Community Member
Software pack 8 for uc520 and SPA525G 7-4-2 load
Just loaded the spa525g 7-4-2 load from the 8.x software pack for uc520. I'm going to start listing bugs that I discover in that load so everyone can enjoy.
FIRST: CLI programmed "speedial" buttons do not appear on the phone. In the below example, buttons 2 and 3 on the phone display are blank.
ephone  42
device-security-mode none
video
mac-address 0025.8406.1111
ephone-template 19
max-calls-per-button 2
username "user" password 1234
speed-dial 1 815551212 label "when will it be fixed"
speed-dial 2 85551212 label "no chance"
paging-dn 1
type 525G
button  1:50 4m48 5m47
CISCO: Do I need to go to TAC with this bug?
Everyone's tags (3)
1 REPLY
Community Member
Re: Software pack 8 for uc520 and SPA525G 7-4-2 load
If you modify the configuration so that all the buttons come first before speeddial commands, the phone appears as programmed. This is a bug if you ask me, but that may not matter. On 79xx phones, the speeddials can come between buttons without problems.
This works but would be a limitation in that the end user would have to accept buttons not in the order they would want/need:
ephone  42
video
ephone-template 19
username "username" password 1234
speed-dial 1 815551212 label "this fixed it"
speed-dial 2 85551212 label "it is still a bug"
paging-dn 1
type 525G
button  1:50 2m48 3m47
So the speed-dials appear properly on buttons 4 and 5.
1203
