Community Member
Simple FXS port no access digit dialing (for Fax and EFTPOS)
There may be several ways to do this, but with some assistance for the big C guys (cheers Luke and Dave) here is a simple solution for no access digit dialing for FXS ports. (that is, can dial the number directly without using 0 or 9 to select 'outside line')
Because the FXS port is a skinny controlled port, we apply a translation profile to the ephone-dn for the port to add the access digit (in our case 0)
So, create the translation rule and profile
EXAMPLE:
conf t
voice translation-rule 10001
rule 1 // /0/
voice translaton-profile FXS_FAX_EFTPOS
translate called 10001
end
  Then, on ephone-dn 5 (if that is the port you are using, ephone-dn5 is 0/0/0 of the fxs for this example)
add the translation profile to the port
conf t
telephony-service
ephone-dn 5
translation-profile incoming FXS_FAX_EFTPOS
end
So now when dialing out on this port, the leading 0 for outside number does not need to be added. However you cannot dial internally from this port. (generally not an issue on a fax or eftpos terminal)
1742
