Community Member
Prior to buying a BE6000
Hi, I wanted to get some infor before I spend cash on a BE6000. Is there anything else I need besides the following to implament the BE 6000.
Sip trunck, POE Switches, IP Phones, BE6000?
Also I have FIOS running which is what I wanted to run the be6k on, Would it be better to get a seperate FIOS line for the b6k?
Community Member
Hello:
Your device is not supported by the Small Business  Support Center. To get an answer to your post please post in the  appropriate section (see below).
Also, you have a duplicate post, please be careful to  limit similar issues / questions to one post to more accurately get  answers to your questions.
You will most likely have better luck posting under Collaboration, Voice and Video > Unified Communications Applications
Hope this helps you get an answer!
~Nick
Cisco Network Support Engineer
~Nick Cisco Network Support Engineer Please mark answered for helpful posts!
Hall of Fame Super Gold
Duplicate posts.
Go here:  https://supportforums.cisco.com/thread/2269481
198
