07-20-2011 11:50 AM - edited 03-21-2019 04:22 AM
guys,
did anyone use sip trunk with XO on their UC? i am trying to setup sip trunk on the uc using CLI, but no success. i haven't worked with sip trunk that many.
let me know if you guys can share. thanks in advanced.
07-21-2011 07:14 PM
I did think there was a profile for XO in CCA.
But if no one responds, I reckon you should have a chat during the day with the wonderful folks at the Small Business Support Center .
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
regards Dave
07-21-2011 09:14 PM
Hi There,
Please check you have filled out the following information:
That should cover it, if you need some configuration guides then let me know and I will post one up.
Cheers,
David.
07-22-2011 11:31 AM
thanks for the response.
this is what i have so far. i have pretty configured everything by CLI, and have the right credential from the telco side. but i don't see that sip is registered. also, access list on the outiside interface is open to all. let me know if there is mistake or anything.
thank you.
voice translation-rule 8000
rule 1 /^91\(.*\)/ /\1/
rule 2 /^9\([2-9]\)/ /\1/
rule 3 /^9011/ /011/
voice translation-rule 8001
rule 1 /.*/ /2122794200/
voice translation-rule 8002
rule 1 /^2122794237/ /8000/
rule 2 /^2122794200/ /8001/
rule 3 /^2129677555/ /8009/
rule 4 /^2122681299/ /8009/
rule 5 /^2125640489/ /6405/
rule 6 /.*/ /8001/
rule 7 /^6469989100/ /106/
voice translation-rule 8003
rule 1 /\(.*\)/ /91\1/
voice translation-profile SIP_PSTN_Incoming
translate calling 8003
translate called 8002
voice translation-profile SIP_PSTN_Outgoing
translate calling 8001
translate called 8000
dial-peer voice 24000 voip
description SIP_Incoming
translation-profile incoming SIP_PSTN_Incoming
preference 1
session protocol sipv2
session target ipv4:207.101.31.37
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 24001 voip
description US Call SIP_Outgoing
translation-profile outgoing SIP_PSTN_Outgoing
preference 1
destination-pattern 91..........
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte h245-alphanumeric
no vad
dial-peer voice 24002 voip
description Service Call SIP_Outgoing
preference 1
destination-pattern 9[2-9]11
no vad
sip-ua
credentials username 2-1IU-3869 password 7 06544270657B444A5D414B realm 207.101.31.37
authentication username 2-1IU-3869 password 7 05594B5E0879035A41534E realm 207.101.31.37
retry invite 2
retry register 3
mwi-server ipv4:10.1.10.1 expires 3600 port 5060 transport udp
registrar ipv4:207.101.31.37 expires 3600
sip-server ipv4:207.101.31.37
host-registrar
sh sip-ua register status:
Line peer expires(sec) registered P-Associated-URI
101 20025 81 no
103 20021 81 no
104 20023 81 no
105 20026 81 no
106 20007 81 no
107 20009 81 no
108 20018 81 no
110 20014 81 no
111 20024 81 no
112 20016 81 no
113 20011 81 no
114 20008 81 no
115 20015 81 no
116 20012 81 no
118 20019 81 no
119 20022 81 no
121 20020 91 no
122 20028 91 no
123 20013 94 no
124 20017 91 no
125 20010 94 no
130 20029 91 no
180 20030 90 no
190 20027 90 no
2-1IU-3869 -1 93 no
07-25-2011 11:02 PM
Hi There,
You may need the following:
ephone-dn XXX
number 2122794200
description SIP Trunk Registration
hold-alert 30 originator
Or
ephone-dn XXX
number 2-1IU-3869
I don't know how XO work so I would try it with your DID number first, if that does not work then try it with your username, although not sure if the configuration will take that type of character arrangement
But I am going to assume at this stage you need a DN to form the registration process as well, unless someone who has used XO before advises otherwise.
Cheers,
David.
