scenario I have three UC520 system in each branch and the three branches and connected Via VPN tunnel created in a 2800 series router in each site (SO from each site I can ping and access any device at the other sites). I need now to connect the voice between the branches so I want to clear some points before starting the configuration:
  • Since the VPN sonfigurtion is done on the router not on the UC520 then can I use the Mulisite manager or not ?  and if not then will I be able to use the features on the Uc520 such as (Call admision control, traffic shaping, number of calles).
  • what is the best configuration or solution to make this three site comunicate together as a voice.
  • is there any document to explain this ?
1 REPLY
Bronze
Re: Multisites Deployment
Multisite manager would not work for this case to configure the UC500. You can follow the multi site guidelines for CLI here
https://supportforums.cisco.com/docs/DOC-9652 (may have to modify this to ignore the VPN configs)
Another good doc on integrating multiple CME / UC500 systems is below:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/multcme.html
450
