Community Member
site to site VPN re-connection issue
Hi I done site -to -site VPN between two UC 560 and I am able to make call too. Both site I am using DDNS FQDN. Now I am facing these problems,
1. When ever any of the site gone down , it is taking around 45 minute to get reconnect the VPN.
2. With in 2 minute Dialer interface is getting WAN  IP address from service provider and it is updating with Dyndns also. But while checking crypto session details from my local UC I can see the peer address is not changing or showing none.
please help me to overcome this issue
I tested by restarting ROUTER-A  UC560
Please find the status of remote site:
ROUTER-B#sh crypto isa sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
2.50.37.13      86.99.72.10     MM_NO_STATE       2004 ACTIVE (deleted)
ROUTER-A#sh crypto isa sa
ROUTER-B#sho crypto session detail
Crypto session current status
Code: C - IKE Configuration mode, D - Dead Peer Detection
K - Keepalives, N - NAT-traversal, T - cTCP encapsulation
X - IKE Extended Authentication, F - IKE Fragmentation
Interface: Dialer0
Session status: UP-NO-IKE
Peer: 86.99.72.10 port 500 fvrf: (none) ivrf: (none)
      Desc: (none)
      Phase1_id: (none)
  IPSEC FLOW: permit ip 192.168.10.0/255.255.255.0 192.168.50.0/255.255.255.0
        Active SAs: 2, origin: crypto map
        Inbound:  #pkts dec'ed 12452 drop 0 life (KB/Sec) 4477633/1050
        Outbound: #pkts enc'ed 15625 drop 228 life (KB/Sec) 4477628/1050
ROUTER-A# sho crypto session det
Interface: Virtual-Access2
Session status: DOWN
Peer:  port 500 fvrf: (none) ivrf: (none)
      Desc: (none)
      Phase1_id: (none)
  IPSEC FLOW: permit ip 192.168.50.0/255.255.255.0 192.168.10.0/255.255.255.0
        Active SAs: 0, origin: crypto map
        Inbound:  #pkts dec'ed 0 drop 0 life (KB/Sec) 0/0
        Outbound: #pkts enc'ed 0 drop 0 life (KB/Sec) 0/0
Interface: Dialer0
      Desc: (none)
      Phase1_id: (none)
        Outbound: #pkts enc'ed 0 drop 23 life (KB/Sec) 0/0
**** Here I can see the peer IP is 86.99.72.10, but address had been changed to  92.98.211.242 in ROUTER-A
Please see the debug crypto isakpm
ROUTER-A#debug crypto isakmp
Crypto ISAKMP debugging is on
ROUTER-A#terminal monitor
000103: Aug  6 18:40:48.083: ISAKMP:(0): SA request profile is (NULL)
000104: Aug  6 18:40:48.083: ISAKMP: Created a peer struct for , peer port 500
000105: Aug  6 18:40:48.083: ISAKMP: New peer created peer = 0x86682AAC peer_handle = 0x80000031
000106: Aug  6 18:40:48.083: ISAKMP: Locking peer struct 0x86682AAC, refcount 1 for isakmp_initiator
000107: Aug  6 18:40:48.083: ISAKMP: local port 500, remote port 500
000108: Aug  6 18:40:48.083: ISAKMP: set new node 0 to QM_IDLE
000109: Aug  6 18:40:48.083: ISAKMP:(0):insert sa successfully sa = 8B4EBE04
000110: Aug  6 18:40:48.083: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000111: Aug  6 18:40:48.083: ISAKMP:(0):No pre-shared key with !
000112: Aug  6 18:40:48.083: ISAKMP:(0): No Cert or pre-shared address key.
000113: Aug  6 18:40:48.083: ISAKMP:(0): construct_initial_message: Can not start Main mode
000114: Aug  6 18:40:48.083: ISAKMP: Unlocking peer struct 0x86682AAC for isadb_unlock_peer_delete_sa(), count 0
000115: Aug  6 18:40:48.083: ISAKMP: Deleting peer node by peer_reap for : 86682AAC
000116: Aug  6 18:40:48.083: ISAKMP:(0):purging SA., sa=8B4EBE04, delme=8B4EBE04
000117: Aug  6 18:40:48.083: ISAKMP:(0):purging node 2113438140
000118: Aug  6 18:40:48.083: ISAKMP: Error while processing SA request: Failed to initialize SA
000119: Aug  6 18:40:48.083: ISAKMP: Error while processing KMI message 0, error 2.
000120: Aug  6 18:41:18.083: ISAKMP:(0): SA request profile is (NULL)
000121: Aug  6 18:41:18.083: ISAKMP: Created a peer struct for , peer port 500
000122: Aug  6 18:41:18.083: ISAKMP: New peer created peer = 0x8668106C peer_handle = 0x80000032
000123: Aug  6 18:41:18.083: ISAKMP: Locking peer struct 0x8668106C, refcount 1 for isakmp_initiator
000124: Aug  6 18:41:18.083: ISAKMP: local port 500, remote port 500
000125: Aug  6 18:41:18.083: ISAKMP: set new node 0 to QM_IDLE
000126: Aug  6 18:41:18.083: ISAKMP:(0):insert sa successfully sa = 86685DFC
000127: Aug  6 18:41:18.083: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000128: Aug  6 18:41:18.083: ISAKMP:(0):No pre-shared key with !
000129: Aug  6 18:41:18.083: ISAKMP:(0): No Cert or pre-shared address key.
000130: Aug  6 18:41:18.083: ISAKMP:(0): construct_initial_message: Can not start Main mode
000131: Aug  6 18:41:18.083: ISAKMP: Unlocking peer struct 0x8668106C for isadb_unlock_peer_delete_sa(), count 0
000132: Aug  6 18:41:18.083: ISAKMP: Deleting peer node by peer_reap for : 8668106C
000133: Aug  6 18:41:18.083: ISAKMP:(0):purging SA., sa=86685DFC, delme=86685DFC
000134: Aug  6 18:41:18.083: ISAKMP:(0):purging node 379490091
000135: Aug  6 18:41:18.083: ISAKMP: Error while processing SA request: Failed to initialize SA
000136: Aug  6 18:41:18.083: ISAKMP: Error while processing KMI message 0, error 2.
000137: Aug  6 18:42:48.083: ISAKMP:(0): SA request profile is (NULL)
000138: Aug  6 18:42:48.083: ISAKMP: Created a peer struct for , peer port 500
000139: Aug  6 18:42:48.083: ISAKMP: New peer created peer = 0x86691200 peer_handle = 0x80000033
000140: Aug  6 18:42:48.083: ISAKMP: Locking peer struct 0x86691200, refcount 1for isakmp_initiator
000141: Aug  6 18:42:48.083: ISAKMP: local port 500, remote port 500
000142: Aug  6 18:42:48.083: ISAKMP: set new node 0 to QM_IDLE
000143: Aug  6 18:42:48.083: ISAKMP:(0):insert sa successfully sa = 866E1758
000144: Aug  6 18:42:48.083: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000145: Aug  6 18:42:48.083: ISAKMP:(0):No pre-shared key with !
