MWI isn't working
guys,
i have sip trunk setup on the uc, and mwi isn't working. however, i can leave message to the extension with no problem. i tired to refresh the mwi for many times, and i confirmed that mwi on/off is configure to be the same on cme/cue.
is there anything that is missing? i use cli during this troubleshooting steps.
thanks
this is the screenshot
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 3600 min 3600
  no update-callerid
sip-ua
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server ipv4:192.168.100.250 expires 3600 port 5060 transport udp
registrar ipv4:x.x.x.x expires 3600
sip-server ipv4:x.x.x:5060
connection-reuse
ephone-dn  599
number A801... no-reg primary
mwi off
ephone-dn  600
number A800... no-reg primary
mwi on
1 ACCEPTED SOLUTION
Bronze
MWI isn't working
What I meant was
on the cue module:
http:// 192.168.100.250 - find the settings for MWI and make sure the messages are send to your gi0/0 IP address. You have a SIP listener on your gi0/0 IP only
MWI isn't working
My first suggestion would be to try removing the bind statements.  I have seen those cause MWI problems before.
Thank you,
Darren
Bronze
MWI isn't working
Or on the CUE module, under the mwi settings you could try configuring the IP of gi 0/0 rather than the internal IP (typically 10.1.10.2)
MWI isn't working
i modified the ccn subsystem as well to point to cme local ip. the cme and cue are on the same subnet.
ccn subsystem sip
gateway address "192.168.100.254"
dtmf-relay rtp-nte
mwi sip outcall sub-notify
mwi envelope-info
end subsystem
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Vlan100
ip nat inside
ip virtual-reassembly in
service-module ip address 192.168.100.250 255.255.255.0
service-module ip default-gateway 192.168.100.254
interface GigabitEthernet0/1/0
switchport access vlan 100
switchport mode trunk
switchport voice vlan 50
macro description cisco-switch
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
Bronze
MWI isn't working
What I meant was
on the cue module:
MWI isn't working
okay after few troubleshooting, i changed sip gateway to point to the same ip as the gi 0/0, and also made mwi sip statemen on each ephone-dn. that's fixed the issue
thanks for the lead.
MWI isn't working
if i removed the bind command then i am not able to get inbound calls.
680
