10-06-2009 09:44 AM - last edited on 03-25-2019 10:42 PM by ciscomoderator
I have a Polycom plugged into the FXS port on a UC520 and I am able to make and transfer calls to that extension fine. How do I make multiple outbound calls to conference from the device itself? There is a flash button and several different timings but I have not gotten any of them to function properly.
Solved! Go to Solution.
04-13-2010 03:22 PM
I am actually having the same problem again - FAC and flash are not working, both phones are still set in user mode and the remainder of the settings are still correct as explained before.
04-13-2010 09:15 PM
I think I figured this out. I noticed that the Polycom was not being registered via SCCP, so I configured the following:
dial-peer voice 2 pots
no destination-pattern 88
service stcapp
no sip-register
port 0/0/1 (was already configured)
Now it registers correctly; I'll test conferencing tomorrow and will update with results.
04-26-2010 03:53 PM
John,
Can you receive a call on a user mode FXS, hookflash, and then dial another number, and hookflash again to conference all together?
be specific about what stopped working for you and I'll chase it down.
Steve
02-23-2011 12:13 PM
That is exactly the problem - I can not use hookflash to dial another number, I no
longer get a dial tone.
02-23-2011 12:16 PM
fac is also not working
02-23-2011 12:19 PM
well - I followed your steps at the top again and it fixed it - thanks again Steve!!