000146: Aug  6 18:42:48.083: ISAKMP:(0): No Cert or pre-shared address key.
000147: Aug  6 18:42:48.083: ISAKMP:(0): construct_initial_message: Can not start Main mode
000148: Aug  6 18:42:48.083: ISAKMP: Unlocking peer struct 0x86691200 for isadb_unlock_peer_delete_sa(), count 0
000149: Aug  6 18:42:48.083: ISAKMP: Deleting peer node by peer_reap for : 86691200
000150: Aug  6 18:42:48.083: ISAKMP:(0):purging SA., sa=866E1758, delme=866E1758
000151: Aug  6 18:42:48.083: ISAKMP:(0):purging node -309783810
000152: Aug  6 18:42:48.083: ISAKMP: Error while processing SA request: Failed to initialize SA
000153: Aug  6 18:42:48.083: ISAKMP: Error while processing KMI message 0, error 2.
000154: Aug  6 18:43:18.083: ISAKMP:(0): SA request profile is (NULL)
000155: Aug  6 18:43:18.083: ISAKMP: Created a peer struct for , peer port 500
000156: Aug  6 18:43:18.083: ISAKMP: New peer created peer = 0x8668106C peer_handle = 0x80000034
000157: Aug  6 18:43:18.083: ISAKMP: Locking peer struct 0x8668106C, refcount 1 for isakmp_initiator
000158: Aug  6 18:43:18.083: ISAKMP: local port 500, remote port 500
000159: Aug  6 18:43:18.083: ISAKMP: set new node 0 to QM_IDLE
000160: Aug  6 18:43:18.083: ISAKMP:(0):insert sa successfully sa = 8B4AB780
000161: Aug  6 18:43:18.083: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000162: Aug  6 18:43:18.083: ISAKMP:(0):No pre-shared key with !
000163: Aug  6 18:43:18.083: ISAKMP:(0): No Cert or pre-shared address key.
000164: Aug  6 18:43:18.083: ISAKMP:(0): construct_initial_message: Can not start Main mode
000165: Aug  6 18:43:18.083: ISAKMP: Unlocking peer struct 0x8668106C for isadb _unlock_peer_delete_sa(), count 0
000166: Aug  6 18:43:18.083: ISAKMP: Deleting peer node by peer_reap for : 8668106C
000167: Aug  6 18:43:18.083: ISAKMP:(0):purging SA., sa=8B4AB780, delme=8B4AB78 0
000168: Aug  6 18:43:18.083: ISAKMP:(0):purging node 461611358
000169: Aug  6 18:43:18.083: ISAKMP: Error while processing SA request: Failed to initialize SA
000170: Aug  6 18:43:18.083: ISAKMP: Error while processing KMI message 0, erro r 2.
000171: Aug  6 18:44:48.083: ISAKMP:(0): SA request profile is (NULL)
000172: Aug  6 18:44:48.083: ISAKMP: Created a peer struct for , peer port 500
000173: Aug  6 18:44:48.083: ISAKMP: New peer created peer = 0x8B4A25C8 peer_handle = 0x80000035
000174: Aug  6 18:44:48.083: ISAKMP: Locking peer struct 0x8B4A25C8, refcount 1 for isakmp_initiator
000175: Aug  6 18:44:48.083: ISAKMP: local port 500, remote port 500
000176: Aug  6 18:44:48.083: ISAKMP: set new node 0 to QM_IDLE
000177: Aug  6 18:44:48.083: ISAKMP:(0):insert sa successfully sa = 8B4EC7E8
000178: Aug  6 18:44:48.083: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000179: Aug  6 18:44:48.083: ISAKMP:(0):No pre-shared key with !
000180: Aug  6 18:44:48.083: ISAKMP:(0): No Cert or pre-shared address key.
000181: Aug  6 18:44:48.083: ISAKMP:(0): construct_initial_message: Can not start Main mode
000182: Aug  6 18:44:48.083: ISAKMP: Unlocking peer struct 0x8B4A25C8 for isadb_unlock_peer_delete_sa(), count 0
000183: Aug  6 18:44:48.083: ISAKMP: Deleting peer node by peer_reap for : 8B4A25C8
000184: Aug  6 18:44:48.083: ISAKMP:(0):purging SA., sa=8B4EC7E8, delme=8B4EC7E8
000185: Aug  6 18:44:48.083: ISAKMP:(0):purging node -1902909277
000186: Aug  6 18:44:48.083: ISAKMP: Error while processing SA request: Failed to initialize SA
000187: Aug  6 18:44:48.083: ISAKMP: Error while processing KMI message 0, error 2.
000188: Aug  6 18:45:18.083: ISAKMP:(0): SA request profile is (NULL)
000189: Aug  6 18:45:18.083: ISAKMP: Created a peer struct for , peer port 500
000190: Aug  6 18:45:18.083: ISAKMP: New peer created peer = 0x8668106C peer_handle = 0x80000036
000191: Aug  6 18:45:18.083: ISAKMP: Locking peer struct 0x8668106C, refcount 1 for isakmp_initiator
000192: Aug  6 18:45:18.083: ISAKMP: local port 500, remote port 500
000193: Aug  6 18:45:18.083: ISAKMP: set new node 0 to QM_IDLE
000194: Aug  6 18:45:18.083: ISAKMP:(0):insert sa successfully sa = 86685DFC
000195: Aug  6 18:45:18.083: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000196: Aug  6 18:45:18.083: ISAKMP:(0):No pre-shared key with !
000197: Aug  6 18:45:18.083: ISAKMP:(0): No Cert or pre-shared address key.
000198: Aug  6 18:45:18.083: ISAKMP:(0): construct_initial_message: Can not start Main mode
000199: Aug  6 18:45:18.083: ISAKMP: Unlocking peer struct 0x8668106C for isadb_unlock_peer_delete_sa(), count 0
000200: Aug  6 18:45:18.083: ISAKMP: Deleting peer node by peer_reap for : 8668106C
000201: Aug  6 18:45:18.083: ISAKMP:(0):purging SA., sa=86685DFC, delme=86685DFC
000202: Aug  6 18:45:18.083: ISAKMP:(0):purging node 1093064733
000203: Aug  6 18:45:18.083: ISAKMP: Error while processing SA request: Failed to initialize SA
000204: Aug  6 18:45:18.083: ISAKMP: Error while processing KMI message 0, error 2.
000205: Aug  6 18:46:48.083: ISAKMP:(0): SA request profile is (NULL)
000206: Aug  6 18:46:48.083: ISAKMP: Created a peer struct for , peer port 500
000207: Aug  6 18:46:48.083: ISAKMP: New peer created peer = 0x86682BE0 peer_handle = 0x80000037
000208: Aug  6 18:46:48.083: ISAKMP: Locking peer struct 0x86682BE0, refcount 1 for isakmp_initiator
000209: Aug  6 18:46:48.083: ISAKMP: local port 500, remote port 500
000210: Aug  6 18:46:48.083: ISAKMP: set new node 0 to QM_IDLE
000211: Aug  6 18:46:48.083: ISAKMP:(0):insert sa successfully sa = 866E1758
000212: Aug  6 18:46:48.083: ISAKMP:(0):Can not start Aggressive mode, trying Main mode.
