SPA 501 - disabling IVR configuration menu
I am deploying spa 501 with asterisk and need to be able to disable IVR configuration menu or at least set a password for it. Would you have any idea how to do it?
Konrad.
I really need some help on it. Is there no way to disable or set a password for IVR configuration menu?
Konrad
The IVR protection is already part of the latest firmware for the SPA1xx, which is an ATA.
I do believe that Cisco might also release this feature on the next Firmware for the SPA50x.
Anyway, I don't see anything wrong users using the admin IVR, since they can only get informations from phone.
Anything that is related with configuration changes, are protected by the admin password, like enabling the Web interface or resetting into default factory settings.
Joao
619
