Community Member
outbound SIP trunk calls failing
I have my UC540 setup and the inbound SIP trunk calls work great, the outbound is the issue.
I pulled the logs and found the following error from the trunk provider:
SIP/2.0 404 Number not in e164 format, example +12125551212
My provider (bandwidth.com) says that I need to add a "+" in front of the numbers going out that trunk.
Anyhow know how to do this?
Thanks!!
1 REPLY
Hello Tony,
If you are using CCA under Caller ID tab of the outgoing dial plan window you may setup the CallerID and you may put + under the additional callerid settings on the lower window.
Further reading for CCA - Admin guide 3.2.1 p.461
In CLI you need to add "+" in front of the translated number in the translation rule.
HTH,
Alex
*Please rate helpful posts
274
