Community Member
SIP Trunk between CUCM and SPA9000
Hi All,
I would like to know is it possible to connect SPA9000 with CUCM by using SIP Trunk ? How is the setting on both ?
Or is there any other way to connect SPA9000 to CUCM ?
I Cannot get any clue on the internet about this
Really appreaciate if someone have the tips and how to configure this
Thanks very much
David
1 REPLY
Re: SIP Trunk between CUCM and SPA9000
Dear sir;
This configuration is not documented or supported by our Technical Support Center, however it should work without any issues. Some hints on the SPA9000 piece (I cannot comment on the CUCM since I'm not an expert on it).
On SPA9000 web UI go to the Voice tab, then go to admin and then advanced mode
- Click on the Line 1 tab
- Set register to no
- Set make and answer call without registration to Yes
- Set the proxy address to the ip address of the CUCM.
- Set a user name (any, should match with the username included in CUCM route)
- If required by CUCM, add the user password.
- Submit changes
That completes the configuration on the SPA9000 side. For CUCM, I suggest you go to cisco.com. There is a good set of documentation available for partners.
Alberto
1467