000213: Aug  6 18:46:48.083: ISAKMP:(0):No pre-shared key with !
000214: Aug  6 18:46:48.083: ISAKMP:(0): No Cert or pre-shared address key.
000215: Aug  6 18:46:48.083: ISAKMP:(0): construct_initial_message: Can not start Main mode
000216: Aug  6 18:46:48.083: ISAKMP: Unlocking peer struct 0x86682BE0 for isadb_unlock_peer_delete_sa(), count 0
000217: Aug  6 18:46:48.083: ISAKMP: Deleting peer node by peer_reap for : 86682BE0
000218: Aug  6 18:46:48.083: ISAKMP:(0):purging SA., sa=866E1758, delme=866E1758
000219: Aug  6 18:46:48.083: ISAKMP:(0):purging node -1521272284
000220: Aug  6 18:46:48.083: ISAKMP: Error while processing SA request: Failed to initialize SA
000221: Aug  6 18:46:48.083: ISAKMP: Error while processing KMI message 0, error 2.
000222: Aug  6 18:47:03.131: ISAKMP (0): received packet from 2.50.37.13 dport 500 sport 500 Global (N) NEW SA
000223: Aug  6 18:47:03.131: ISAKMP: Created a peer struct for 2.50.37.13, peer port 500
000224: Aug  6 18:47:03.131: ISAKMP: New peer created peer = 0x8668106C peer_handle = 0x80000038
000225: Aug  6 18:47:03.131: ISAKMP: Locking peer struct 0x8668106C, refcount 1 for crypto_isakmp_process_block
000226: Aug  6 18:47:03.131: ISAKMP: local port 500, remote port 500
000227: Aug  6 18:47:03.131: ISAKMP:(0):insert sa successfully sa = 8B4C1924
000228: Aug  6 18:47:03.131: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000229: Aug  6 18:47:03.131: ISAKMP:(0):Old State = IKE_READY  New State = IKE_R_MM1
000230: Aug  6 18:47:03.131: ISAKMP:(0): processing SA payload. message ID = 0
000231: Aug  6 18:47:03.131: ISAKMP:(0): processing vendor id payload
000232: Aug  6 18:47:03.131: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
000233: Aug  6 18:47:03.131: ISAKMP (0): vendor ID is NAT-T RFC 3947
000234: Aug  6 18:47:03.131: ISAKMP:(0): processing vendor id payload
000235: Aug  6 18:47:03.131: ISAKMP:(0): vendor ID seems Unity/DPD but major 245 mismatch
000236: Aug  6 18:47:03.131: ISAKMP (0): vendor ID is NAT-T v7
000237: Aug  6 18:47:03.131: ISAKMP:(0): processing vendor id payload
000238: Aug  6 18:47:03.131: ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismatch
000239: Aug  6 18:47:03.131: ISAKMP:(0): vendor ID is NAT-T v3
000240: Aug  6 18:47:03.131: ISAKMP:(0): processing vendor id payload
000241: Aug  6 18:47:03.131: ISAKMP:(0): vendor ID seems Unity/DPD but major 123 mismatch
000242: Aug  6 18:47:03.131: ISAKMP:(0): vendor ID is NAT-T v2
000243: Aug  6 18:47:03.131: ISAKMP:(0):found peer pre-shared key matching 2.50.37.13
000244: Aug  6 18:47:03.131: ISAKMP:(0): local preshared key found
000245: Aug  6 18:47:03.131: ISAKMP : Scanning profiles for xauth ... sdm-ike-profile-1
000246: Aug  6 18:47:03.131: ISAKMP:(0): Authentication by xauth preshared
000247: Aug  6 18:47:03.131: ISAKMP:(0):Checking ISAKMP transform 1 against priority 1 policy
000248: Aug  6 18:47:03.131: ISAKMP:      encryption 3DES-CBC
000249: Aug  6 18:47:03.131: ISAKMP:      hash SHA
000250: Aug  6 18:47:03.131: ISAKMP:      default group 2
000251: Aug  6 18:47:03.131: ISAKMP:      auth pre-share
000252: Aug  6 18:47:03.131: ISAKMP:      life type in seconds
000253: Aug  6 18:47:03.131: ISAKMP:      life duration (VPI) of  0x0 0x1 0x51 0x80
000254: Aug  6 18:47:03.135: ISAKMP:(0):atts are acceptable. Next payload is 0
000255: Aug  6 18:47:03.135: ISAKMP:(0):Acceptable atts:actual life: 1800
000256: Aug  6 18:47:03.135: ISAKMP:(0):Acceptable atts:life: 0
000257: Aug  6 18:47:03.135: ISAKMP:(0):Fill atts in sa vpi_length:4
000258: Aug  6 18:47:03.135: ISAKMP:(0):Fill atts in sa life_in_seconds:86400
000259: Aug  6 18:47:03.135: ISAKMP:(0):Returning Actual lifetime: 1800
000260: Aug  6 18:47:03.135: ISAKMP:(0)::Started lifetime timer: 1800.
000261: Aug  6 18:47:03.135: ISAKMP:(0): processing vendor id payload
000262: Aug  6 18:47:03.135: ISAKMP:(0): vendor ID seems Unity/DPD but major 69 mismatch
000263: Aug  6 18:47:03.135: ISAKMP (0): vendor ID is NAT-T RFC 3947
000264: Aug  6 18:47:03.135: ISAKMP:(0): processing vendor id payload
000265: Aug  6 18:47:03.135: ISAKMP:(0): vendor ID seems Unity/DPD but major 245 mismatch
000266: Aug  6 18:47:03.135: ISAKMP (0): vendor ID is NAT-T v7
000267: Aug  6 18:47:03.135: ISAKMP:(0): processing vendor id payload
000268: Aug  6 18:47:03.135: ISAKMP:(0): vendor ID seems Unity/DPD but major 157 mismatch
000269: Aug  6 18:47:03.135: ISAKMP:(0): vendor ID is NAT-T v3
000270: Aug  6 18:47:03.135: ISAKMP:(0): processing vendor id payload
000271: Aug  6 18:47:03.135: ISAKMP:(0): vendor ID seems Unity/DPD but major 123 mismatch
000272: Aug  6 18:47:03.135: ISAKMP:(0): vendor ID is NAT-T v2
000273: Aug  6 18:47:03.135: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000274: Aug  6 18:47:03.135: ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM1
000275: Aug  6 18:47:03.135: ISAKMP:(0): constructed NAT-T vendor-rfc3947 ID
000276: Aug  6 18:47:03.135: ISAKMP:(0): sending packet to 2.50.37.13 my_port 500 peer_port 500 (R) MM_SA_SETUP
000277: Aug  6 18:47:03.135: ISAKMP:(0):Sending an IKE IPv4 Packet.
