problem uc560
please help with this problem.....
UC560#service-module integrated-Service-Engine 0/0 status
Service Module is Cisco Integrated-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module is failed
Service Module heartbeat-reset is enabled
Service Module status is not available
after this capture i try to enter to CUE and appear bootloader session
Hall of Fame Super Gold
problem uc560
If CUE fails to load system, you can always re-install software as explained in documentation.
Community Member
Re: problem uc560
Hi Juan,
Please try the following command:
ROUTER#: service-module integrated-Service-Engine 0/0 reload
Or
ROUTER#: service-module integrated-Service-Engine 0/0 reset
Or
Power the system down completley, waut about 60 seconds and power it back up.
If this does not bring it back to life log a fault with SBSC for a failed CUE, let them investigate if the HDD has failed or if just the DB has failed, in which case they will assist you with a full reinstall. DO NOT do this yourself if you are not well versed with CLI reinstalls and the CUE CLI interface, you can do more harm then good
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
604
