Community Member
No more web UI acces on SPA504G
Since a couple of weeks I have no more acces to web UI via the web browswr using :
http://<phoneip> and/or http:<phoneip>/admin. neither of both works.
I get a connection error from firefox.
I tried fro several palces, always the same mistake.
Problem, my phone locked itself. None of the possible passwords are working.
00 or 000 or even the station's number 202
Therefor I can't even get into the configs to make any changes on the phone.
Is there any way to solve this issue without making a factory reset?
Phone is working fine anyway. I can call and receive calls without any problems.
Thank you in adavnce for any support.
Rgds
Patrick
1 REPLY
Community Member
Re: No more web UI acces on SPA504G
The only thing I can think of, is maybe the ip address changed on you.  If you're using dynamic ip then it may have changed.  You can check the phone ip in network settings.
228
