SIP incoming paging for SPA50X. What's the header format?
Hi, I have this Alert-Info header in my INVITE
Alert-Info: <http://x>;info=alert-autoanswer
for Intercom, paging.
This works fine with Linksys SPA2102 DTA.
But SPA50x didn't automatically answer the call.
I have Paging Serv enable under phone tab.
What else do I need to do for paging. Thanks
Re: SIP incoming paging for SPA50X. What's the header format?
There's two ways you can do this; multicast or individual.  I got both to work at one point, but I'm currently only using Multicast (through MulticastRTP in Asterisk).  I can give this a try over the weekend (if I remember), and let you know which header code does it.  Which PBX/Controller are you using?
Hi, I have figured it out from another thread. http://homecommunity.cisco.com/t5/VoIP-Phones/SPA942-auto-answer-page-intercom-beeping-loudly/td-p/215064
I put
Call-Info: ;answer-after=0
and it works.
Thanks for your help.
592
