Community Member
No RTP Stream gong outside with SNR over SIP Trunk
Hi Community.
I've setup SIP Trunk on a UC540
Callin and Callout is working. Transfer is working too. But if I use SNR there isn't any RTP stream going out to the mobile phone.
Why don't send my UC a RTP stream to the mobile phone?
Best Regards Patrick
Pat,I can not talk to the
Pat,
I can not talk to the UC540, but I ran into a situation recently where the SIP gateway was sending out the private extension of the phone number instead of the full DID that was registered to the provider.  The provider was then blocking call.
In our SIP debugs we saw the RDNIS information of the private extension I believe. The error code we were getting back from SP was code 404 or something along those lines.
I recommend you do some debugs and track where the calls fails, compare the SNR call versus a normal call in the debugs, and then if you still get stuck post running configs and debugs back here.
Community Member
Hi.Your behavior can be fixed
Hi.
Your behavior can be fixed with the command "snr calling-number local".
But anyway, the Cisco TAC Engineer told me that the SIP Provider should support Hairpin calls, and he doesn't.
Patrick
141