000278: Aug  6 18:47:03.135: ISAKMP:(0):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000279: Aug  6 18:47:03.135: ISAKMP:(0):Old State = IKE_R_MM1  New State = IKE_R_MM2
000280: Aug  6 18:47:03.191: ISAKMP (0): received packet from 2.50.37.13 dport 500 sport 500 Global (R) MM_SA_SETUP
000281: Aug  6 18:47:03.191: ISAKMP:(0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000282: Aug  6 18:47:03.191: ISAKMP:(0):Old State = IKE_R_MM2  New State = IKE_R_MM3
000283: Aug  6 18:47:03.191: ISAKMP:(0): processing KE payload. message ID = 0
000284: Aug  6 18:47:03.199: ISAKMP:(0): processing NONCE payload. message ID = 0
000285: Aug  6 18:47:03.203: ISAKMP:(0):found peer pre-shared key matching 2.50.37.13
000286: Aug  6 18:47:03.203: ISAKMP:(2001): processing vendor id payload
000287: Aug  6 18:47:03.203: ISAKMP:(2001): vendor ID is DPD
000288: Aug  6 18:47:03.203: ISAKMP:(2001): processing vendor id payload
000289: Aug  6 18:47:03.203: ISAKMP:(2001): speaking to another IOS box!
000290: Aug  6 18:47:03.203: ISAKMP:(2001): processing vendor id payload
000291: Aug  6 18:47:03.203: ISAKMP:(2001): vendor ID seems Unity/DPD but major 223 mismatch
000292: Aug  6 18:47:03.203: ISAKMP:(2001): vendor ID is XAUTH
000293: Aug  6 18:47:03.203: ISAKMP:received payload type 20
000294: Aug  6 18:47:03.203: ISAKMP (2001): His hash no match - this node outside NAT
000295: Aug  6 18:47:03.203: ISAKMP:received payload type 20
000296: Aug  6 18:47:03.203: ISAKMP (2001): No NAT Found for self or peer
000297: Aug  6 18:47:03.203: ISAKMP:(2001):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000298: Aug  6 18:47:03.203: ISAKMP:(2001):Old State = IKE_R_MM3  New State = IKE_R_MM3
000299: Aug  6 18:47:03.203: ISAKMP:(2001): sending packet to 2.50.37.13 my_port 500 peer_port 500 (R) MM_KEY_EXCH
000300: Aug  6 18:47:03.203: ISAKMP:(2001):Sending an IKE IPv4 Packet.
000301: Aug  6 18:47:03.203: ISAKMP:(2001):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000302: Aug  6 18:47:03.203: ISAKMP:(2001):Old State = IKE_R_MM3  New State = IKE_R_MM4
000303: Aug  6 18:47:03.295: ISAKMP (2001): received packet from 2.50.37.13 dport 500 sport 500 Global (R) MM_KEY_EXCH
000304: Aug  6 18:47:03.295: ISAKMP:(2001):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000305: Aug  6 18:47:03.295: ISAKMP:(2001):Old State = IKE_R_MM4  New State = IKE_R_MM5
000306: Aug  6 18:47:03.295: ISAKMP:(2001): processing ID payload. message ID = 0
000307: Aug  6 18:47:03.295: ISAKMP (2001): ID payload
        next-payload : 8
        type         : 1
        address      : 2.50.37.13
        protocol     : 17
        port         : 500
        length       : 12
000308: Aug  6 18:47:03.295: ISAKMP:(0):: peer matches *none* of the profiles
000309: Aug  6 18:47:03.295: ISAKMP:(2001): processing HASH payload. message ID = 0
000310: Aug  6 18:47:03.295: ISAKMP:(2001): processing NOTIFY INITIAL_CONTACT protocol 1
        spi 0, message ID = 0, sa = 0x8B4C1924
000311: Aug  6 18:47:03.295: ISAKMP:(2001):SA authentication status:
        authenticated
000312: Aug  6 18:47:03.295: ISAKMP:(2001):SA has been authenticated with 2.50.37.13
000313: Aug  6 18:47:03.295: ISAKMP:(2001):SA authentication status:
        authenticated
000314: Aug  6 18:47:03.295: ISAKMP:(2001): Process initial contact,
bring down existing phase 1 and 2 SA's with local 92.98.211.242 remote 2.50.37.13 remote port 500
000315: Aug  6 18:47:03.295: ISAKMP: Trying to insert a peer 92.98.211.242/2.50.37.13/500/,  and inserted successfully 8668106C.
000316: Aug  6 18:47:03.295: ISAKMP:(2001):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000317: Aug  6 18:47:03.295: ISAKMP:(2001):Old State = IKE_R_MM5  New State = IKE_R_MM5
000318: Aug  6 18:47:03.295: ISAKMP:(2001):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
000319: Aug  6 18:47:03.295: ISAKMP (2001): ID payload
        next-payload : 8
        type         : 1
        address      : 92.98.211.242
        protocol     : 17
        port         : 500
        length       : 12
000320: Aug  6 18:47:03.295: ISAKMP:(2001):Total payload length: 12
000321: Aug  6 18:47:03.295: ISAKMP:(2001): sending packet to 2.50.37.13 my_port 500 peer_port 500 (R) MM_KEY_EXCH
000322: Aug  6 18:47:03.295: ISAKMP:(2001):Sending an IKE IPv4 Packet.
000323: Aug  6 18:47:03.295: ISAKMP:(2001):Returning Actual lifetime: 1800
000324: Aug  6 18:47:03.299: ISAKMP: set new node -1235582904 to QM_IDLE
000325: Aug  6 18:47:03.299: ISAKMP:(2001):Sending NOTIFY RESPONDER_LIFETIME protocol 1
        spi 2291695856, message ID = 3059384392
000326: Aug  6 18:47:03.299: ISAKMP:(2001): sending packet to 2.50.37.13 my_port 500 peer_port 500 (R) MM_KEY_EXCH
000327: Aug  6 18:47:03.299: ISAKMP:(2001):Sending an IKE IPv4 Packet.
