Community Member
Site-to-Site VPN btw SR520's
I can't figure out thru CCA 2.1 how to setup a site-to-site VPN btw two SR520's.
Can this only be done from cli and where can I find some doc's on it, or am I missing something is CCA 2.1
Re: Site-to-Site VPN btw SR520's
I don't believe this is possible in CCA.
This guide is long, but it has everything.
http://www.cisco.com/en/US/docs/ios/sec_secure_connectivity/configuration/guide/sec_key_exch_ipsec_ps6017_TSD_Products_Configuration_Guide_Chapter.html
Other pages also have good information on options for this.  Hopefully this helps.
Community Member
This would only work if you had two SR520's correct? Not a SC520 and Other ipsec device...?
-Ted
Bronze
This would work with any other Cisco IOS device or even an ASA or PIX. Nor sure what you have on the other side in this case.
1235
