Community Member
smtp settings for voicemail notification in email ?
i have a client who uses google apps and his email address is user@hiscompanyname.net
I would like to know how i can setup the voicemail notification to the above email address? Not sure what smtrp settings to put in there.
I have set it up earlier where another client has his own smtp server onsite. Not sure how to get this one setup... any ideas?
Everyone's tags (5)
1 REPLY
Community Member
Re: smtp settings for voicemail notification in email ?
If you use the user's authentication for smtp sending through his GoogleApps account, Gmail will place the message in his sent messages folder. Try using the SMTP server settings for the local ISP the UC box is connected through.
Luis
1854