000328: Aug  6 18:47:03.299: ISAKMP:(2001):purging node -1235582904
000329: Aug  6 18:47:03.299: ISAKMP: Sending phase 1 responder lifetime 1800
000330: Aug  6 18:47:03.299: ISAKMP:(2001):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000331: Aug  6 18:47:03.299: ISAKMP:(2001):Old State = IKE_R_MM5  New State = IKE_P1_COMPLETE
000332: Aug  6 18:47:03.299: ISAKMP:(2001):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
000333: Aug  6 18:47:03.299: ISAKMP:(2001):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
000334: Aug  6 18:47:03.307: ISAKMP (2001): received packet from 2.50.37.13 dport 500 sport 500 Global (R) QM_IDLE
000335: Aug  6 18:47:03.307: ISAKMP: set new node -687536412 to QM_IDLE
000336: Aug  6 18:47:03.307: ISAKMP:(2001): processing HASH payload. message ID = 3607430884
000337: Aug  6 18:47:03.307: ISAKMP:(2001): processing SA payload. message ID = 3607430884
000338: Aug  6 18:47:03.307: ISAKMP:(2001):Checking IPSec proposal 1
000339: Aug  6 18:47:03.307: ISAKMP: transform 1, ESP_3DES
000340: Aug  6 18:47:03.307: ISAKMP:   attributes in transform:
000341: Aug  6 18:47:03.307: ISAKMP:      encaps is 1 (Tunnel)
000342: Aug  6 18:47:03.307: ISAKMP:      SA life type in seconds
000343: Aug  6 18:47:03.307: ISAKMP:      SA life duration (basic) of 3600
000344: Aug  6 18:47:03.307: ISAKMP:      SA life type in kilobytes
000345: Aug  6 18:47:03.307: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
000346: Aug  6 18:47:03.307: ISAKMP:      authenticator is HMAC-SHA
000347: Aug  6 18:47:03.307: ISAKMP:(2001):atts are acceptable.
000348: Aug  6 18:47:03.307: ISAKMP:(2001): processing NONCE payload. message ID = 3607430884
000349: Aug  6 18:47:03.311: ISAKMP:(2001): processing ID payload. message ID = 3607430884
000350: Aug  6 18:47:03.311: ISAKMP:(2001): processing ID payload. message ID = 3607430884
000351: Aug  6 18:47:03.311: ISAKMP:(2001):QM Responder gets spi
000352: Aug  6 18:47:03.311: ISAKMP:(2001):Node 3607430884, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
000353: Aug  6 18:47:03.311: ISAKMP:(2001):Old State = IKE_QM_READY  New State = IKE_QM_SPI_STARVE
000354: Aug  6 18:47:03.311: ISAKMP:(2001): Creating IPSec SAs
000355: Aug  6 18:47:03.311:         inbound SA from 2.50.37.13 to 92.98.211.242 (f/i)  0/ 0
        (proxy 192.168.10.0 to 192.168.50.0)
000356: Aug  6 18:47:03.311:         has spi 0x4C5A127C and conn_id 0
000357: Aug  6 18:47:03.311:         lifetime of 3600 seconds
000358: Aug  6 18:47:03.311:         lifetime of 4608000 kilobytes
000359: Aug  6 18:47:03.311:         outbound SA from 92.98.211.242 to 2.50.37.13 (f/i) 0/0
        (proxy 192.168.50.0 to 192.168.10.0)
000360: Aug  6 18:47:03.311:         has spi  0x1E83EC91 and conn_id 0
000361: Aug  6 18:47:03.311:         lifetime of 3600 seconds
000362: Aug  6 18:47:03.311:         lifetime of 4608000 kilobytes
000363: Aug  6 18:47:03.311: ISAKMP:(2001): sending packet to 2.50.37.13 my_port 500 peer_port 500 (R) QM_IDLE
000364: Aug  6 18:47:03.311: ISAKMP:(2001):Sending an IKE IPv4 Packet.
000365: Aug  6 18:47:03.311: ISAKMP:(2001):Node 3607430884, Input = IKE_MESG_INTERNAL, IKE_GOT_SPI
000366: Aug  6 18:47:03.311: ISAKMP:(2001):Old State = IKE_QM_SPI_STARVE  New State = IKE_QM_R_QM2
000367: Aug  6 18:47:03.323: ISAKMP (2001): received packet from 2.50.37.13 dport 500 sport 500 Global (R) QM_IDLE
000368: Aug  6 18:47:03.323: ISAKMP:(2001):deleting node -687536412 error FALSE reason "QM done (await)"
000369: Aug  6 18:47:03.323: ISAKMP:(2001):Node 3607430884, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
000370: Aug  6 18:47:03.323: ISAKMP:(2001):Old State = IKE_QM_R_QM2  New State = IKE_QM_PHASE2_COMPLETE
000371: Aug  6 18:47:53.323: ISAKMP:(2001):purging node -687536412
ROUTER-A# sho crypto isa sa
92.98.211.242   2.50.37.13      QM_IDLE           2001 ACTIVE
RUNNING CONFIGURATION OF ROUTER-A
Building configuration...
Current configuration : 29089 bytes
! Last configuration change at 21:31:11 PST Tue Aug 7 2012 by administrator
version 15.1
parser config cache interface
no service pad
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname xxxxxxxxxxXX
boot-start-marker
boot-end-marker
enable secret 4 LcV6aBcc/53FoCJjXQMd7rBUDEpeevrK8V5jQVoJEhU
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
clock timezone ZP4 4 0
clock summer-time PST recurring
crypto pki trustpoint TP-self-signed-4070447007
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4070447007
revocation-check none
rsakeypair TP-self-signed-4070447007
crypto pki certificate chain TP-self-signed-4070447007
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34303730 34343730 3037301E 170D3132 30373331 30353139
  30375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30373034
  34373030 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BBA6 F2C9A163 B7EAB25D 6C538A5B 29832F58 6B95D2C0 1FBE0E72 BD4E9585
  6230CAD1 8DA4E337 5A11332C 36EAFF86 02D8C977 6CD2AA50 D76FB97F 52AE73AD
  E777194B 011C95EB E2A588B4 3A7D618E F1D03E3F EF1A60FB 26372B63 9395002D
  38126CC5 EA79E23C 40E0F331 76E7731E D03E2CE8 F1A0B5E9 B83AA780 D566A679
  599F0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14C8BC47 90602FB0 18A8821A 85A3444F 874E2292 27301D06
  03551D0E 04160414 C8BC4790 602FB018 A8821A85 A3444F87 4E229227 300D0609
  2A864886 F70D0101 05050003 8181001B D0EA74FE 7EDD03FE 68733D87 6434D20B
  80481807 DD4A488E FFEFA631 245F396F 5CADF523 1438A70B CA113994 9798483D
  F59221EA 09EDB8FC 6D1DBBAE FE7FE4B9 E79F064F E930F347 B1CAD19B 01F5989A
  8BCFDB1D 906163A4 C467E809 E988B610 FE613177 A815DFB0 97839F92 4A682E8F
  43F08787 E08CBE70 E98DEBE7 BCD8B8
            quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 192.168.50.1 192.168.50.9
ip dhcp excluded-address 192.168.50.241 192.168.50.255
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.50.0 255.255.255.0
default-router 192.168.50.1
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
ip ddns update method sdm_ddns1
HTTP
  add http://xxxxxxxs:ppppp@members.dyndns.org/nic/update?system=dyndns&hostname=ppppp@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
  remove http://xxxxxxx:pppppp@members.dyndns.org/nic/update?system=dyndns&hostname=pppppp@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
interval maximum 2 0 0 0
interval minimum 1 0 0 0
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  call start slow
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.1.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 1113
rule 1 /^82\(...\)/ /\1/
voice translation-rule 1114
rule 1 /\(^...$\)/ /82\1/
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile multisiteInbound
translate called 1113
voice translation-profile multisiteOutbound
translate calling 1114
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax interface-type fax-mail
license udi pid UC560-FXO-K9 sn FHK1445F43M
archive
log config
  logging enable
  logging size 600
