Community Member
SF200 Series Switches
Are they supported (I mean officially -- by Cisco)?
The reason I ask is because it seems like these switches should work fine on UC320/UC500... but the Quick Pricing Tool does not give them as an option...
Thanks.
1 ACCEPTED SOLUTION
Green
Hi Daniel,
These switches are officially supported by the small business support group. On the latest firmware, I know for sure they work quite well with the uc320, just like the SX300 series does. (basically plug and play).
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Green
Hi Daniel,
-Tom
Community Member
Thanks Thomas.
Community Member
Re: SF200 Series Switches
I'm having terrible problems with the SF200e 24 port switch and the UC540 using CCA 3.2.1 (I'm guessing that its a VLAN issue - CCA wont let me add to the topology although it does see it)
VLANs must be manually configured for these to work with the UC500 - NO support via CCA
441
