Send a call directly to voicemail on SPA525G?
How can I send a call directly to voicemail from the SPA525G/2?
It appears to only allow 3 digit transfers.
Everyone's tags (3)
Re: Send a call directly to voicemail on SPA525G?
Transfer to voice mail prefix.
dial it + ext and you go there.
I was told by the user that the phone would only accept 3 digits.
Upon testing dialing 6+Ext did transfer directly to voicemail after all.
So thank you.
On a related note, what does TRANSVM do if not transfer a call to voicemail? I cant find the TRANSVM feature documented,
Thanks again.
Feature/   FunctionCategoryDescriptionCCA: WizardCCA: Expert   ModeOffice ManagerPhone TUIOperate Notes
Call   Transfer to Voice MailVoicemail and   Auto AttendantAny user may   dial and access code as a prefix to any extension number that will access   that extensions voice mail box if created.  1-9 can be used.TSW: Define   Internal DialingConfigure>   Telephony> Voice Mail TrnsfVM SoftkeyTrnsfVM softkey   does the same as dialing to transfer (or   dial) direct to a users voice mail box.
2028