  hidekeys
username administrator privilege 15 secret 4 LcV6aBcc/53FoCJjXQMd7rBUDEpeevrK8V5jQVoJEhU
username pingerID password 7 06505D771B185F
ip tftp source-interface Vlan90
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 1800
crypto isakmp key xxxxxxx address 0.0.0.0 0.0.0.0
crypto isakmp client configuration group EZVPN_GROUP_1
key xxxxxxx
dns 213.42.20.20
pool SDM_POOL_1
save-password
max-users 20
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
crypto map multisite 1 ipsec-isakmp
description XXXXXXX
set peer xxxxxxxxxx.dyndns.biz dynamic
match address 105
qos pre-classify
interface GigabitEthernet0/0
description $ETH-WAN$
no ip address
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport mode trunk
switchport voice vlan 100
no ip address
macro description cisco-switch
interface GigabitEthernet0/1/1
no ip address
macro description cisco-phone
spanning-tree portfast
interface GigabitEthernet0/1/2
no ip address
macro description cisco-desktop
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
no ip address
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
description $FW_INSIDE$
ip address 192.168.50.1 255.255.255.0
ip access-group 101 in
ip nat inside
ip tcp adjust-mss 1412
h323-gateway voip bind srcaddr 192.168.50.1
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip access-group 103 in
ip nat inside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface Dialer0
description $FW_OUTSIDE$
mtu 1492
ip ddns update hostname xxxxxxxxxx.dyndns.biz
ip ddns update sdm_ddns1
ip address negotiated
ip access-group 104 in
ip mtu 1452
ip nat outside
ip inspect SDM_LOW out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname CCCCCC
ppp chap password 7 071739545611015445
ppp pap sent-username CCCCC password 7 122356324SDFDBDB
ppp ipcp dns request
ppp ipcp route default
ip local pool SDM_POOL_1 192.168.50.150 192.168.50.160
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.1.10.1 255.255.255.255 Vlan90
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host 192.168.50.1 eq non500-isakmp
access-list 101 permit udp any host 192.168.50.1 eq isakmp
access-list 101 permit esp any host 192.168.50.1
access-list 101 permit ahp any host 192.168.50.1
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 permit ip any any
access-list 101 permit ip 10.1.10.0 0.0.0.3 any
access-list 101 permit ip 10.1.1.0 0.0.0.255 any
access-list 101 permit ip host 255.255.255.255 any
access-list 101 permit ip 127.0.0.0 0.255.255.255 any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit udp any host 10.1.1.1 eq non500-isakmp
access-list 102 permit udp any host 10.1.1.1 eq isakmp
access-list 102 permit esp any host 10.1.1.1
access-list 102 permit ahp any host 10.1.1.1
access-list 102 permit ip any any
access-list 102 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 permit ip 192.168.50.0 0.0.0.255 any
access-list 102 permit ip 10.1.10.0 0.0.0.3 any
access-list 102 permit ip host 255.255.255.255 any
access-list 102 permit ip 127.0.0.0 0.255.255.255 any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any host 10.1.10.2 eq non500-isakmp
access-list 103 permit udp any host 10.1.10.2 eq isakmp
access-list 103 permit esp any host 10.1.10.2
access-list 103 permit ahp any host 10.1.10.2
access-list 103 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 103 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 103 permit ip 192.168.50.0 0.0.0.255 any
access-list 103 permit ip 10.1.1.0 0.0.0.255 any
access-list 103 permit ip host 255.255.255.255 any
access-list 103 permit ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_13##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit ip 192.168.10.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 104 permit udp any any eq non500-isakmp
access-list 104 permit udp any any eq isakmp
access-list 104 permit esp any any
access-list 104 permit ahp any any
access-list 104 permit ip any any
access-list 104 permit ip 192.168.50.0 0.0.0.255 any
access-list 104 permit ip 10.1.10.0 0.0.0.3 any
access-list 104 permit ip 10.1.1.0 0.0.0.255 any
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 permit ip 10.0.0.0 0.255.255.255 any
access-list 104 permit ip 172.16.0.0 0.15.255.255 any
access-list 104 permit ip 192.168.0.0 0.0.255.255 any
access-list 104 permit ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip host 255.255.255.255 any
access-list 104 permit ip host 0.0.0.0 any
access-list 105 remark CryptoACL for xxxxxxxxxx
access-list 105 remark SDM_ACL Category=4
access-list 105 permit ip 192.168.50.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 106 remark SDM_ACL Category=2
access-list 106 deny   ip 192.168.50.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 106 permit ip 10.1.10.0 0.0.0.3 any
access-list 106 permit ip 192.168.50.0 0.0.0.255 any
access-list 106 permit ip 10.1.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map SDM_RMAP_1 permit 1
match ip address 106
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
voice-port 0/0/0
station-id number 401
caller-id enable
voice-port 0/0/1
station-id number 402
caller-id enable
voice-port 0/0/2
station-id number 403
caller-id enable
voice-port 0/0/3
station-id number 404
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 201
description Configured by CCA 4 FXO-0/1/0-OP
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-OP
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-OP
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-OP
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan90
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register mtpd0d0fd057a40
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Multisite Only
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 10
associate application SCCP
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 403
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 404
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description ôcatch all dial peer for BRI/PRIö
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-7-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-7-Digit*7-Digit Local**
preference 5
destination-pattern 9[2-9]......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*North American-7-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-7-Digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-7-Digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-7-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91855.......
forward-digits all
no sip-register
dial-peer voice 2100 voip
corlist incoming call-internal
description **CCA*INTERSITE inbound call to xxxxxxxxxx
translation-profile incoming multisiteInbound
incoming called-number 82...
voice-class h323 1
dtmf-relay h245-alphanumeric
fax protocol cisco
no vad
dial-peer voice 2101 voip
description **CCA*INTERSITE outbound calls to xxxxxxxxxx
translation-profile outgoing multisiteOutbound
destination-pattern 81...
