SPA 504G MWI
I have SPA504g connected to my voip PBX. When the MWI option is set to yes, it turns the MWI on permanently, regardless of whether there is a message or not.
The only way to turn off the MWI is set the option to NO.
Any ideas why this ahhpens and how to rectify?
Jim
SPA 504G MWI
If you are referring to the flag in the "Call Feature Settings" section in the "Ext" tab in the GUI, if it is set to "yes," the light will remain on (always). I believe the field should be left on the default setting, no, unless there is some type of problem with the MWI indicator and there is a need to turn the light on manually. Normally even if it is set to "no," if the phone has messages, the MWI indicator will light up.
Hope this helps.
SPA 504G MWI
Thank you. So how do I set the phone to accept MWI from the Voipswitch itself?, as this does not light at all with the setting set to no.
SPA 504G MWI
It is something that your VoIP service provider has to support. I think if they support it, some kind of flag is set in the SIP messages from the provider to the phone and that triggers the light to come on. I don't think there is any configuration required on the phone side, other than entering your mailbox ID and server in the GUI.
SPA 504G MWI
The system lights the MWI on other IP phones such as polycom and Yealink..... But not Cisco... So the question is, what is the SPA504G looking for to trigger the lamp on, that is different from every other phone?
SPA 504G MWI
I configured my voice mailbox ID and server in the GUI and I didn't have to do additional configuration, but I am using the SPA400 for voicemail.
I will send this thread to one of the engineers to see if we can get the information that you need.
SPA 504G MWI
James,
Under the EXT 1 tab there are 3 options fields related to the Phones MWI light.
Mailbox ID: (phone number or user id)
Voice Mail Server: (ip address or domain name:port)
Voice Mail Subscriber Interval: (default value of 86400 should be ok)
With the 3 options configured the phone should subscribe to the PBX voice mail service and through the NOTIFY messages the MWI light should turn on and off per the status from the voice mail service.
Randy
SPA 504G MWI
Randy,
On the SPA504G I see only the mailbox number option, as well as a restrict MWI option. Nothing else...?
James
SPA 504G MWI
James,
Are you logged into the phone web browser with admin & advancedpage mode?
Upper right hand corner of web broswer page provide the access.
After the admin/advancedpage is accessed then the Voicemail settings are in the EXT 1 tab.
Randy
SPA 504G MWI
Thanks Randy, I logged in at that level. All set correctly, but still does not work. I can turn the led and interupted dial tome on and off by setting MWI yes / no. But does not respond or work with the VPS
SPA 504G MWI
James,
Go ahead and email me directly for further troubleshooting the MWI issue.
rbordner@cisco.com
Randy
SPA 504G MWI
I have the same kind of issue with a SPA504G.
The light keeps being on.
In the feature settings, I set "no" for "Message Waiting:".
I also have a sip trace where I can see the "NOTIFY" messages :
Notification arrivée nouveau message :
U 91.213.79.49:5060 -> 80.12.80.19:5062
NOTIFY sip:9998@192.168.1.253:5062 SIP/2.0.
Via: SIP/2.0/UDP 91.213.79.49:5060;branch=z9hG4bK71e08586;rport.
Max-Forwards: 70.
To: <9998>.
Contact: .
Call-ID: 5a0e8f385dcdaa9f182a88cf0b8e8975@91.213.79.49:5060.
CSeq: 102 NOTIFY.
User-Agent: FPBX-2.9.0(1.8.7.1).
Event: message-summary.
Content-Type: application/simple-message-summary.
Content-Length: 93.
Messages-Waiting: yes.
Message-Account: sip:*97@91.213.79.49:5060.
Voice-Message: 1/0 (0/0).
Notification "plus de message" :
Via: SIP/2.0/UDP 91.213.79.49:5060;branch=z9hG4bK08b98f37;rport.
Max-Forwards: 70.
To: <9998>.
Contact: .
Call-ID: 66bfcd720205f4404a6577aa71d85990@91.213.79.49:5060.
CSeq: 102 NOTIFY.
Content-Length: 92.
Messages-Waiting: no.
Voice-Message: 0/0 (0/0).
So why my led keeps being on ?
Re: SPA 504G MWI
I am having the same issue.MWI will not come on, even with message. I configured the 504g as follows - Call feature Settings
Message waiting: no
Mailbox ID: anveo user ID number
Voicemail subscribe interval: 86400
Voice Mail Server: anveo domain and port
I can see the subscription updating on my anveo user account page. MWI still does not light when I get a voicemail. Thanks for any help you may be able to provide.
4519
