Community Member
Selectively withholding CLI when dialling out
Is this possible?  Customer would selectively like to withhold their CLI, ie when calling some numbers.
We have a site with a UC 560, and we only have SSH access to the CLI from our location.
The customer has emailed and asked if it’s possible to program a code (eg. *141) to withhold CLI information on a call-by-call basis?  The site is a school, and sometimes want to be a bit stealthy.
The site has ISDN2 with 6 channels for outgoing/incoming calls.
I have tried the following, but it’s not working for the customer:
From http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeclid.html
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. caller-id block code code-string
5. exit
6. ephone-dn dn-tag
7. caller-id block
8. end
DETAILED STEPS
   Command or Action  Purpose
Step 1
enable
Example:
Router> enable
Enables privileged EXEC mode.
•Enter your password if prompted.
Step 2
configure terminal
Example:
Router# configure terminal
Enters global configuration mode.
Step 3
telephony-service
Example:
Router(config)# telephony-service
Enters telephony-service configuration mode.
Step 4
Example:
Router(config-telephony)# caller-id block code *1234
(Optional) Defines a code that users can enter before making calls on which the caller ID should not be displayed.
•code-string—Digit string of up to 16 characters. The first character must be an asterisk (*).
Step 5
exit
Example:
Router(config-telephony)# exit
Exits telephony-service configuration mode.
Step 6
ephone-dn dn-tag
Example:
Router(config)# ephone-dn 3
Enters ephone-dn configuration mode.
Step 7
caller-id block
Example:
Router(config-ephone-dn)# caller-id block
(Optional) Blocks display of caller-ID information for all outbound calls that originate from this dirceory number.
•This command can also be configured in ephone-dn-template configuration mode and applied to one or more directory number. The ephone-dn configuration has priority over the ephone-dn-template configuration.
Step 8
end
ENDS
Any ideas what I am missing, and is it possible to selectively withhold CLI on ISDN calls out?
Hall of Fame Super Gold
Take "debug isdn q931" with "term mon" when making a CLID blocked call as above.
If the presentation allowed bit is set correcntly to "no", that means telco is ignoring it.
In that case you have to ask telco what is the code for selectively block CLID, and use it with a dedicated DP.
Community Member
Hi Mikael,
In CCA, if you go to the outbound call rules and go to the Caller ID tab, look right at the top and it actually asks you if you want to setup selective CLI code
I use *55 as it is simple to remember, but you can use the one you listed above as well, this works very well with ISDN services, however check with your carrier if you can push out no number and they will honor it, that way when ever you do the selective CLID it will get sent out as blank and the carrier will then push the call out as "Private"... This of course is dependant on where you are located.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Community Member
Thank you both!  I will try this at customer site when I next visit.
Much obliged for your help.
Kind Regards
Mik
1269
