Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
PAT with DHCP on Firewall
Simple question that I don't know the answer to;
Can I do PAT on the UC500 if it is only getting it's IP via DHCP from the ISP?
The client wants to pass traffic inside but they only have 1 DHCP address and I have only done this with statics.
Thanks in advance,
Bob James
Re: PAT with DHCP on Firewall
Do you mean port forwarding? If so, you can still do this. I would recommend that you use DDNS, so when accessing your application from the outside you can just point it to a named destination, rather than an IP which wuld change.
If your mean NAT/PAT from the inside out, that should work too.
Marcos
Yes I mean port forwarding (inbound to DHCP IP) DDNS is a good choice I just wanted to make sure if I forward SSL, that the UC would not intercept it for itself (if that makes sense).
Cheers,
Bob
278
