SIP configuration on UC 560 with XO
guys,
did anyone use sip trunk with XO on their UC? i am trying to setup sip trunk on the uc using CLI, but no success. i haven't worked with sip trunk that many.
let me know if you guys can share. thanks in advanced.
I did think there was a profile for XO in CCA.
But if no one responds, I reckon you should have a chat during the day with  the wonderful folks at the Small Business Support Center .
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
regards Dave
Hi There,
Please check you have filled out the following information:
  • The SIP-UA
  • Created a SIP registration DN
  • Created your SIP Translation Rule/Profiles(s)
  • Made sure that the ITSP IP address is in the ACL's so incoming calls get through
That should cover it, if you need some configuration guides then let me know and I will post one up.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
thanks for the response.
this is what i have so far. i have pretty configured everything by CLI, and have the right credential from the telco side. but i don't see that sip is registered. also, access list on the outiside interface is open to all. let me know if there is mistake or anything.
thank you.
voice translation-rule 8000
rule 1 /^91\(.*\)/ /\1/
rule 2 /^9\([2-9]\)/ /\1/
rule 3 /^9011/ /011/
voice translation-rule 8001
rule 1 /.*/ /2122794200/
voice translation-rule 8002
rule 1 /^2122794237/ /8000/
rule 2 /^2122794200/ /8001/
rule 3 /^2129677555/ /8009/
rule 4 /^2122681299/ /8009/
rule 5 /^2125640489/ /6405/
rule 6 /.*/ /8001/
rule 7 /^6469989100/ /106/
voice translation-rule 8003
rule 1 /\(.*\)/ /91\1/
voice translation-profile SIP_PSTN_Incoming
translate calling 8003
translate called 8002
voice translation-profile SIP_PSTN_Outgoing
translate calling 8001
translate called 8000
dial-peer voice 24000 voip
description SIP_Incoming
translation-profile incoming SIP_PSTN_Incoming
preference 1
session protocol sipv2
session target ipv4:207.101.31.37
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 24001 voip
description US Call SIP_Outgoing
translation-profile outgoing SIP_PSTN_Outgoing
preference 1
destination-pattern 91..........
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte h245-alphanumeric
no vad
dial-peer voice 24002 voip
description Service Call SIP_Outgoing
preference 1
destination-pattern 9[2-9]11
no vad
sip-ua
credentials username 2-1IU-3869 password 7 06544270657B444A5D414B realm 207.101.31.37
authentication username 2-1IU-3869 password 7 05594B5E0879035A41534E realm 207.101.31.37
retry invite 2
retry register 3
mwi-server ipv4:10.1.10.1 expires 3600 port 5060 transport udp
registrar ipv4:207.101.31.37 expires 3600
sip-server ipv4:207.101.31.37
host-registrar
sh sip-ua register status:
Line          peer           expires(sec)  registered   P-Associated-URI
101           20025            81            no
103           20021            81            no
104           20023            81            no
105           20026            81            no
106           20007            81            no
107           20009            81            no
108           20018            81            no
110           20014            81            no
111           20024            81            no
112           20016            81            no
113           20011            81            no
114           20008            81            no
115           20015            81            no
116           20012            81            no
118           20019            81            no
119           20022            81            no
121           20020            91            no
122           20028            91            no
123           20013            94            no
124           20017            91            no
125           20010            94            no
130           20029            91            no
180           20030            90            no
190           20027            90            no
2-1IU-3869    -1               93            no
Hi There,
You may need the following:
ephone-dn  XXX
number 2122794200
description SIP Trunk Registration
hold-alert 30 originator
Or
ephone-dn  XXX
number 2-1IU-3869
I don't know how XO work so I would try it with your DID number first, if that does not work then try it with your username, although not sure if the configuration will take that type of character arrangement
But I am going to assume at this stage you need a DN to form the registration process as well, unless someone who has used XO before advises otherwise.
Cheers,
David.
843