session target ipv4:192.168.10.1
voice-class h323 1
fax protocol cisco
no vad
no dial-peer outbound status-check pots
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 10
sdspfarm tag 2 mtpd0d0fd057a40
video
fxo hook-flash
max-ephones 138
max-dn 600
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message Cisco Small Business
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 521G-524G cp524g-8-1-17
time-zone 34
keepalive 30 auxiliary 4
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$WAFQ$OP1VRo.qS702FTu8jYLtZ/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Aug 01 2012 01:04:42
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  596  octo-line
number 300 no-reg primary
label raj
name ra j
call-forward noan 81200 timeout 20
ephone-dn  597  dual-line
number 201 no-reg primary
label 201
description RINCHU RAJ
name RINCHU RAJ
call-forward busy 399
call-forward noan 399 timeout 20
ephone-dn  598
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  599
number A801... no-reg primary
mwi off
ephone-dn  600
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address 0012.7FD9.6068
ephone-template 16
username "raj" password 123456
type 7940
button  1:596
ephone  5
mac-address CCEF.485E.66E0
ephone-template 16
max-calls-per-button 2
username "uone" password 123456
type 504G
button  1:597
ephone  6
mac-address 0012.7FDE.99E6
ephone-template 16
type 7940
alias exec cca_voice_mode PBX
banner login ^CCisco Configuration Assistant. Version: 3.2 (1). Tue Jul 31 18:00:27 GST 2012^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
event manager session cli username "pingerID"
event manager applet vpn-pinger
event timer watchdog time 120 maxrun 100
action 1.0           cli command "enable"
action 2_xxxxxxxxxx cli command "ping ip  192.168.10.1  source Vlan1 repeat 2 timeout 5"
end
RUNNING CONFIGURATION FROM ROUTER-B
Current configuration : 33800 bytes
! Last configuration change at 22:42:30 PST Tue Aug 7 2012 by administrator
! NVRAM config last updated at 23:39:21 PST Sat Aug 4 2012 by administrator
version 15.1
no service pad
service internal
hostname xxxxxxxxxxI
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/3
aaa new-model
crypto pki trustpoint TP-self-signed-3185319720
subject-name cn=IOS-Self-Signed-Certificate-3185319720
rsakeypair TP-self-signed-3185319720
crypto pki certificate chain TP-self-signed-3185319720
  69666963 6174652D 33313835 33313937 3230301E 170D3132 30373331 31313138
  34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 31383533
  31393732 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CCAD 9950E6EE 95FEE29D A9B6C621 1923402B 1FE17E8A 4CE19D8A D922ACE3
  C620C023 39872246 2768F796 1AB8AD4F 3FA90F8D 4E9174B6 B1FD04B4 EE8F4DCC
  65D97A9C BAC2B55F E1836046 96BEB81F 27BE2774 DBAF263A 34DBCCC8 A0DB5019
  1C64BAEE DBE552C8 20F9FC79 CCADB008 E28A3FF5 B5AD875D 70B85FA4 3E4EC5AA
  CA830203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 148F77B7 EB3D576C 7BB1CD3C E824DF6A BEDCC8ED BA301D06
  03551D0E 04160414 8F77B7EB 3D576C7B B1CD3CE8 24DF6ABE DCC8EDBA 300D0609
  2A864886 F70D0101 05050003 81810085 B88D59B9 3CE8ACAB 7888C7D1 C2DD26AC
  A0E4A5A4 55A6D9A6 95F83034 B261112B 3490334A 214F94CD 385E58FA 460C2793
  83EEE878 41EA06EB 1DB3A198 BAE96086 BB16ABD0 CDED6550 1C2B4855 1B69CC67
  4F270E44 888EF633 86EBBF00 5514E100 BADF6DB8 3F02C02B 7DB1C3C8 8C09ABEB
  A2B59DFA D4A9E843 92ED0103 FECAFA
            quit
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.10.241 192.168.10.255
ip dhcp pool phone
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
HTTP
  add http://frtrgerg:1231231232313123@members.dyndns.org/nic/update?system=dyndns&hostname=1231231232313123@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
  remove http://xxxxx:121532132123@members.dyndns.org/nic/update?system=dyndns&hostname=121532132123@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice rtp send-recv
voice service voip
sip
  no update-callerid
voice class codec 1
voice class h323 1
  call start slow
no-circuit
mode cme
create profile sync 0112055807714808
voice translation-rule 4
rule 15 // //
rule 1 /.*/ //
rule 1 /^9/ //
rule 1 /^81\(...\)/ /\1/
rule 1 /\(^...$\)/ /81\1/
rule 1 /^6/ //
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice-card 0
dspfarm
license udi pid UC560-T1E1-K9 sn FGL1551100S
archive
log config
  logging enable
  logging size 600
  hidekeys
username pingerID password 7 055E515F791C17
encr 3des
group 2
description xxxxx
set peer xxxxxx.dyndns.biz dynamic
match address 105
qos pre-classify
no ip address
load-interval 30
duplex auto
speed auto
ip nat inside
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
h323-gateway voip bind srcaddr 192.168.10.1
interface Vlan90
ip nat inside
interface Vlan100
ip nat inside
interface Dialer0
ip ddns update hostname xxxxxxxxxxi.dyndns.biz
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname zzzzzz
ppp chap password 7 03055C195657395D59
ppp pap sent-username zzzzz password 7 cccccc
ip http server
ip dns server
access-list 101 permit ip 192.168.50.0 0.0.0.255 any
access-list 102 permit ip 192.168.10.0 0.0.0.255 any
access-list 103 permit ip 192.168.10.0 0.0.0.255 any
access-list 104 permit ip 192.168.50.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 104 permit ip 192.168.10.0 0.0.0.255 any
access-list 105 permit ip 192.168.10.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 106 deny   ip 192.168.10.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 106 permit ip 192.168.10.0 0.0.0.255 any
access-list 107 remark SDM_ACL Category=2
access-list 107 deny   ip 192.168.10.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 107 permit ip 10.1.10.0 0.0.0.3 any
access-list 107 permit ip 192.168.10.0 0.0.0.255 any
access-list 107 permit ip 10.1.1.0 0.0.0.255 any
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-9c.bin alias spa50x-30x-7-4-9c.bin
control-plane
voice-port 0/0/0
cptone AE
caller-id enable
voice-port 0/0/1
cptone AE
caller-id enable
voice-port 0/0/2
cptone AE
caller-id enable
voice-port 0/0/3
cptone AE
caller-id enable
voice-port 0/1/0
cptone AE
connection plar opx 200
caller-id enable
voice-port 0/1/1
cptone AE
caller-id enable
voice-port 0/1/2
cptone AE
caller-id enable
voice-port 0/1/3
cptone AE
caller-id enable
voice-port 0/2/0
cptone AE
description Configured by CCA 4 FXO-0/2/0-OP
caller-id enable
voice-port 0/2/1
cptone AE
shutdown
voice-port 0/2/2
cptone AE
shutdown
voice-port 0/2/3
cptone AE
shutdown
voice-port 0/4/0
auto-cut-through
signal immediate
sccp local Vlan90
sccp
sccp ccm group 1
associate profile 2 register mtp44d3ca454420
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 10
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member emergency
member internal
member local
member emergency
member toll-free
member internal
member local
member local-plus
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
port 0/0/0
no sip-register
port 0/0/1
no sip-register
port 0/0/2
no sip-register
port 0/0/3
no sip-register
port 0/4/0
no sip-register
direct-inward-dial
incoming called-number ^AAAA$
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
dial-peer voice 100 pots
port 0/2/0
dial-peer voice 101 pots
port 0/2/1
dial-peer voice 102 pots
port 0/2/2
dial-peer voice 103 pots
port 0/2/3
port 0/1/0
no sip-register
port 0/1/1
no sip-register
port 0/1/2
no sip-register
port 0/1/3
no sip-register
dial-peer voice 104 pots
destination-pattern A4
port 0/2/0
no sip-register
dial-peer voice 105 pots
destination-pattern A5
port 0/2/1
no sip-register
dial-peer voice 106 pots
destination-pattern A6
port 0/2/2
no sip-register
dial-peer voice 107 pots
destination-pattern A7
port 0/2/3
no sip-register
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
description **CCA*INTERSITE inbound call to xxxxxxxxxxI
incoming called-number 81...
