Community Member
Port forwarding issue
IOS: 12.4(22)YB/ CME 7.1
I used CCA 2.0.1 for initial config.
I can't seem to get port forwarding working...anyone see what I am missing?
Do you have to specifiy "ip routing"?
Re: Port forwarding issue
I just used CCA 2.0.1 to configure a NAT for port 1024 coming in on FE0/0 to map to 1024 (TCP) on an inside 192.168.10.x address on my 12.4(20)T2 system and I am able to get in and use the application.
I see the same commands as you shared in your config:
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.10.16 1024 interface FastEthernet0/0 1024
and
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
Are you sure your terminal server is ready to receive connections?   Can you forward to a different application to rule that out?
Community Member
It was an ISP Issue
Are you trying to forward TCP 3389?  Or is it something else you are trying to forward?
2760
