Community Member
Site to Site Voicemail
So I have a two site UC560 setup.  Which for the most part was setup using the CCA.  Some of the routing/etc had to be done manually due to a MPLS network existing, so there is no VPN its all over MPLS.
That said voicemail on site A works fine from external/internal.
Voicemail on site B works fine from external/internal.
Site A can call Site B and leave voicemails on Site B's CUE.
Site B CANNOT call Site A and leave voicemails on Site A's CUE.  The get a no mailbox associated with that extension.
Like I said it works fine from the outside/inside and from Site A to B.  Just not from B to A.
Where would I begin hunting for the issue?
Btw I use seperate phone networks on each end.
Site A - 10.1.1.0
Site B - 10.2.1.0
However both use the same CUE network/address of 10.1.10.x
I initially thought that may be the issue but then why can site B call A and leave voicemails, just not vice versa.
162