voice-class h323 1
fax protocol cisco
no vad
destination-pattern 82...
session target ipv4:192.168.50.1
voice-class h323 1
fax protocol cisco
no vad
dial-peer voice 69 pots
trunkgroup ALL_FXO
description **CCA*UAE*Emergency**
preference 5
destination-pattern 99..
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 9..
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
description **CCA*UAE*International**
preference 5
destination-pattern 900T
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup ALL_FXO
description **CCA*UAE*Dubai local**
preference 5
destination-pattern 9[2-8]......
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
description **CCA*UAE*Non emergency Police**
preference 5
destination-pattern 9101
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_FXO
description **CCA*UAE*National**
preference 5
destination-pattern 90[2345678].......
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
corlist outgoing call-national-plus
description **CCA*UAE*Mobile**
preference 5
destination-pattern 905........
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup ALL_FXO
description **CCA*UAE*Toll free**
preference 5
destination-pattern 9[68]00T
forward-digits all
no sip-register
telephony-service
sdspfarm units 5
sdspfarm tag 2 mtp44d3ca454420
video
fxo hook-flash
max-ephones 138
max-dn 600
service phone webAccess 0
service dss
system message xxxxxx
load 501G spa50x-30x-7-4-9c
load 502G spa50x-30x-7-4-9c
load 504G spa50x-30x-7-4-9c
load 508G spa50x-30x-7-4-9c
load 509G spa50x-30x-7-4-9c
load 301 spa50x-30x-7-4-9c
load 303 spa50x-30x-7-4-9c
time-zone 34
date-format dd-mm-yy
voicemail 399
web admin system name cisco secret 5 $1$RyZT$u4zjKW91Y/VqGFVwIp2xJ/
dn-webedit
time-webedit
transfer-pattern .T
fac standard
create cnf-files version-stamp 7960 Aug 06 2012 23:30:48
ephone-template  15
ephone-template  16
ephone-template  17
ephone-template  18
ephone-dn  9
description MoH
moh out-call ABC
ephone-dn  582  dual-line
label 201
description MOHAMED FADEL
name MOHAMED FADEL
ephone-dn  583  dual-line
number 215 no-reg primary
label 215
description NOO R
name NOO R
ephone-dn  584  dual-line
number 204 no-reg primary
label 204
description USER B
name USER B
ephone-dn  585  dual-line
number 202 no-reg primary
label 202
description USER L
name USER L
ephone-dn  586  dual-line
number 212 no-reg primary
label 212
description USER K
name USER K
ephone-dn  587  dual-line
number 200 no-reg primary
label 200
description RECEPTIO N
name RECEPTIO N
ephone-dn  588  dual-line
number 233 no-reg primary
label 233
description SAVAD NOORJAHAN
name SAVAD NOORJAHAN
corlist incoming user-national-plus
ephone-dn  589  dual-line
number 219 no-reg primary
label 219
description USER Q
name USER Q
ephone-dn  590  dual-line
number 218 no-reg primary
label 218
description USER P
name USER P
ephone-dn  591  dual-line
number 227 no-reg primary
label 227
description USER V
name USER V
ephone-dn  592  dual-line
number 226 no-reg primary
label 226
description USER T
name USER T
ephone-dn  593  dual-line
number 231 no-reg primary
label 231
description USER S
name USER S
ephone-dn  594  dual-line
number 225 no-reg primary
label 225
description MOHAMMED AMEEN
name MOHAMMED AMEEN
ephone-dn  595  dual-line
number 213 no-reg primary
label 213
description Jennifer Jaleel
name JENNIFER JALEEL
ephone-dn  596  dual-line
number 214 no-reg primary
label 214
description TAMARA FAIZOVA
name TAMARA FAIZOVA
number 210 no-reg primary
label 210
description USER A
name USER A
ephone-dn  598
ephone-dn  599
mwi off
ephone-dn  600
mwi on
ephone  5
mac-address CCEF.485E.66CF
ephone-template 16
username "Mameen" password 123456
type 504G
button  1:594
ephone  6
mac-address CCEF.485E.668C
ephone-template 16
username "UV" password 123456
type 504G
button  1:591
ephone  7
mac-address 649E.F376.6D0E
ephone-template 16
username "Snoorjahan" password 123456
type 504G
button  1:588
ephone  8
mac-address CCEF.485E.6682
ephone-template 16
username "US" password 123456
type 504G
button  1:593
ephone  9
mac-address 649E.F376.6D1F
ephone-template 16
username "UQ" password 123456
type 504G
button  1:589
ephone  10
mac-address CCEF.485E.66BC
ephone-template 16
username "UT" password 123456
type 504G
button  1:592
ephone  11
mac-address 649E.F376.6D19
ephone-template 16
username "UL" password 123456
type 504G
button  1:585
ephone  12
mac-address 649E.F376.C67B
ephone-template 16
username "reception" password 123456
type 508G addon 1 500S
button  1:587
ephone  13
mac-address 649E.F376.6D16
ephone-template 16
username "UP" password 123456
type 504G
button  1:590
ephone  14
mac-address 649E.F376.6CFE
ephone-template 16
username "UB" password 123456
type 504G
button  1:584
ephone  15
mac-address CCEF.485E.6686
ephone-template 16
username "Tfaizova" password 123456
type 504G
button  1:596
ephone  16
mac-address 7081.05B3.7306
ephone-template 16
username "Mfadel" password 123456
type 525G2
button  1:582
ephone  17
mac-address CCEF.485E.66E3
ephone-template 16
username "Jjaleel" password 123456
type 504G
button  1:595
ephone  18
mac-address CCEF.485E.66B6
ephone-template 16
username "NR" password 123456
type 504G
button  1:583
ephone  19
mac-address 649E.F376.6D1A
ephone-template 16
username "UK" password 123456
type 504G
button  1:586
ephone  20
mac-address 649E.F376.6DA0
ephone-template 16
username "UA" password 123456
type 504G
button  1:597
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.2 (1). Tue Jul 31 15:48:42 GST 2012^^C
line con 0
line aux 0
line 2
no exec
transport input all
speed 115200
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
action 2_xxxxxxx cli command "ping ip  192.168.50.1  source Vlan1 repeat 2 timeout 5"
end
1345
