Community Member
setting up corlist
hi guys,
i have question regarding corlist setup. can we setup this based on the ephone-dn instead of ephone. for example, there are 2 offices, office A has extension 100 and 101 and the phone number is 111-2222. then office B has extension 200 and 201 and the phone number is 333-4444. is there a way from the phone that if someone picks either extension then the it only uses specific outgoing number?
does this make sense?
thank you
1 ACCEPTED SOLUTION
Community Member
Re: setting up corlist
It is possible. Something like this:
dial-peer cor custom
name office-a
name office-b
dial-peer cor list call-office-a
member office-a
dial-peer cor list call-office-b
member office-b
dial-peer voice 20 pots
description 111-2222
corlist outgoing call-office-a
dial-peer voice 30 pots
description 333-4444
corlist outgoing call-office-b
ephone-dn 1
corlist incoming call-office-a
ephone-dn 2
corlist incoming call-office-b
If you are using the CCA config, it gets a little more complicated, since you have to work with existing COR lists, but the idea is the same. Hope this helps.
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
1 REPLY
Community Member
name office-a
name office-b
member office-a
member office-b
ephone-dn 1
ephone-dn 2
Marcos Hernandez
Cisco Systems, Inc.
3334
