Community Member
Shared FXO with FXS ?
Is there a way to have a shared line on a SPA phone and FXS handset ? I'd like the incoming call on an FXO line to ring on a line on SPA phone and handse on FXS port.
1 ACCEPTED SOLUTION
Re: Shared FXO with FXS ?
Hi Glanders,
Does it need to be in a shared model?
Because you can set up a Hunt Group to ring simultaneously in both, IP Phone and FXS handset.
You just need to route your incoming call to the configured Hunt Group Extension.
I hope it help you.
Regards.
Andrey Cassemiro.
Hi Glanders,
I hope it help you.
Regards.
Andrey Cassemiro.
Community Member
You're right. Really doesn't matter in my application. That should work. Thanks!
226
